Old 02-14-2013, 12:37 PM   #376
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
We have to start doing pulls with Virtual Dyno to compare, I am getting close to finish the install of the 20G SL2 with a GS EBCS 3-way and a 3" TBE. Will be etuned on 93 @+/- 20psi.
Just used a calculator and indeed I may be small on the injectors, minimum is 850cc for a 350WHP engine.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 02-14-2013, 01:13 PM   #377
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
Originally Posted by nate_fisher View Post
A 3 port will get you better spool and better control for around $100 but you would have to retune for it again. I maxed out my id1000 and 300lph pump on the same turbo on e85 around 23psi so i would think 750cc would be cutting it close on pump gas. I will be hardwiring the pump to lower them a bit with the dw hard wire kit which is something you could do to stretch out the 7500cc a bit.
curious what kind of power did u push out?
Thran is offline   Reply With Quote
Old 02-14-2013, 05:15 PM   #378
powerls
Member#: 74322
06 STI basic build
TD06SL2 8cm2 20G
Originally Posted by abrumlev View Post
Yeah sounds like you're missing a couple parts that would really make a significant difference. Grab an EBCS and 3" catback, you should see a good bit of pickup on spool/boost control up top. I really want to know what this turbo does as I'm strongly considering picking one up to replace my og fp green.
Yeah, it will have to wait till I save up the loot. I want to install exhaust, TMIC and EBCS all at the same time to save $$$ on tunes
powerls is offline   Reply With Quote
Old 02-14-2013, 06:44 PM   #379
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Virtual dyno jet said 375whp on my dd map but should be around 400whp on my high boost/ timing track map this summer. I have a auto trans so the torque number is going to be high due to the converter and reaches over 450wtq.
2011 fxt 4eat auto
td06sl2 20g 8cm
IPR tmic (perrin replica)
300lph pump
id1000cc
aem cai and perrin inlet
catless tbe
grimmspeed 3 port ebcs
forge bpv
cobb ap tuned by [email protected]
I am running E85 at 23psi tapering to 20 at redline. There is other stuff but this is the most of it, also it is wrapped and blanketed and heat taped on everything. I love this turbo and for the half the price of others out there it is a great buy i will be running these turbos for a while to come i think.
nate_fisher is offline   Reply With Quote
Old 02-18-2013, 02:04 AM   #380
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
To aid in the spool up issues, you really want an upgraded wastegate actuator. Kinugawa has them along with springs.
A 3 port ran in blocking mode helps as well.
Also, past 10 PSI, the stock BPV starts to open up killing spool (the car is designed for 14ish PSI max. When I added my TXS Type H BOV, my spool up on my 20G dropped 750 RPMS in all gears. People who tell you, oh the stock BPV is fine until XX HP are not thinking about spool and area under the curve. This by far was my best spool up mod and I am running it at the lowest setting.
I am trading my CHRA again for the billet 25GTX compressor wheel coupled with a different turbine wheel (not the SL2 wheel).
Plus wow, lots of discussion since I last checked.
gabedude is offline   Reply With Quote
Old 02-18-2013, 02:24 AM   #381
gabedude
Member#: 10108
07 STI
Originally Posted by powerls View Post
sorry for the poor photo quality. I'm certainly happy with the 349HP/349Trq figures, I do wish that it would have spooled a bit faster. Hill at Agile mentioned that I'm currently limited by my stock IC and exhaust.
Dynapack Dyno
EJ257
STI TD06SL2 20G 8cm housing w/IWG @19psi
Custom AP Tune
850cc
3in no cat DP
stock STI exhaust
stock STI TMIC
TGV Deletes
Forged Pistons
Stock STI Rods
Perrin Inlet Hose
Crawford AOS
Yes, you are severely limiting this turbo with the stock cbe and TMIC. This turbo can make 450 WTQ and 400 WHP on 93 octane with supporting mods (I have a ton of supporting mods and can almost hit 400 WHP on 93 octane with my old worn out 20G). Get a full 3 inch turboback and a FMIC (trust me, the FMIC does not add lag) to put you into the 400's. I went through the same thing with my Blouch TD05 20G. I could barely touch 400 WHP using the stock TMIC with methanol injection. A few more mods later with a good FMIC and I hit 478 ft/lb 438 whp on E85. By then I was clutch limited, so time for more upgrades and the larger turbo.
Old 02-18-2013, 12:41 PM   #382
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Does anyone have a current phone# for bruce @ Kinugawa? I have a few questions for him and wanted to speak too him in person...
Thanks,
rexworx is offline   Reply With Quote
Old 02-18-2013, 06:24 PM   #383
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
2011 fxt 4eat auto
td06sl2 20g 8cm
300lph pump
id1000cc
catless tbe
forge bpv
Very nice bro! man i have a dom 2.5xtr and really making me want to switch it out for something :P
Old 02-18-2013, 08:45 PM   #384
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
That's a nice turbo.
wrxsubiemod is offline   Reply With Quote
Old 02-18-2013, 11:53 PM   #385
crazymoet
Member#: 342418
You want to change it out. dom 2.5xtr is a brilliant turbo. 400whp+(with meth). Full boost on the 2.5l around 3000rpm.
crazymoet is offline   Reply With Quote
Old 02-19-2013, 12:04 AM   #386
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
I think the Kinugawas are great budget turbos but I'd keep the 2.5xtr.
theotherguy is offline   Reply With Quote
Old 02-19-2013, 10:37 AM   #387
nate_fisher
Member#: 270482
2011 turbotek fxt
^^ This my friends 2012 sti made 490whp on the 2.5xtr on e85 at 26psi it is a bad ass turbo.
Old 02-19-2013, 03:26 PM   #388
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
I havent really gotten to push the turbo yet, its on my wrx ,stock 2.0. Got the turbo when i blew my 18g and waiting when i build the 2.1L i can really full push this turbo
Thanks guys for the great feedback!
Old 02-19-2013, 06:24 PM   #389
powerls
Member#: 74322
06 STI basic build
TD06SL2 8cm2 20G
I actually received the upgraded wastegate actuator w/o ordering it. I believe that all shipments now are including those, since I saw someone say the same thing earlier in the thread
Old 02-20-2013, 11:38 AM   #390
nate_fisher
Member#: 270482
2011 turbotek fxt
Same here i recieved the billet upgraded actuator as well with out asking which was nice.
Old 02-20-2013, 11:51 AM   #391
jacky599r
Member#: 137631
2006 WRX
Red
What difference am i looking at between twinscroll TD06SL2 60-1 10 cm non billet to TD06SL2 20G 10cm billet wheel. Understand both are completely different turbos but i wanna know what kinda trade off considering i want a bigger turbo but 60-1 doesnt come with the option to upgrade.
jacky599r is offline   Reply With Quote
Old 02-20-2013, 12:04 PM   #392
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Choose a turbo to meet your requirements or goals. If you need help choosing I can lend an opinion
Old 02-21-2013, 07:48 AM   #393
jacky599r
Member#: 137631
2006 WRX
Red
i need something close to DOM2.5XTR Twinscroll performance. To be fair, i am planning to run twinscroll. I am trying to use the best out of my money.
For the money of a single DOM 2.5XTR TS, i may be able to get a TS06SL2 20G 10CM (upgrade billet wheel) or 60-1 and have upgraded 264 cams or even meth to go along with it.
Old 02-21-2013, 09:07 AM   #394
Cuda528
Member#: 336195
2010 STI hatch
^^ This is my question as well, the billet 60-1 wheel looks like a good option for me.
Cuda528 is offline   Reply With Quote
Old 02-21-2013, 09:14 AM   #395
Boostedbob
Member#: 336241
08 Sti
OPB
So kinagawa is sending a better wastegate with these turbo's? When I was at there site the only option I could see to upgrade was the billet wheel. For the sl2 td06 20g
Boostedbob is offline   Reply With Quote
Old 02-21-2013, 09:55 AM   #396
skets
Member#: 170698
2003 WRX V-Limited
If you email them they will quote you for the upgraded wastegate.
skets is offline   Reply With Quote
Old 02-21-2013, 10:21 AM   #397
Boostedbob
Member#: 336241
08 Sti
OPB
Thanks, yeah was going to email then yesterday but there comment box only allows 100charecters just going to send them a email through my ISP. Thanks guys!
Old 02-21-2013, 11:02 AM   #398
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
The 2.5xtr is a gtx3071 crammed into a small housing restricting it to 49lb/min. If your looking for same power potential I would suggest the 60-1. You should get the same power out of the twin scroll at possibly lower boost.
Old 02-21-2013, 01:05 PM   #399
jacky599r
Member#: 137631
2006 WRX
Red
Not just concerned with power, but trade off in spool. Besides, 2.5 is a billet wheel as opposed to cast in the 60-1 offered by kinugawa; there's without mentioned the former is a bb turbo
Old 02-21-2013, 01:57 PM   #400
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Have someone build you a twin scroll gtx3071r. You'll be asking too much of a 20g if your looking for fast spool and similar power, unless you plan on high boost and race gas. Billet version of course
FS : Kinugawa Td05 20G Turbo + Boost Gauge. Fit Subaru thenic123 Engine/Power/Exhaust 15 06-08-2011 07:02 PM
VF39 vs HTA68 vs Blouch TD0518G 8 cm dmcutter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 103 03-11-2010 01:41 PM
NEW 1 Bar / 14.5PSI Blouch Turbo Wastegate Actuator NEW 1 Bar / 14.5PSI Blouch Turbo dexterous Engine/Power/Exhaust 6 02-14-2010 07:55 PM
Blouch Turbo Budget Series Turbos Blouchturbo Engine/Power/Exhaust 18 06-05-2009 04:07 PM
fullrace GT3076 1.5 Scroll vs Blouch DOM III vs FullRace Twinscroll GT35R azn_ryder02 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 58 04-06-2009 10:29 PM
