Alaskan Impreza Club
Old 03-02-2012, 05:53 PM   #26
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
The jug that looks the coolest.
granny is offline   Reply With Quote
Old 03-02-2012, 06:00 PM   #27
_davin
Member#: 260501
2003 miata SE
Blurple
Originally Posted by DOMIN8R View Post
I'm gonna have to try the Rotella. I've used Mobil 1 exclusively in all my Subaru's. If it's getting favorable reviews over Mobil 1 and it's cheaper, it's a no brainer.
I used M1 in my MR2 and my wife's G6, but everyone on here says it's too thin and burns a lot.
I don't understand why they don't start marketing it for cars too, instead of just heavy duty trucks.
_davin is offline   Reply With Quote
Old 03-02-2012, 06:07 PM   #28
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
Slap a picture of a STi and I'll bye it!
Old 03-02-2012, 06:53 PM   #29
AKSubie
Member#: 6214
01.5 Audi S4
www.motorsportsalaska.com
12k holy cow, that takes some balls but awesome it holds up. I've heard good things about RedLine too, but with T6 being at least half the price...
Yeah, it did take some gonads. My buddy claimed that Amsoil oil, WITH their filter could last like 20k + miles, even had a warranty or something. It might be a bit different using a genuine OEM filter though. Not sure.
The key for me though was the oil report showing how good (or bad) my oil was when I changed it. With them claiming it still showed good properties and I could even extend the mileage if I chose, gave me confidence I could keep going 10-12k between changes. I'll send off another sample to confirm that interval wasnt some fluke.
AKSubie is offline   Reply With Quote
Old 03-02-2012, 06:59 PM   #30
DaBlueSquirrel
Member#: 311480
Well I finally went and bought everything. I bought the OEM Subaru filter (and New crush washer) 5qts Amsoil 5w-30 (as per Amsoil and Subaru). And 5qts of Amsoil 75-90 Gear Oil (as per Amsoil and Subaru). Subaru said to run Synthetic in everything so I will be swapping it all out here in about an hour. I appreciate everyone's input and assistance in helping me figure this out. I will post up how it all went afterwards.
DaBlueSquirrel is offline   Reply With Quote
Old 03-02-2012, 07:03 PM   #31
_davin
Member#: 260501
2003 miata SE
Blurple
Don't miss the meet! I'm about to change mine too, while I try and patch my bumper...
Old 03-03-2012, 06:52 AM   #32
07_BluRex
Member#: 127922
1996 Chevy S-10 ZR-2
Winter Beater Silver
Yep Rotella T6 5/40 here too, Switched to syn at 30,000. Did Mobil 1 first, heard both good and bad about it tho, and mostly only good about rotella so switched. I used to do 3000 mile changes but the oil still seemed pretty good so i was movin up to 4000 next but then sold car. Did Subaru black filters until i ran out, then blues, heard mostly good things about the blues, not as good as blacks but still good. But from what i hear Purolator Pure One is one of the best, but much more spendy than the blues, but depending on how hard you run it might be good for you. I was daily driver duty and babied my car so didn't splurge for Purolators.
07_BluRex is offline   Reply With Quote
Old 03-05-2012, 03:53 PM   #33
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
So I checked at Walmart, and they do carry the Rotella T6 5w40.
Rotella T6 5w40
4 qt jug for +- $22.00
22 / 4 = $5.5qt.
Mobil1 5w30
5qt jug for +- $26.00
26 / 5 = $5.20qt
Not a big monetary difference at all, but you'll need 2 jugs of Rotella for 1 oil change. With a lot of extra oil to spare.
http://www.shell.com/home/content/rotella/products/t6/
The new video is good info too, especially the cold temp demonstration and the graph that shows the wear protection.
Question: Any big difference with the long term use? Are the detergents and additives OK for gasoline engines?
Dominator is offline   Reply With Quote
Old 03-05-2012, 06:08 PM   #34
_davin
Member#: 260501
2003 miata SE
Blurple
Or a jug of T6 and .2qts of whatever you have lying around.
Old 03-05-2012, 06:12 PM   #35
AKSubie
Member#: 6214
01.5 Audi S4
While I may not adhere to the recommended mileage intervals, I do adhere to the "dont mix oil weights/brands" rule.
Old 03-05-2012, 06:18 PM   #36
_davin
Member#: 260501
2003 miata SE
Blurple
Why?.
Old 03-05-2012, 06:36 PM   #37
AKSubie
Member#: 6214
01.5 Audi S4
There used to be a theory that it was bad juju mixing the weights or brands of oil because the varying properties and additives between the manufacturers of the oils could be counter productive and wreak havoc as ... how I understood it then at least, the oils wouldn't exactly mix evenly, so you wind up with an inconsistent oil property. This could be an ole wives tale, or could still be true. I think at least it hold true for the weight at least.
For me though, it basically boils down to Personal preference and me being anal on wanting the same weight and brand of oil in the car. Plus, why would I spend the effort, money and research on deciding to use something like Rotella/Amsoil/M1 in my motor, only to dump in any ole oil to top it off?
Old 03-05-2012, 06:48 PM   #38
_davin
Member#: 260501
2003 miata SE
Blurple
Hmm, perhaps with conventional. I just can't fathom the physics behind that being the case, I sure as hell hope not.
Old 03-05-2012, 06:55 PM   #39
AKSubie
Member#: 6214
01.5 Audi S4
As I said... it might've just been an ole wives tale from the Dino oil days. I still think you lose a bit of the properties of the better oil when introducing the lower grade stuff.
Regardless, personal preference wise I'd not do it.
Old 03-05-2012, 07:21 PM   #40
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
^^ I'm just gonna buy 2 the first time, then the remaining other stuff will be the right stuff.
Old 03-06-2012, 12:22 AM   #41
DaBlueSquirrel
Member#: 311480
So far the amsoil is holding up great in the engine, tranny, and diff. Ive put about 300 miles on it and it all seems to be just as clean as when i changed it.
Fluids, fluids, fluids... subaru_steve Newbies & FAQs 12 01-30-2012 07:00 PM
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 05:54 AM
Brake Fluid/Steering Fluid/Diff. Fluid/Transmission Fluid Jasno999 Brakes, Steering & Suspension 11 09-27-2002 11:22 AM
MT fluid & power streering fluids are low... ok to top off? Fubaru Newbies & FAQs 9 10-04-2001 03:13 AM
Transmisission fluid & Differential Fluid CRAZY KEN Transmission (AT/MT) & Driveline 0 08-21-2001 02:44 PM
