Old 03-02-2012, 08:56 AM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default 2013 RS5 Driven
We've admittedly had our share of issues with the approach Audi takes with its RS cars. In theory, "RS" represents the German tradition of heavy-breathing RennSport driving – essentially for cars that can really race. What we have found most often, however, is that the RS more readily approximates a branding exercise that comes sort of close to smacking us upside the head with thrills, but falls short in key ways – especially when Audi has brought us to a track, eagerly awaiting our feedback.
RS models tend to weigh a lot, and the company's Quattro obsession can harm handling while cornering – and it costs a pretty pickle or two to boot. The RS model that finally got us closest to Renn Sportiness was the TT RS (a car that's finally hitting the U.S., having already been savaging European roads since 2009). Then we waited until Spring 2010 and the RS5 that promised us things – wonderful things. The A5 upon which it is based was possessed of the near-perfect rear-biased sports coupe proportions, and the S5 it spawned was a pretty solid piece of work, too, so we were excited to drive it.
After our first drive at the Ascari circuit in southern Spain, we were even a little more encouraged by the RS5 than we had been after our previous track session in the TT RS. Subsequent high-spirited comparison drives on warm and dry surfaces, however, revealed the original 444-horsepower RS5 as no match for the sheer dynamic satisfaction of the Mercedes-Benz C63 AMG coupe and BMW M3 coupe. The RS5, even with its improved lighter and quicker-reacting Quattro, simply had too hard a time resisting prodigious amounts of understeer. We were left begging for effortless and soul-stirring oversteer whenever exactly that would have been called for. Everything else on the RS5 is so good that this one bit just made us whiney.
There is a trade-off, though, and this new drive of the slightly updated 2013 RS5 in wintry white central Sweden brought this to bear more clearly than any other test could. When the going gets tougher and the drive surface is no longer warm and dry – heck, not even asphalt or earthbound – there may be no other sporting coupe we'd rather be driving. If we hit wet and oily pavement in rainy weather, or perhaps ice on a Swedish lake, we want the RS5 wrapped around us if we still want to have a fast, fun ride.
It's just this sort of opportunity that Audi recently afforded us, too. With the RS5's ESP Sport thresholds in place, Audi Drive Select settings all in Dynamic mode and special 19-inch Finnish studded winter tires at the corners, we were set free on a circuit mapped atop a frozen lake at the Molanda test center near Jδrpen. And before you berate our evaluation as cheating due to the studded tires, think again – being thusly shod is pretty much law of the land here in the far north. If you are caught having caused – inadvertently or otherwise – any sort of traffic mishap and you don't have proper snow shoes on your wheels, the legal repercussions here are more severe than you might imagine.
After first hauling butt over this same circuit in a slightly dicier A1 Quattro with its small wheelbase, 252-horsepower and 258 pound-feet of torque, it was time for a turn at the wheel of the RS5, and immediately, the graceful looking two-door was right at home. We've done ice driving circuits in many cars, including an M3, but this was by far the quickest we'd ever settled down and felt completely at ease with the weight-shift + throttle play + steering angle drift ballet required of serious winter driving.
The 4.2-liter naturally aspirated FSI V8 was clearly enamored of this exercise, and it was under these conditions where the quick reactions of the new crown-gear Quattro system were rendered crystal sharp. Regarding feathery throttle work, in Dynamic mode, the linkage's response is perfectly brisk, to the point where less is truly more. At times when we'd shifted to opposite lock too soon for the next apex cone (and the snow bank behind it), we had the satisfaction of flooring it in order to broaden the arc of our ice drift, and the RS5's bigmouth dual Boysen sport exhaust obliged with a satisfying roar that echoed across the lake.
Then there were the 15-inch carbon composite brake discs up front and new-for-2013 "wave" design steel brakes in back, though braking is the last thing you do out here in slippy drift mode. If ever we felt the need, a tap was all that served the purpose to peel off a little lateral momentum from this hurtling 3,950-pounder. Then it was back on the throttle good and hard to enjoy the 317 pound-feet of torque in its 4,000-to-6,000 rpm sweet spot.
The RS5's most tangible tech change for the 2013 model year is the ditching of a hydraulic power assist steering in favor of an electro-mechanical setup. This is happening all over the European landscape these days due to the need for improved fuel efficiency. While these systems once felt universally synthetic and wonky, they have become better and better through thorough testing. Nowadays, it's not taboo to mention electrically assisted steering when speaking of cutting-edge sports cars. In Sweden under these unusual conditions, the easy action of the RS5's new electric power steering came across as perfectly suited to the drive characteristics on the slide-happy circuit.
Paradoxically, the RS5's 59-percent front, 41-percent rear weight distribution was its biggest asset on our drive. While the distribution of heft is the car's main bugbear on warm, clear pavement, the car's front weight bias proved to be an asset on the frigid Swedish circuit. The 19-inch studded Lappi Winter tires – 245/35 R19 – are owed some credit, certainly, but the Audi's naturally heavy nose and 108.3-inch wheelbase made easy work of making sure that the tail came around at just the right cadence. The weight-shift dance was an easy one to learn in this car.
Final changes worth a brief mention are the same exterior touches incorporated on the revamped 2013 A5 and S5 models: the new face, single-frame grille with folded top corners, and squintier Clint Eastwood headlights and taillights that are all-LED units. The best news of all? Whereas the pre-facelift RS5 wasn't sold in North America, the updated model should appear in U.S. dealerships by the end of March, with a price tag of around $70,000.
It was good to finally come away delighted with an RS model from our Audi pals. It's just a shame that not everyone gets to test this RS5 coupe's chemistry out here in the ice and snow. Maybe Audi's engineers should strive to make the next-generation RS5 dramatically more rear-biased and not so self-neutralizing in its dynamics. That way, owners on dry pavement can get as excited as we did driving up near Santa's toyshop in RennSport Wonderland.
http://www.autoblog.com/2012/03/01/2...-drive-review/
Old 03-02-2012, 10:56 AM   #2
manticus
Member#: 162857
4000 lbs... Wow. There's a weight limit to what I enjoy driving, and it sits at around 3500 lbs. As I drive more and more cars, that limit is dropping more than it's increasing.
manticus is offline   Reply With Quote
Old 03-02-2012, 11:47 AM   #3
delongedoug
Member#: 124113
and beyond!
It's a good looking car but I never thought Audi spiced up their RS models enough visually. Call me a ricer, but if I'm spending $70k on the RS model, it better look like I spent $70k on the RS model.
delongedoug is offline   Reply With Quote
Old 03-02-2012, 12:51 PM   #4
HipToBeSquare
Member#: 119958
1992 SVX LS-L
Such a gorgeous car, but so expensive, and so heavy.
But it is pretty much everything you can throw at the car, tech-wise.
But I have to wonder, even being the 2+2 coupe fan that I am... Between an RS4 sedan or Avant wagon, and the R8 4.2 mid-engined sports car... is there really a demand for this 2+2 coupe at that high price, where buyers can own multiple cars for multiple roles?
Frankly, I badly wish that all this car's tech, could be applied to an R8 4.2 S-line.
The 450hp red-head version of the engine in the RS5... The dual-clutch DSG gearbox... the torque-vectoring rear diff... should be applied to the R8 V8, which only has 420-430hp, and Lambo's single-clutch automated gearbox that is not as good... and without torque vectoring.
Apply that tech to the R8 4.2, and dress it like a 5.2/GT with the flared side blades, the fewer-strake intake and extractor vents, the GT's black tail lights, and the mesh front grille... like an under-dog to the 5.2 R8 GT... that would be about ideal to me. Supercharged would be icing on the cake, but not essential to the enjoyment of the car. And it would be lighter and run cooler than the 5.2 V10.
HipToBeSquare is offline   Reply With Quote
Old 03-02-2012, 01:16 PM   #5
E. Nick
Member#: 8489
1978 Plymouth Volare
Maroon / White Vinyl
R8 is the only Audi without pig-understeer. How about that trait make it down the line instead of just more LED's.
E. Nick is offline   Reply With Quote
Old 03-02-2012, 01:21 PM   #6
teiva-boy
Member#: 22825
What does an equivalent M3/M5 weigh? Or an AMG?
The weight seems reasonable to me. This isn't a lite weight racer, this is a luxury car with balls. As such all the gadgetry and comfort included has its penalty.
teiva-boy is offline   Reply With Quote
Old 03-02-2012, 02:19 PM   #7
delongedoug
Member#: 124113
and beyond!
http://lmgtfy.com/?q=e92+m3+weight
~3,700
Old 03-02-2012, 02:26 PM   #8
edkwon
Member#: 453
2014 Audi S4 B8
2016 Porsche Cayman GTS
Why are you lumping the M3 and M5 together? Apples & oranges, anyway to answer your question, the E90 M3 coupe/sedan both weigh about 300 lbs less than the RS5, thats not insignificant.
The AMG C63 is definitely heavier and close to the RS5 in weight, and its not known for nimble grace, definitely more for brutal straight line power.
edkwon is offline   Reply With Quote
Old 03-03-2012, 08:20 PM   #9
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
those a5 body styles are soo nice. i was looking at some audis today at a local dealer. if i only could afford one!
424wrx is offline   Reply With Quote
Old 03-04-2012, 04:02 PM   #10
stirob
Member#: 93631
2014 CTS-V
Opulent Blue Mtallic
For those complaining about weight I seriously doubt Audi was aiming for the track crowd when building this car.
stirob is offline   Reply With Quote
Old 03-04-2012, 05:22 PM   #11
LGT_2005
Member#: 303277
That is just a fantastic looking interior. The engine bay is very attractive as well. But the rest of the car just doesn't match as much imo. ITs not mean enough.
LGT_2005 is offline   Reply With Quote
Old 03-04-2012, 05:55 PM   #12
WRXHillClimb
Member#: 206907
2014 EvoX GSR
M3>RS anything? No surprise.
WRXHillClimb is offline   Reply With Quote
Old 03-05-2012, 05:57 AM   #13
shikataganai
Member#: 92634
'07 Land Cruiser
'12 RAV4 EV
So the carbon brakes are just to impress one's drinking buddies? RS should imply something other than bling...
shikataganai is offline   Reply With Quote
Old 03-05-2012, 11:47 AM   #14
teiva-boy
Member#: 22825
Marketing probably plays more than you think vs performance.
Old 03-06-2012, 06:35 AM   #15
stirob
Member#: 93631
2014 CTS-V
Yes. Audis market is not the track junkie even though this car is probably more than capable of turning some good lap times. The bling in the RS is essential to please there customer base.
Old 03-08-2012, 12:18 AM   #16
CreoWRX
Member#: 19024
2016 F80 M3
Alpine White
The understeer in my S4 is quite minimal with the sports rear diff option and in full dynamic mode.
-Mike-
CreoWRX is offline   Reply With Quote
Audi RS5 review/Driven/Compared AVANTI R5 Non-Subaru News & Rumors 12 11-04-2010 01:25 PM
Whats a good battery for a "weekend driven only" or rarely driven car? Psybin Mid Atlantic Impreza Club -- MAIC 11 04-26-2010 09:05 AM
Is it possible to convert a subaru from belt driven to chain driven? DoctorNick Built Motor Discussion 10 03-12-2007 01:18 AM
Wheel Advice. Konig-tantrum & Enkie- Rs5 Jasno999 Brakes, Steering & Suspension 3 11-07-2001 07:27 PM
Enkei RS5 weight? MichiganRS Brakes, Steering & Suspension 0 05-25-2001 12:03 AM
