Old 03-01-2012, 02:30 AM   #1
dimwittedmoose
Member#: 231049
Default Legacy Brighton stored for a year, now gas gauge issues
Finally got the clutch in the beast and now that it's on the road, I fill the gas tank and it's only reading like 3/4 full. drive it a couple hundred miles and the tank is way down to empty and I'm still driving. Thought the sending unit or gauge went bad, so I test as per Haynes manual and find nothing unusual. Add 7 gallons of gas and the needl moves up to like a quarter tank. Fill it again to day after another 25 miles of driving and same deal, only goes up to like 3/4 full.
My question is, since thew gas gauge didn't act up like this before these problems, what happened during storage to cause this issue? Is therre some sort of balance tube between both sides of the gas tank that's not allowing fuel to get to both sides of the tank or is it something else.
TIA
DM&FS
dimwittedmoose is offline   Reply With Quote
Old 03-01-2012, 02:46 AM   #2
USLiberty
Member#: 294466
1993 Legacy SS
white
If its like my 93 turbo ss it uses two intank sender units, one on the driver side and one on passenger. One meters 0-1/2 level the other handles 1/2-full tank. So if either one is dirty it will act funny. I found the contacts on the fuel level sender that are in the tank were gummed up. Once I cleaned them both my gauge started being more accurate. Just my experience with fuel sender units
USLiberty is offline   Reply With Quote
Old 03-01-2012, 03:54 AM   #3
dimwittedmoose
Member#: 231049
Did your "low fuel" warning light still work despite the dirty contacts?? I haven't been able to determine if my warning light is functional yet. May have to carry a gallon of gas with me when the tank gets low next time and just test it all out by running the tank down all the way..
Thanks
DM&FS
Old 03-01-2012, 11:20 AM   #4
USLiberty
Member#: 294466
1993 Legacy SS
white
My low fuel light does not work but I think it may have something to do with my removal of the factory ecm. I have a standalone so I had to hookup each gauge individually. I think the low fuel sensor is part of the fuel level so maybe it will work after your level starts working. I always carry extra gallon of gas, duct tape, knife, water, basic sockets/wrenches, tiewraps and a first aid kit. If something can go wrong it will go wrong..... for me anyways. Does your brighton have hatchs to pull the fuelpump/sender unit from the top without dropping the gas tank? If so its an easy fix to clean the contacts, when you get it out you will see why they're so suspect to getting dirty. The contacts are exposed in the gas so any dirty fuel will eventually build up. I would do this first as its possible your low fuel light is the same issue. If you can't easily clean it then on the next full tank of gas poar a bottle of Seafoam in. Its a fuel system cleaner that works better than others IMO. they have it at wallmart or autozone, its a lazy mans fix and not guaranteed to clean in one use but it may work. I also use it in my synthetic motor oil for the last few miles before a change.
Old 03-01-2012, 08:09 PM   #5
dimwittedmoose
Member#: 231049
I ran two Techrons through in the first tank, so maybe that didn't help so much. Will try Sea Foam next tank. I'm thinking that having the tank and level sit in the same position for over a year could have been the issue. I felt lucky that it started after all that time down. My tank sending units are REAL easy to get to and upon ordering new gaskets for both, I will take the mess apart. The nuts holding it all down aren't too rusty, but some PB Blaste will free them up. For now, I will just carry some spare gas and tempt fate. Si9nce the gauge only gets to 3/4, it may be reasonable to assume that when it first hits empty that I still have 4 gallons left. Watching the trip odometer should get me close to the theoretical point where the light should come on at the 2 gallon mark. I guess I'm not sure if the low fuel light is activated by a certain ohm resistance in the sending wire or whether it's and actual position of the float arm. Thanks again for the follow up.
DM&FS
Old 03-01-2012, 10:24 PM   #6
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
It should have been stored with a full tank to prevent formation of condensation and corrosion...
I'd wager you've got a problem with one of the fuel senders.
CosmoTheCat is offline   Reply With Quote
weird gas gauge issue on 2011 WRX rkjunior Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-26-2011 12:50 PM
Holy s***, I've been on NASIOC for 3 years now. BhamRoadrunner Off-Topic 73 05-18-2008 01:11 PM
OK so I have had the MY04 PSM STi for a year now and . . . . . THE-95-STi Member's Car Gallery 51 12-27-2006 11:11 AM
The Ipod has been out for 4+ years now, is there a way to get the music off? crowbar Off-Topic 13 10-13-2006 08:35 PM
I've been stalling on fixing this for a year now... m4r10 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-04-2006 01:18 PM
