Old 02-29-2012, 10:18 AM   #1
DNelson
Member#: 265983
MBP
Default Godspeed Lateral Links
Hey guys I'm looking to pick up some rear lateral links for my 02 wrx and I don't want to spend like 500 dollars on lateral links. Godspeed seems to offer quality lateral links for like 300 and I'm just curious if anyone has any experience with these items.
DNelson is offline   Reply With Quote
Old 02-29-2012, 12:14 PM   #2
teiva-boy
Member#: 22825
Why not buy STi bits or SPT bits?
teiva-boy is offline   Reply With Quote
Old 02-29-2012, 12:47 PM   #3
DNelson
Member#: 265983
MBP
im looking for wide range adjustability of camber and toe..and i dont think those provide that?
Old 02-29-2012, 01:04 PM   #4
teiva-boy
Member#: 22825
No they don't. But unless you are slamming your car, you don't need that functionality either. What you want from a performance perspective is better bushings and possibly a more rigid bar with more rigid endlinks.
What is the problem you are trying to solve to necessitate adjustable links?
Ultimately it's your money and you can buy crap products if you want, or blow it on quality gear. But it will suck if you're buying it for the wrong reasons.
Old 02-29-2012, 01:11 PM   #5
Bikelok
Member#: 254851
2002 WRX wagon 5mt
For good quality at a reasonable price I went with Eibach(SPC) lateral links. You can find them for less than $300. Easy to adjust and they are stoutly made.
They are also called the pro alignment kit.
Bikelok is offline   Reply With Quote
Old 02-29-2012, 01:13 PM   #6
Bikelok
Member#: 254851
2002 WRX wagon 5mt
I am not a fan of Godspeed products.
Old 02-29-2012, 01:42 PM   #7
DNelson
Member#: 265983
MBP
I'm buying lateral links in order to get more negative camber that I can't get out of bolts/camber plates. I was looking at the Eibach lateral links and they looked nice, I just didn't like how the bracket for the endlink seems to be seperate from the lateral link and you have to bolt them on. On ebay I found a set of godspeed lateral links and and trailing arms for 220, so that's the only thing making me hesitate on pulling the trigger on a more expensive brand. Thanks for the help so far guys, it's much appreciated.
Old 02-29-2012, 02:04 PM   #8
Bikelok
Member#: 254851
2002 WRX wagon 5mt
The sway bar mounting blocks on the Eibach links are very burly. I doubt they would ever slip or break.
Old 02-29-2012, 02:23 PM   #9
teiva-boy
Member#: 22825
Agreed.
Old 02-29-2012, 02:44 PM   #10
DNelson
Member#: 265983
MBP
Good to know, and you guys think I will be able to get enough adjustment from them? I prob have about -3 degrees from my rear camber plates but I need just a little more to stop rubbing, Just want to make sure that these will do the trick before I pull the trigger and purchase them.
Old 02-29-2012, 02:53 PM   #11
teiva-boy
Member#: 22825
Perhaps you should raise your car.
Old 02-29-2012, 03:09 PM   #12
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
so I did rear control arms for camber and lateral links for Toe on my 08, not sure if you guys are getting your names mixed up or they are called something different for the 02, but I know what I bought and put on my car specifically to fit my wheels and to get the camber where I want.
I bought cusco parts specifically because I did not want to cheap out on anything, its suspension thats under constant use. Nothing against godspeed but I went high end on this for a reason.
and my apologies if I am wrong with the naming of parts on the 02 compared to a 08
SedonaScooby is offline   Reply With Quote
Old 02-29-2012, 03:31 PM   #13
jamal
Member#: 71875
98 Legacy GT
my wheels fit
02-07 has lateral links and a trailing arm and a strut
08+ has lower control arm, upper a-arm, toe link, and trailing link and a shock.
I wouldn't put godspeed parts on my car if they were free.
jamal is offline   Reply With Quote
Old 02-29-2012, 05:59 PM   #14
SedonaScooby
Member#: 143522
98 Forester L (RIP)
Ya I went with cusco for a reason, plus that shiny blue is sexy
Old 02-29-2012, 06:30 PM   #15
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
Don't buy the godspeed lateral links. A close friend of mine had one snap on his Legacy while he was on the highway, it was damn scary.
I have Whiteline links and I love them.
03SubyWRX is offline   Reply With Quote
Old 02-29-2012, 09:42 PM   #16
DNelson
Member#: 265983
MBP
Good to know that definitely makes me NOT want to buy them. Eibach links here i come! Thanks for the help fellas.
Old 03-01-2012, 10:41 AM   #17
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
Why not get the TIC/MSI rear lateral links w/some Group N bushings.
http://turninconcepts.com/product_in...oducts_id=1123
csmithwrx'05 is offline   Reply With Quote
Old 03-01-2012, 10:59 AM   #18
DNelson
Member#: 265983
MBP
those dont look adjustable at all..
Old 03-01-2012, 12:04 PM   #19
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
opps didn't know you wanted adjustable. They are not, but still a really nice peice and do you really need adjustability anyways (most do not). Personally, I would rather have those than some crappy chinese knockoff/ebay Godspeed part.
Old 03-01-2012, 03:10 PM   #20
DNelson
Member#: 265983
MBP
Nahh i need adjustability, read higher! But thanks though they seem to be quality parts.
Old 03-01-2012, 07:56 PM   #21
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
I have had some ebay lateral links on my car for close to a year now, they are not godpseed but I'm pretty sure they are all the same. Since I fitted mine a number of people have also started using them without issues. The quality of the pillowballs is surprisingly good and they come with nice rubber boots to keep the dirt out, they are still tight as the day I installed them with no movement in the joints. The only downside I have found so far is the inner lock nuts on the rear links are almost impossible to reach with a spanner due to the small gap in the subframe. I got around that by doing them up off the car and only using the front links to adjust the toe. I have done plenty of hard driving on these and they are working well, couldn't be happier with them for the money.
in use
JDwhiteWRX is offline   Reply With Quote
Old 03-01-2012, 08:12 PM   #22
SedonaScooby
Member#: 143522
98 Forester L (RIP)
the difference is int he bushings, yours will wear out much much faster from what i've heard/read/seen
Old 03-01-2012, 09:54 PM   #23
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
Like I said, they still feel new after almost a year of abuse. Whether other people want to use them or not I don't care, just letting people know my actual experience running them.
Old 03-01-2012, 10:52 PM   #24
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
Those ebay links won't make it a year past the northeast winter the OP will be putting them through. Rust is a big concern, and the ebay links just can't handle it.
Again, my WL links still look good after 2 tough winters.
Old 03-01-2012, 11:25 PM   #25
teiva-boy
Member#: 22825
Two words for you that you may have never heard of down under..
Winter
Roadsalt
FS/FT : Godspeed rear lateral links and trailing arms, brand new! Blue! 02-07 Wrx/Sti Wirk TXIC Private Classifieds 5 01-10-2012 12:11 AM
FS/FT : 02-07 WRX/04 STi Godspeed Lateral Links!!! kcle730 SCIC Private Classifieds 3 06-15-2011 01:46 AM
06 STI Godspeed Lateral Links+Trailing Arms Question gcasey200 Brakes, Steering & Suspension 5 04-14-2011 06:51 PM
godspeed WRX lateral links bugeye-brawler Rocky Mountains Impreza Club Forum -- RMIC 6 12-15-2009 05:02 PM
