Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 05-14-2016, 08:45 PM   #1
edu01jose
Member#: 404638
2005 WRX STI
Default Turbo wheel damage- Risk?
Recently bought this turbo fron a friend. HTA3586
Upon inspection I notice that most fins were damaged with small nicks on the exducer.
Is this something to worry about? Should I get it rebalanced?
Money back?
Change wheel and balance?
edu01jose is offline   Reply With Quote
Old 05-14-2016, 10:51 PM   #2
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
I'd get it fixed its not horrible but it's not good either
Old 05-16-2016, 11:26 AM   #3
websdatacenter
Member#: 420274
No way you should run that, and little off balance and it's a bomb . Get it fixed ( replaced the impeller ) before using again.
websdatacenter is offline   Reply With Quote
Old 05-16-2016, 11:29 AM   #4
websdatacenter
Member#: 420274
Think about it , either somthing went though that turbo to do that or the bearings are wearing and causing shafts play.
Old 05-16-2016, 12:12 PM   #5
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Something went through it look at the unpredictable/uneven pattern. I'd say manifold/up pipe weld slag.
Old 05-16-2016, 12:15 PM   #6
websdatacenter
Member#: 420274
I agree . If it was mine I would ask the seller why he sold it to you in this condition. It's going to be about 400 to get it fixed. When I had turbo city down south in ca rebuild mine it was 450.
Old 05-18-2016, 05:36 PM   #7
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
How's the other wheel?
Hope your friend gave you a very, very, very good deal.
imma_stocker is offline   Reply With Quote
Old 05-25-2016, 11:15 PM   #8
Subie_
Member#: 419354
2007 STI
Crystal gray metallic
Compare the size of the nicks relative to machined portions off the center boss on the exducer - the further out from the center of rotation you remove material, the greater the off-balancing effect it will have... that wheel is 100% beat my friend - I hope you bought that thing dirt cheap.
Up pipe slag at a bare minimum... My ej257 kicked a rod and left a chicken nugget size wad of a piston left in the bore and my exducer looked better than that. My guess is it went through a significant engine failure. I'd be wary of metal shavings in the CHRA... that wheel looks pretty jacked up to me
Will it run? Probably. Will it run long? Probably not... The possibility of costing you up to a shortblock rebuild isn't worth the risk
Subie_ is offline   Reply With Quote
