Old 08-19-2002, 01:54 AM   #1
BADWRX
Member#: 3792
2002 6MT almost GDB
Exclamation Help, clutch WILL NOT DISENGAGE!
What could be wrong. The ford had spring tension on it, and I can drive the car (If I push and jump in and throw it in gear) but I can't stop. The clutch slave is working beautifully. AFU! What could be wrong. If I have tension, that means that the throwout bearing locked in, right? It just doesn't want to disengage!
This is after a transmission install BTW. Help me!
I am taking it to redstar ASAP. It is going to be so expensive!
Andy
BADWRX is offline   Reply With Quote
Old 08-19-2002, 04:36 AM   #2
TerenceT
Member#: 9510
04 FX35
Pearl White
clutch hydrlic fluid leaks?
happened to my old a4 before but then i had no pressure on the clutch pedal and it simply collapeds
btw, if yours doesn't disengage, how do you shift/drive? would you be in neutral? or do you mean it doesn't engage? and you have to power shift every gear?
TerenceT is offline   Reply With Quote
Old 08-19-2002, 05:28 AM   #3
N/A
Member#: 133
TBA TBA
TBA
Well the small return spring might be the reason it doesn't just collapse. Are you sure the throw out bearing and clutch fork are connected? Sometimes if your not careful when you put it back together the fork comes off of the throw out bearing. Pull back the rubber boot and take a look inside with a flashlight and inspection mirror if you have one. Otherwise its possible that the throw out bearing either came off of the fork or never locked in all the way.
Also when reusing the old TB make sure there are no cracks in it. I've seen a couple in the past that the metal tabs that hold it to the fork start to crack and break.
N/A is offline   Reply With Quote
Old 08-19-2002, 06:23 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you have air in your hydrualic system...that or you didn't line the throwout bearing up correctly.
jeremy
Old 08-20-2002, 03:56 AM   #5
dead-eye
Member#: 43
1999 2.5RS no T
RBP
Take it back ASAP. My clutch didn't disengage and like a moron, I just kept jamming the shifter back and forth. I ended up breaking the shifter fork and frying my clutch disk. Cost me a bundle to get it fixed.
dead-eye is offline   Reply With Quote
Clutch WILL NOT BLEED (WRX Slave RS Master) White 2.5rs Transmission (AT/MT) & Driveline 3 05-29-2007 11:28 PM
Parking Brake will not disengage RSCaptain Brakes, Steering & Suspension 7 12-18-2005 08:20 PM
Clutch Will Not Disengage at above 1000 RPMs Sherb Transmission (AT/MT) & Driveline 13 10-28-2005 11:45 PM
I need your help guys. Clutch will not disengage. JjSwee Transmission (AT/MT) & Driveline 11 08-07-2005 01:07 AM
Clutch will not disengage?! dead-eye Transmission (AT/MT) & Driveline 10 09-22-2001 02:27 PM
