Old 12-29-2012, 07:59 PM   #251
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Or delete it...
theotherguy is offline   Reply With Quote
Old 12-29-2012, 10:21 PM   #252
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
That would be my vote...just slows your warm up a minute or 2...
aboothman is offline   Reply With Quote
Old 12-30-2012, 05:43 AM   #253
WhatTurboLag?
Member#: 243992
2006 WRX TR
What turbo can I use the 3 inch anti surge cover on? Like only a kinguawa turbo or what?
WhatTurboLag? is offline   Reply With Quote
Old 12-30-2012, 03:28 PM   #254
theotherguy
Member#: 191514
'05 FXT 6spd, 98
The kinugawa cover should fit any other reputable turbo of the same sized wheel, 20g to 20g, 18g to 18g, etc.
Old 12-31-2012, 05:49 AM   #255
WhatTurboLag?
Member#: 243992
2006 WRX TR
That means I wouldn't be able to use the blouch xtr turbosnwith the kinguawa cover because its a Garrett center cartridge I bet
Old 01-01-2013, 05:54 PM   #256
powerls
Member#: 74322
06 STI basic build
TD06SL2 8cm2 20G
alright, I'm taking the jump and buying a new turbo. Can I get some help to make sure that I'm picking the "best" turbo for my '06 STI with 850cc, forged pistons, TGV deletes...yada yada yada
Will a 2.4" inlet turbo fit my perrin turbo inlet pipe? Or should I be looking at the turbos that specifically say "Subaru T518Z 2008 before"
Like seemingly everyone, I'm looking for a quick spool and around 350hp/350tq, should I just get a TD06H 20G, or should I be getting a TD06SL2 20G?
Should I buy an upgraded wastegate actuator? Do I buy this line kit?
What else? Help me pull the trigger on this!
powerls is offline   Reply With Quote
Old 01-01-2013, 11:36 PM   #257
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
My TD06 SL2 made 363 whp, the 2.4" inlet is Subaru std size, unless ur Perrin is the 3" inlet you'll be fine . The Turbo comes w/ a braided SS line. Actuator prolly wouldn't hurt, not sure if it'd help tho
G/L
sense of nature is offline   Reply With Quote
Old 01-02-2013, 12:40 AM   #258
powerls
Member#: 74322
06 STI basic build
TD06SL2 8cm2 20G
so what is the difference between the 2.4 turbo and the "Subaru T518Z 2008 before"? And I don't need to purchase any new lines?
Old 01-02-2013, 12:50 AM   #259
Kirby10
Member#: 300139
2010 STi
Spark Silver
You might also want to look at the Dom 1.5xtr. I have this turbo on my 2010 STi and the powerband is great. I made 370whp on E85 at 6300 ft for altitude. This turbo carries all the way to redline with power through every gear.
Kirby10 is offline   Reply With Quote
Old 01-02-2013, 01:18 AM   #260
powerls
Member#: 74322
06 STI basic build
TD06SL2 8cm2 20G
build on a budget, the dom1.5xtr is almost twice as much
Old 01-02-2013, 02:15 AM   #261
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Originally Posted by V8 GTFO Lesbic WGN View Post
There is pictures of the Kinugawa aka MadDad aka Tomei aka AgencyPower aka GTSpec ELH with uppipe on #168.
I am in the process of finalizing the install Kinugawa ELH & Kinugawa TD06SL2 8cm2 20G, problem is the Foz Oil Cooler is hitting the ELH, too tall, I have to get a WRX/STi cooler to avoid interference.
TS as in twin scroll, not ELH, like the great photos you posted in 207!
Zee Biker is online now   Reply With Quote
Old 01-02-2013, 05:23 AM   #262
jacky599r
Member#: 137631
2006 WRX
Red
Just to check how different would a dom 1.5xtr compare to a kinugawa td06sl2 20g in 10cm. I understand the latter can be upgraded to a billet wheel, but im debating if i should pay extra for the ball bearing
jacky599r is offline   Reply With Quote
Old 01-02-2013, 08:56 AM   #263
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Here's their power chart thing...
I would imagine crank horsepower.
100 PS equals roughly 98.63 horsepower.
Old 01-02-2013, 10:53 AM   #264
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
^good find.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 01-02-2013, 11:04 AM   #265
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
A TD05H 16G is shown as being good for 345 HP.
A TD05H 18G is shown as good for 362 HP.
Most people with a 2.0 (Ej205) with a TD05- EVO III 16g in an 8 sq cm, got close to 290-300 WHP, in an 8 sq cm, which makes it good for 370-380 CHP, on 93 fuel.
So I am thinking to add 25 to the CHP number, as a correction factor.
The TD06SL2 would then take the 16G to 391 CHP and the 18g to 400 CHP, with an EJ205 on 93.
The EJ207 twinscroll took my 16G from 299 to 325 WHP.
I consider that to be from 380 to 405 CHP.
So a TD06SL2 would do 422 CHP or 338 WHP with my compressor.
For my car, the SL2 is good for +13 WHP over the TD05H
Now, to try to figure the difference between a SL2 and a STS.
Edit: I looked some more and the STS is only a different technology applied to the same diameter inducer and exducer turbine. Therefore they have STS TD05H and STS TD06 SL2, so now i feel it's obvious that the power levels are the same as with the classic TD05H and TD06SL2 turbine, which is what I was estimating below.
Look in the EJ207 thread for post 4752, I can't post a link from work.
There, there is a graph for a GTX STS 16G.
To me, the GTX is in line any billet wheel, it takes a 16G into a 18G+ (blouch 16g=39lb/min, 18g=40lb/min, 20g=44lb/min, 16gXT=41lb/min). You can almost consider this as a 20G classic compressor wheel, for the purpose of comparing something close to apples to apples, let's go with 18G.
The guy had a problem with the actuator, has an initial graph both on E85 and on 93, then a final graph on E85 only. If you extrapolate the gains on E85 to 93, you get, for 93:
350 WHP and 364 FtLb, for an EJ207 on 93.
From the graph above, the difference between a 16G and a 18G in a SL2 is 12 CHP, this would be close to 10 WHP.
So, by adding to my estimation above of 338 WHP for a TD06 SL2 16G 10 WHP, a TD06 SL2 18G would be approximatively 348 WHP.
So, the difference between a STS and an SL2 could be estimated as:
SL2 is making the same WHP.
The STS is most likely spooling faster by couple hundred RPM.
The boost levels I am figuring are in the 21-22 PSI.
This is what I think we may see.
Old 01-02-2013, 01:39 PM   #266
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
A 25g is larger than a 60-1? I'm all sorts of confused now.
Old 01-02-2013, 01:46 PM   #267
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
25G compressor wheel = 60.2mm/ 78mm(Ind/exd)
60-1 compressor wheel = 59.5mm/ 76mm(Ind/exd)
Not by much, but the 25G is slightly bigger.
EvileyeZ88 is offline   Reply With Quote
Old 01-03-2013, 04:17 AM   #268
mcganz121
Member#: 138569
2017 STI+B8A4
06STI <- 09WRX <- 06WRX
would it be possible to compare the kinugawa turbos to something more familiar like blouch sizes?
I take it the td06sl2 20g is comparable to a blouch 20gxt while the td06h 20g is more similar to a green/ blouch 2.5?
mcganz121 is offline   Reply With Quote
Old 01-03-2013, 11:03 AM   #269
EvileyeZ88
Member#: 233501
99 outback sport
Blouch XT family of turbos have a billet compressor wheel.
Blouch 20g sizes are technically Mitsubishi, since the TD0xxx family is a Mitsubishi developed turbo.
All "20G" compressor wheels are:
Inducer: 52.56mm
Exducer: 68.01mm
Its the turbine wheels where everything gets confusing as hell.
TD05H. 12 blade 55.8mm/49.1mm
TD06SL2/ 11 blade 61mm/54mm
Green
TD06H 12 blade 67.2mm/58.8mm
TD06H 11 blade 67.2mm/58.8mm
TD06 12 blade 64.3mm/55.92mm
I don't have any exact specs for the Blouch20GXT other then what they put up on their site.
BPT 20gxt/R 56.5mm turbine wheel
Some sites list them as a TD06H but with a turbine wheel that is 56.5mm it is much closer to a standard TD06.
Hopefully that helped a little bit
~Evil
Old 01-03-2013, 11:24 AM   #270
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
Anything from Blouch with "XT" nomenclature indicates billet compressor wheel. All of the XT's are Mitsu based and the XTR ball bearing units are Garret GTXXR cartridges.
So, If comparing Blouch to Kinugawa on a power potential front then you'd need to consider that the standard Kinugawa is not billet compressor equipped.
Basically, with the Kinugawa turbos you can select your compressor wheel according to your power goals, then use the turbine options to select spool/powerband.
So if you wanted a Kinugawa version of a Blouch 20gXT I believe you'd want a TD06H 20G with a billet compressor upgrade. I also have found nothing but conflicting info regarding the true turbine used in the Blouch 20gXT so take that with a grain of salt if you will.
ericz is offline   Reply With Quote
Old 01-04-2013, 04:12 AM   #271
mcganz121
Member#: 138569
2017 STI+B8A4
Thanks for the help... I have a pretty good understanding of spool/power for the majority of the turbo brands; however, the kinugawa line tends to confuse me.
Old 01-06-2013, 10:44 PM   #272
Jelphree
Member#: 48316
Other than price, does anyone know the difference between these two turbos?
http://shopping.kinugawaturbo.com/ki...2-1-1-2-4.aspx
http://shopping.kinugawaturbo.com/ki...1-1-1-1-1.aspx
I sent Kinugawa an email regarding the difference and haven't gotten a response from them yet. I was wondering if anyone has used any of these turbos before. I'm really on the fence on this brand because of the price. I also asked if I could get a billet compressor wheel, but we'll see if they respond.
Jelphree is offline   Reply With Quote
Old 01-06-2013, 11:00 PM   #273
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
The difference is in the compressor covers.
The first link is for a Red/Green older style standard 20g compressor housing.
The second link is for a GReddy T518Z style compressor cover which is a bit more compact.
Compressor covers aside, they are identical.
Also, I've noticed that the Kinugawa website has now been updated with billet options in the drop down menus and the Kamak STS turbos have been added in a new section. I really wish the price on those was a little less optimistic, at that price I'd be buying a Blouch XTR series.
I've been dealing with an intermittent rear o2 issue that has been throwing the ECU into 13.5:1 AFR closed loop cruise. I'm hoping to get a new sensor installed tomorrow and get back with the tuner by the weekend.
Old 01-07-2013, 12:08 AM   #274
Jelphree
Member#: 48316
Are there any advantages/disadvantages between the two compressor housings? I checked the Kinugawa website and I wasn't able to find drop down menus for the billet option. Hopefully I can get a Kinugawa TD06H-20G with a billet wheel and maybe billet actuator. I was looking into the Blouch 20G XT or Dom 1.5 XTR, but the price is holding me back.
Edit: I just received an email from Kinugawa this morning (1/7/2013). You now can upgrade to a billet compressor wheel for the TD06H-20G. Now I might get this turbo.
Old 01-07-2013, 02:22 PM   #275
05EJ25
Member#: 93133
87 Foxbody
red
I have to start car and break motor in and hopefully numbers will be decent.
HOWEVER:
1. I had to modify the compressor housing inlet by cuting a piece out of it to fit past TGV's even with deletes. The inlet length should be cut to half that length in order to be a perfect fit.
2. All braided lines are no go what so ever on my EJ257, no room for them to work, had to use old FP green lines. I even used the Old return for their return spout is too long and was interfering with all brackets. All old lines including oil lines fit fine and like I said just the compressor housing had to be modified on mine to sneak past the TGV's.
Hopefully this turbo works out well. I would love to see them shorten up the inlet housing so it's truly a drop in turbo.
05EJ25 is offline   Reply With Quote
FS : Kinugawa Td05 20G Turbo + Boost Gauge. Fit Subaru thenic123 Engine/Power/Exhaust 15 06-08-2011 08:02 PM
VF39 vs HTA68 vs Blouch TD0518G 8 cm dmcutter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 103 03-11-2010 02:41 PM
NEW 1 Bar / 14.5PSI Blouch Turbo Wastegate Actuator NEW 1 Bar / 14.5PSI Blouch Turbo dexterous Engine/Power/Exhaust 6 02-14-2010 08:55 PM
Blouch Turbo Budget Series Turbos Blouchturbo Engine/Power/Exhaust 18 06-05-2009 05:07 PM
fullrace GT3076 1.5 Scroll vs Blouch DOM III vs FullRace Twinscroll GT35R azn_ryder02 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 58 04-06-2009 11:29 PM
