Old 03-02-2012, 03:21 AM   #1
curt
Member#: 165657
fast wagon, toyota
4x4, & a supermoto bike
Default I have a question about a Rob Tune for the ej20g
i have a jdm wrx wagon "gf8" ej20g swap into a 97 impreza outback wagon.
since the motor came from a jdm wagon, it is running the 90* TD04 instead of the TD05, and i am running a 3b ecu, which hits a peak of 10 psi and tapers to 6 psi by redline.
Can i use a rob tuned ecu designed for a td05 equipped car? Are the ecu's compatible?
i am running all necessary mods for the rob tune:
catless downpipe and catback
perrin catless uppipe
apexi jdm ej20g hi flow air intake kit
usdm STi yellow injectors in ej25d fuel rails
ej20g STi tmic
basically, my question is.."could i use a rob tuned ecu with this motor, or since i am running the td04, would i not be able to use it"?
thanks in advance,
curtis
curt is offline   Reply With Quote
Old 03-02-2012, 06:13 PM   #2
RawRock
Member#: 284365
1996 STi 555 (1/500)
53c
Not sure, but you can email him at <[email protected]>.
RawRock is offline   Reply With Quote
Old 03-04-2012, 01:50 AM   #3
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
thanks in advance,
curtis
Its a Tuned ECU. Like anything else that tuned...its customized for the application. SO you let him know what you've done to your car and he makes changes to the tune accordingly.
TommyAtomic is offline   Reply With Quote
Old 03-05-2012, 11:08 PM   #4
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
...to a certain extent, it was actually tuned for his car.
i ran it on my car, pretty much the same mods as u curt, and made good power except with a fmic and td05 ran with ~18psi.. never had time to dyno it..
but now i am curious on my new build. hopefully tomorrow it will start up. i will be running robs chip on my engine and not getting a standalone..
i would suggest getting it, its the most affordable for the 20Gs
azn0boi04 is offline   Reply With Quote
Hello, I'm new here and have a question about a sound coming from the engine bay cscx12 Newbies & FAQs 23 07-06-2008 01:09 AM
I have a Rear sway bar, I have a question about the front WRblueX_Guy Brakes, Steering & Suspension 3 03-15-2006 02:41 PM
Question about double din screens for the gurus... thebing Car Audio, Video & Security 5 12-14-2004 09:16 PM
TUning for the ej20g phunkeeHomosapien Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-12-2004 10:56 PM
