Alaskan Impreza Club
Old 03-01-2012, 06:10 PM   #1
DaBlueSquirrel
Member#: 311480
Default Removing paint form an Intercooler
My intercooler is painted black and I would like to remove the paint since it is starting to chip and also it reduces the cooling properties a bit. What would you reccomend to remove it without damaging the intercooler?
DaBlueSquirrel is offline   Reply With Quote
Old 03-01-2012, 06:13 PM   #2
bhinak
Member#: 300026
dont use soap...
bhinak is offline   Reply With Quote
Old 03-01-2012, 06:17 PM   #3
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
I cleaned some parts with this stuff called aluminum bright. I would think it would take paint off but not completely sure but after you get the paint off it would do a good job polishing it up.
granny is offline   Reply With Quote
Old 03-01-2012, 06:40 PM   #4
AK_GT
Member#: 275567
2010 WRX
Light soda or walnut shell blasting. Make sure all orifaces are blocked off. Or, use aircraft paint stripper that you can get at O-Reilly's or Hi-Tec; brush it on, watch it peel the paint, then spray it off with a hose. Don't let it stay in contact with skin for very long or it will give you a chemical burn...
AK_GT is offline   Reply With Quote
Old 03-01-2012, 09:39 PM   #5
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
^^ I was going to suggest the aircraft stripper too.
Dominator is offline   Reply With Quote
Old 03-01-2012, 09:50 PM   #6
QwikEVO
Member#: 44172
2006 Lancer Evo 9
Plasti-Dip is for TOOLS
it shouldn't reduce the cooling capabilites if it was done properly...
QwikEVO is offline   Reply With Quote
Old 03-01-2012, 11:24 PM   #7
DaBlueSquirrel
Member#: 311480
It may not be that noticeable but painting the intercooler will decrease Intake air temperatures regardless of how it is done. By applying a layer of paint over the thin aluminuim fins they are not as efficient.
Old 03-01-2012, 11:42 PM   #8
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
As long as air can get through it it should be fine. Most people's intercooler fins are bent closed anyways. You are running an intercooler twice the size of stock anyways. Don't they come painted from APS? That's just my two cents but its your car so whatevs.
Old 03-03-2012, 08:57 PM   #9
khann23
Member#: 302662
I have a turboxs front mount on my 06. Had the same problem. I just took a razor blade to it and the paint would just peel right off.... Thats how i did mine.
This is mine after
khann23 is offline   Reply With Quote
Old 03-15-2012, 05:42 AM   #10
DaBlueSquirrel
Member#: 311480
I ended up using a friends Media blaster and 3 hrs later.. no paint I did 1/2 the cold side of the charge piping but im going to try and use aircraft stripper for the IC piping. Pics coming soon.
Old 04-10-2014, 04:17 PM   #11
stiwillie
Member#: 278074
2016 STI Limited
CWP waiting on delivery
Has anyone tried using carb cleaner, works great to remove paint and safe
stiwillie is offline   Reply With Quote
Old 04-12-2014, 01:28 AM   #12
Frmrbob
Member#: 290921
2010 Impreza WRX prm
WR Blue
Well I know mine is powder coated from Perrin
Frmrbob is offline   Reply With Quote
Old 04-12-2014, 04:53 PM   #13
Akrexak
Member#: 100607
2015 DGM STI-His
'14 FXT Touring-Hers
Tread bump level: 2 years.
Congrats.
Akrexak is offline   Reply With Quote
Old 04-12-2014, 09:57 PM   #14
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
2 years, that's not that bad. When people start bumping 8 year old threads, that's getting a little ridiculous.
Cleaning/Removing paint from Intercooler? Mr. Sadface Service & Maintenance 4 03-05-2007 06:43 AM
Removing paint from an intercooler? Mr. Sadface Interior & Exterior Modification 1 08-22-2006 05:12 PM
Removing Paint from Intercooler Fins njskatchmo Interior & Exterior Modification 16 12-28-2005 12:34 PM
How to remove garage paint form my car? Pre-diddy Interior & Exterior Modification 1 03-26-2005 10:37 AM
How to remove painted on stencil from intercooler safetly? tundra Interior & Exterior Modification 11 07-17-2003 12:13 PM
