Old 02-29-2012, 10:15 AM   #1
nfranz10
Member#: 244468
2007 Impreza WRX STi
Pearl
Default P0302 - Cylinder 2 Misfire - Fixed
Hey guys,
I just wanted to give a recount of my experience with my first CEL and the steps the Apollo Performance guys and I took to fix it:
2007 STi
~62,000 Miles - All maintenance current
Stage 2 [3" dp, 2.5" catback, SPT intake]
Events:
1 - Just had the 60K check up done with the Apollo guys. Saved tons of money! WOO.
2 - Wanted to go stage 2, Godspeed downpipe installed, but since it's 3" and I have 2.5" exhaust, needed an adapter, ran a few weeks w/o until it got shipped.. loaded a temporary stage 2 map from the tuner until the adapter came. OK, no biggie.
3 - Gaslight came on as usual one day. However, when I filled up the tank, it only took 12 gallons or so [normally 14-14.5]. Then when I started, the gas gauge did not read fully filled up. Weird.
4 - Few days later, cruising on an on-ramp around 45 mph. Then, loss in power, hesistation from the engine. Went off the accelerator, then back on, very very sluggish and harsh feeling. CHECK ENGINE LIGHT flashes. ****.
5 - Plug in CobbAP, CELs read: P0302 [cylinder 2 misfire], PFFFF and PFFFE. shat...
Car symptoms:
+slight backfire when the car is started.
+rough idle
+Sluggish, hesistation.
+Nasty acceleration, so I avoided driving like normal, babied the car.
+Reduced gas mileage. About 170 miles per tank. EXPENSIVE.
Steps to fix it:
1 - Compression test. As I have an '07 STi, first thing Apollo guys did was to check compression. Pass with flying colors. Crisis averted. Phew.
2 - Check Spark plugs. Just replaced from the 60K overhaul, inspected. Clean.
3 - Inspect downpipe area. DP gasket seems blown, replaced. Installed adapter. No improvement, except for reduced exhaust noise obviously.
4 - Gave an idle log to the tuner. He thought it was the intake because the MAF reading was off. Inspected intake with Apollo guys, looks ok. Replaced filter with KN air filter. slight improvement in acceleration, everything else the same.
5 - At this point, check the coilpack or check injectors. Swapped a coilpack with a good set. and baboom, FIXED.
Pretty miserable experience when your subie is sick, but glad everything is fixed. As always, very grateful for the Apollo Performance guys and their great knowledge/customer service.
Hope that makes sense, just wanted to add that to the records of the p0302 CELs so that people can reference my experience should they ever have a similar problem.
-Noah
nfranz10 is offline   Reply With Quote
Old 02-29-2012, 04:28 PM   #2
Vrooom_Psh
Member#: 311923
04 STi
Appreciate it Noah! There should be a stickied P0302 thread because it seems to be pretty common.
So you replaced all the coilpacks? and left the injectors alone?
I've got the same thing going on with my '04 STi right now
Vrooom_Psh is offline   Reply With Quote
Old 02-29-2012, 08:22 PM   #3
nfranz10
Member#: 244468
Pearl
Yeah.. I went in that day to do 2 things:
1) swap coilpacks with a fresh set
2) swap #2 injector with a new one
we began with the coilpacks [cuz it was the faster one of the 2], started the car up, and.... ran great. So we skipped checking the injectors.
Have had no problems with it since. Just been working on e-tune.
Hope your STi gets fixed ASAP!
Old 02-29-2012, 08:25 PM   #4
nfranz10
Member#: 244468
Pearl
If I were to re-do everything, in this order I would:
  1. Compression, if you have an '07 or really gut feeling its a compression issue
  2. Coilpack check
  3. O2 Sensor / downpipe area
  4. Intake and Intake Filter check
  5. Spark Plug / Injectors Check
P0301 P0302 P0303 = Cylinders 1-3 Misfiring KitchenerWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-06-2011 12:55 PM
P0302 CEL *cylinder 2 misfire* Badler Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 48 06-20-2011 05:29 PM
P0302 Cylinder 2 misfire detected...help! RS_to_WRX_swap Normally Aspirated Powertrain 52 03-28-2011 10:46 PM
P0302 Cylinder 2 misfire help? josh04 Normally Aspirated Powertrain 1 09-11-2005 06:34 AM
