Old 01-07-2013, 02:13 PM   #276
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
Which turbo and what compressor housing? Looks like the bigger Red/Green style.
ericz is offline   Reply With Quote
Old 01-07-2013, 04:35 PM   #277
powerls
Member#: 74322
06 STI basic build
TD06SL2 8cm2 20G
Originally Posted by Jelphree View Post
Other than price, does anyone know the difference between these two turbos?
http://shopping.kinugawaturbo.com/ki...2-1-1-2-4.aspx
http://shopping.kinugawaturbo.com/ki...1-1-1-1-1.aspx
I sent Kinugawa an email regarding the difference and haven't gotten a response from them yet. I was wondering if anyone has used any of these turbos before. I'm really on the fence on this brand because of the price. I also asked if I could get a billet compressor wheel, but we'll see if they respond.
T518z turbo's have a 2.25" housing, the 2.4" turbo's obviously have a 2.4" housing
powerls is offline   Reply With Quote
Old 01-07-2013, 06:07 PM   #278
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Im loving my legacy style kinugawa td06sl2 20g 8cm2 2.4 inlet on my 2011 fxt on e85. It spools fast i see 23 psi by 3800 to 4000 rpm depending on the gear and it pulls hard to redline. I wouldnt hesitate to get another kinugawa turbo its great quality and had no install problems what so ever. The only problem is i almost maxed out my fuel system because it flows so much for my id1000 and 300lph pump im hoping a hardwire of the pump will lower my idc a little.
nate_fisher is offline   Reply With Quote
Old 01-07-2013, 07:07 PM   #279
2011boostdwrx
Member#: 263470
Are you using top mount and do you have the STS Kamak wheel on yours? I am waiting to pick up my 2011 with a full built motor, 6 spd trans swap full supports mods, FMIC and Leggy style Kamak 20 GTX billet with the 9-blade STS HS wheel!
2011boostdwrx is offline   Reply With Quote
Old 01-07-2013, 08:32 PM   #280
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
https://www.youtube.com/watch?v=7kHN...e_gdata_player
Just can't get over how nice the anti surge housing sounds.
wrxsubiemod is offline   Reply With Quote
Old 01-08-2013, 02:17 AM   #281
Jelphree
Member#: 48316
To those that picked up the TD06SL2-20G, did you ever look into the TD06H-20G? I was under the impression that a billet compressor wheel on a TD06H-20G would minimize some lag, while holding up on the top-end.
Jelphree is offline   Reply With Quote
Old 01-08-2013, 08:50 AM   #282
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Why sure we have, I dont understand your point this has been covered time and time again... sure thats obvious. Also if you put a billet comp wheel it would spool fasted too.
rexworx is online now   Reply With Quote
Old 01-08-2013, 11:31 AM   #283
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
^Jelphree point is valid, seems they just added the billet wheel option for 2013 on the TD06H not TD06SL2, bought my TD06SL2 in Nov 2012 and I don't remember seeing that option available at the time on the TD06H. Personally even the option was available last year I would have still chosen the TD06SL2 since this smaller turbine wheel provides faster spool (54/61mm) vs TD06H (58/67mm), although the billet TD06H 58/67mm may have less inertia than the smaller cast TD06SL2 54/61mm??
http://shopping.kinugawaturbo.com/ki...2-1-1-1-1.aspx
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 01-08-2013, 11:35 AM   #284
elbertmurphy
Member#: 268256
2005 STI
how about a PTE turbo? you can get them on builtej for $900. better than risking it...
elbertmurphy is offline   Reply With Quote
Old 01-08-2013, 11:45 AM   #285
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
When PTE releases a stock location, bolt on option for $900 please post it in this thread.
Also, I ordered my billet wheel before it was listed on the site, I simply asked since I knew there was a Kamak connection. I'd wager you can get a billet wheel in damn near any standard size turbo they offer.
I don't see a billet wheel TD06H spooling anything like a TD06SL2 with a cast wheel, they are just too different for a lightweight comp wheel to even them out.
Old 01-08-2013, 11:49 AM   #286
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^you mean the TD06SL2 will spool faster than a larger but lighter billet TD06H wheel, right?
Old 01-08-2013, 12:23 PM   #287
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
Yes, of course, without anything other than this old noodle's logic to back it up. The difference in the TD06SL2 and TD06H turbines IMO is enough to negate any real benefit of the billet wheel assuming expectations are that a billet "H" will spool like a standard "SL2". Unless of course, you're only comparing compressors and not entire CHRAs. As far as comparing compressors only? Not sure as there's more to the equation than just "scale mass" as this is a rotating part. Weight distribution throughout the compressor and mass leverage on the turbine shaft will come into effect and I'm not engineering degree'd enough to give any solid input on that note.
Old 01-08-2013, 01:38 PM   #288
05EJ25
Member#: 93133
87 Foxbody
red
25g, 3" inlet.
05EJ25 is offline   Reply With Quote
Old 01-08-2013, 02:16 PM   #289
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
That makes sense. That's a large cover.
Old 01-08-2013, 02:42 PM   #290
05EJ25
Member#: 93133
87 Foxbody
red
Yeah, pretty big. Little smaller then 35r and bigger then red/30r
Old 01-08-2013, 02:54 PM   #291
UnknownAlly
Member#: 277330
2004 WRX
I'm a total noob. Do I order 7cm or 8cm? I dun get their website
Will this work on an 04 wrx?
UnknownAlly is offline   Reply With Quote
Old 01-08-2013, 03:01 PM   #292
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
Which turbo are you interested in? What are your power goals?
Yes, they have multiple turbos that will fit an 04 WRX.
Old 01-08-2013, 03:10 PM   #293
UnknownAlly
Member#: 277330
2004 WRX
I want an 18g. Power goals: no preference. I just want a conservative tune, not pushing too hard. Something that wouldn't break my transmission as long as I baby it.
I just want something more than a VF39.
Old 01-08-2013, 03:15 PM   #294
UnknownAlly
Member#: 277330
2004 WRX
The Kinugawa 16g and 18g are the same price, so I figure I might as well get the 18g.
Old 01-08-2013, 07:48 PM   #295
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
I ordered a td06H4 11 blade 20g chra from Kinugawa today. I'm going to stick it into a 7cm^2 turbine housing and ewg, see how it spools then try it in an 8cm^2 and ewg to see which works better. This will go into my youngest son's 2012 STI. I wouldn't normally even try a 7cm on a 2.5 but a friend is saying that it'll be so good that I won't even try the 8cm.
We'll see, I've tried the normal td06h 12 blade 20g before in both turbine housings with IWG and didn't like the numb feeling from that big wheel. Hope he's right.
theotherguy is offline   Reply With Quote
Old 01-09-2013, 09:51 AM   #296
nate_fisher
Member#: 270482
2011 turbotek fxt
Yes im on a perrin tmic and a 4eat auto transmission. No i dont have the upgraded wheel i didnt even know it was an option or it wasnt when i bought it but it has the upgraded kamak thrust bearing in it and i looked and i dont think i would justify an extra $900 for the billet 9 blade wheel upgrade on the kamak unit. It is a real nice turbo and for $830 shipped to my door i would say its a hell of a deal.
Old 01-09-2013, 01:12 PM   #297
powerls
Member#: 74322
06 STI basic build
TD06SL2 8cm2 20G
Did your friend explain to you his line of reasoning?
Old 01-09-2013, 01:23 PM   #298
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
http://shopping.kinugawaturbo.com/ki...3-2-1-1-2.aspx
7 or 8 cm hotside.
Zee Biker is offline   Reply With Quote
Old 01-09-2013, 09:08 PM   #299
theotherguy
Member#: 191514
'05 FXT 6spd, 98
He runs this set up tuned by a well known NW tuner. The tuner says it's one of his favorite dd set ups. We'll see, I have both turbine housings so it'll be interesting to see the results. I'm also hoping the newer 11 blade will be a bit more responsive than the older 12 blade. I'd have run something else but it ain't my car.
Old 01-09-2013, 10:47 PM   #300
powerls
Member#: 74322
06 STI basic build
TD06SL2 8cm2 20G
Ok, taking the jump almost any day now. I still need help though. '06 STI forged pistons, 850cc inj, stock top mount. I want the car to be as peppy as possible while still having good top end.
Turbocharger 2.4" Cover SUBARU STI TD06SL2 20G w/ 7cm housing and billet wheel upgrade????
Thoughts?
FS : Kinugawa Td05 20G Turbo + Boost Gauge. Fit Subaru thenic123 Engine/Power/Exhaust 15 06-08-2011 07:02 PM
VF39 vs HTA68 vs Blouch TD0518G 8 cm dmcutter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 103 03-11-2010 01:41 PM
NEW 1 Bar / 14.5PSI Blouch Turbo Wastegate Actuator NEW 1 Bar / 14.5PSI Blouch Turbo dexterous Engine/Power/Exhaust 6 02-14-2010 07:55 PM
Blouch Turbo Budget Series Turbos Blouchturbo Engine/Power/Exhaust 18 06-05-2009 04:07 PM
fullrace GT3076 1.5 Scroll vs Blouch DOM III vs FullRace Twinscroll GT35R azn_ryder02 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 58 04-06-2009 10:29 PM
