Alaskan Impreza Club
Old 03-01-2012, 05:53 PM   #1
DaBlueSquirrel
Member#: 311480
Default Fluids
So what is everyone running for fluids around here?
I have a 02 WRX with 127,000 miles with some modifications.
DaBlueSquirrel is offline   Reply With Quote
Old 03-01-2012, 05:55 PM   #2
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
I use Subaru's branded and recommended full-synthetic oil for 2011+ turbo models and my tranny fluid is Extra S. Mmmmm smooth.
chanomatik is online now   Reply With Quote
Old 03-01-2012, 06:14 PM   #3
bhinak
Member#: 300026
rotella t6 for oil.
bhinak is offline   Reply With Quote
Old 03-01-2012, 06:29 PM   #4
07_STi
Member#: 290953
i use rotella t6 as well, great stuff.
07_STi is offline   Reply With Quote
Old 03-01-2012, 06:30 PM   #5
DaBlueSquirrel
Member#: 311480
The T6 is Synthetic right? and what weight are you guys running.
Old 03-01-2012, 06:31 PM   #6
YourFearlessLeader
Member#: 273098
2014 Impreza WRX Hat
Crystal Black Silica
T6 Rotella 5w-40
YourFearlessLeader is offline   Reply With Quote
Old 03-01-2012, 06:34 PM   #7
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
T6 5-40. I would use amsoil if it didn't cost so much though.
LiLpNoY is offline   Reply With Quote
Old 03-01-2012, 06:35 PM   #8
07_STi
Member#: 290953
yes, it is.
Old 03-01-2012, 06:36 PM   #9
DaBlueSquirrel
Member#: 311480
k and are you guys switching up from winter to summer? or just running the same thing all year?
Any oil filter specifics?
How about for the Transmission fluid?
Old 03-01-2012, 06:43 PM   #10
chanomatik
Member#: 159474
SNOSLO
I used T6 in my 08 FSXT. Recommended, same weight as these guys year-round.
Old 03-01-2012, 06:48 PM   #11
DaBlueSquirrel
Member#: 311480
i was going to use amsoil but if you guys reccomend t6 ill use that. The guy i bought it from said he used to use synthetic but it got too hot so he switched back to non synthetic. he was told it is how the old blocks were????
Old 03-01-2012, 07:03 PM   #12
bhinak
Member#: 300026
T6 5w-40 year round.
Old 03-01-2012, 07:08 PM   #13
DaBlueSquirrel
Member#: 311480
So has anyone had the problem with running synthetic? Im just curious because of what someone told the guy i got the car from
(The guy i bought it from said he used to use synthetic but it got too hot so he switched back to non synthetic. he was told it is how the old blocks were????)
As far as the transmission. mine sounds like straight cut gears with the whine through all 5 gears. Just wondering if it is the wrong fluid. (its not low)
Old 03-01-2012, 07:41 PM   #14
_davin
Member#: 260501
2003 miata SE
Blurple
Theoretically synthetic should be better in every way, unless your engine is being kept sealed by gunk that the new oil cleans up and creates leaks. I've also already switched to the T6, based on unanimous praise and UOA results across the board. It makes it all the better that it's also the cheapest synthetic you can buy at $21 per gallon at walmart.
Oh and it only comes in 5w-40.
_davin is offline   Reply With Quote
Old 03-01-2012, 08:27 PM   #15
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
Synthetic for 30k miles and going. I started with mobil 1 at 10k still burned oil them switched, rate of burning oil slowed? Tried amsoil but it was cost prohibitive at 10 bucks a qt.
Old 03-01-2012, 08:34 PM   #16
DaBlueSquirrel
Member#: 311480
I will be switching to synthetic then.. i dont mind paying the extra $$ for amsoil. I thought it was weird to hear that it gets too hot with synthetic so ill try it out to see whats going on.
Still trying to figure out the nest Gear oil too
Old 03-01-2012, 08:43 PM   #17
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
I bought my '02 new when the Bugeye's first came out. Used conventional for the first 10,000 miles, then moved on to synthetic. Been on Rotella T6 for last 50,000 miles or so. It is the way to go. I still change it often though….no 6500 mile oil change intervals for me.
The notion that synthetics got too hot is absurd, they have far better heat soak properties than conventional oils and far superior shear protection capabilities.
There are literally volumes already written here in NASIOC on oil. Do yourself a favor and spend some time reading/searching. Educate yourself.
Nomadgene is offline   Reply With Quote
Old 03-01-2012, 08:50 PM   #18
_davin
Member#: 260501
2003 miata SE
Blurple
http://forums.nasioc.com/forums/showthread.php?t=499177
I also use the subaru blue oil filters because I got a good deal on a case and I won't get hassled about warranty issues, especially since I'm running a 'non-approved' oil. But you'd probably be fine just getting Frams from o'rielly. I don't know anything about gear oil.
Old 03-02-2012, 02:10 AM   #19
Shaggie 907
Member#: 256102
wal mart brand it's cheap
Shaggie 907 is offline   Reply With Quote
Old 03-02-2012, 02:20 AM   #20
RawCode
Member#: 3115
2002 Impreza 2.5RS
mobil 1 5w-30 High mileage (146k and counting)
Mobil 1 synth ATF
Some syth gear lube in front and rear diffs
RawCode is offline   Reply With Quote
Old 03-02-2012, 05:55 AM   #21
Durbin_SPT
Member#: 237036
2010 WRX
obsidian black pearl
Rotella T6 All year round
Durbin_SPT is offline   Reply With Quote
Old 03-02-2012, 05:30 PM   #22
AKSubie
Member#: 6214
01.5 Audi S4
www.motorsportsalaska.com
My thoughts on oil: Some of which is IMHO, some is regurgitation from what I've read and some ... probably way off base.. HAHAaha.
IMHO, Synthetic oil is the way to go unless you are breaking in an engine or have an old and tired engine that might not be sealed as properly. Synthetic tends to help protect more against sludging.
For me, I have used Mobil 1 almost exclusively up until I tried Amsoil. Cost difference for me wasnt that bad. My buddy's discount was ~$9/QT vs the M1 German blend for ~$8/QT. My oil change intervals are hovering around the 10k mile mark. Due to time constraints my last change went till 12k and was quite ... concerned/anxious. However I sent my oil off to Blackstone for a UOA and it came back very good with a recommendation I could go even longer. To note, I am also using the Amsoil oil filter if it makes a hill o beans. I have run the car again to 12k miles (with a couple ice races) and will again send it off for UOA.
According to what has been stated on various forums like QW, Rotella T6 seems to be the new preferred oil for higher end cars & turbo cars. Amsoil isn't too far behind right along side M1 (kind of a preference/available thing), and RP is far in the back. Most also tend to begin relying on UOA reports, almost to an anal level to discern their oil use and change intervals. MOST believe though, that changing a synthetic oil any sooner than 5-6k miles is considered wasting money.
Cliff Notes: I used to use M1, now use Amsoil 0w40. Changing at 10-12k miles with a Blackstone report. You should be fine with a synthetic.
AKSubie is offline   Reply With Quote
Old 03-02-2012, 05:37 PM   #23
MedioAWD
Member#: 295170
On Rotella T6 as well and using the subaru genuine filters.
MedioAWD is offline   Reply With Quote
Old 03-02-2012, 05:42 PM   #24
_davin
Member#: 260501
2003 miata SE
Blurple
12k holy cow, that takes some balls but awesome it holds up. I've heard good things about RedLine too, but with T6 being at least half the price...
Old 03-02-2012, 05:51 PM   #25
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
I'm gonna have to try the Rotella. I've used Mobil 1 exclusively in all my Subaru's. If it's getting favorable reviews over Mobil 1 and it's cheaper, it's a no brainer.
Dominator is offline   Reply With Quote
Fluids, fluids, fluids... subaru_steve Newbies & FAQs 12 01-30-2012 07:00 PM
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 05:54 AM
Brake Fluid/Steering Fluid/Diff. Fluid/Transmission Fluid Jasno999 Brakes, Steering & Suspension 11 09-27-2002 11:22 AM
MT fluid & power streering fluids are low... ok to top off? Fubaru Newbies & FAQs 9 10-04-2001 03:13 AM
Transmisission fluid & Differential Fluid CRAZY KEN Transmission (AT/MT) & Driveline 0 08-21-2001 02:44 PM
