Old 02-13-2013, 11:42 AM   #226
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by nels0300 View Post
That is how my car behaves as well. I can still do stupid stuff like spin around in parking lots and kick the back end out around corners, so I wonder what are people doing where they find VDC so intrusive that they'd want to sell the car.
And you can drift it if you don't get crazy with the steering.
Old 02-20-2013, 07:10 PM   #227
ans2k
Member#: 315631
2012 Impreza Sport
ans2k is offline   Reply With Quote
Old 02-23-2013, 10:58 AM   #228
79letour
Member#: 302570
2013 XV
DGM!
I've found that switching off the bitch switch is sufficient for backroads fun. Would a VDC switch right next to the TC switch be more fun? F$$k yes!
But yeah, turn off the tc and go to some grassy field, anf you can do crazy fun donuts with ease.
79letour is offline   Reply With Quote
Old 03-25-2013, 11:15 PM   #229
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
We found a solution. A real solution. There is a switch under the e-brake lever, that engages the stability control when the handbrake is off, and disables it when the lever is pulled. Obviously, this doesn't solve anything, but if anyone can design a collar offset or something to prop the handbrake lever up slightly, it will keep the stability control off, and I mean completely off. Simple, practical and easy to engineer something for. Unfortunately when the handbrake is pulled up the first retention clip already engages the brakes, but that can probably be avoided with propping the lever up slightly and/or engineering a bypass switch. The information is in these two threads :
http://forums.nasioc.com/forums/show...31206&page=684
Pages: 683-684
http://forums.nasioc.com/forums/show....php?t=2453881
First post.
Just thought I'd let people know the new developments people have discovered with respect to the ESC system.
Dirt Bringer is offline   Reply With Quote
Old 03-26-2013, 03:17 AM   #230
mtdewroo
Member#: 323635
2012 Impreza 5dr Pre
Metallic Gray
I found that if i pull out the bottom far right 7.5 amp fuse under the dash board... the dash board lights up like a x mass tree...ABS,CHECK ENGINE, CRUISE LIGHT FLASHING, HILL AST OFF, TRAC OFF, STAB LIGHT ON, AND YES IT KILLS THE ELECTRIC POWER STEERING. But if you put the fuze back in the CHECK ENGING LIGHT, CRUISE LIGHT FLASHING, AND STABILITY LIGHT STAYS ON. YOU get steering and abs and hill asst back. the car is drivable. Mine is a 5 speed 2012 impreza premium and in my field i can now get it to go sideways at 50mph in third gear in the snow. At first for just a sec the abs try's to correct you then it just gives up. But once I am done playing i have to flash the computer to re-set check engine light, cruise, and stability control. PLAY AT YOUR OWN RISK!!!! It makes me smile now!
mtdewroo is offline   Reply With Quote
Old 03-26-2013, 08:41 AM   #231
Paradis
Member#: 334647
2012 POS Impreza
Nice !
Paradis is offline   Reply With Quote
Old 03-26-2013, 09:14 AM   #232
Dirt Bringer
Member#: 340297
Ice Silver
Originally Posted by Paradis View Post
That's the VDC fuse
Doesn't work for me
I've tried many times
Can't wait to try this !!
Just be aware that pulling the lever to it's first click point will make the rear brakes drag slightly. This is both dangerous in slippery conditions and bad for the car.
Old 03-26-2013, 10:34 AM   #233
KC
Member#: 442
16 SS
00 S2000
You may not even have to do it to a full click. If I just graze the ebrake in my XV, the bake light lights up. We're talking about something less than a 1/2cm of pull, but well before the 1st click.
--kC
KC is offline   Reply With Quote
Old 03-26-2013, 03:28 PM   #234
RJSoobs251
Member#: 345206
2012 Impreza 2.0 Lim
I am also interested in this...would be awesome to find a way around the stability control for more reasons than just wanting to do a few donuts in the parking lot
RJSoobs251 is offline   Reply With Quote
Old 03-26-2013, 05:51 PM   #235
Rememo
Member#: 340728
2013 Impreza 5-spd
Are the guys who have tried this REALLY sure it works? I can't find a link between the parking brake and the VDC system.
VDC wiring:
http://sdrv.ms/14tz4Nf
Parking brake switch wiring:
http://sdrv.ms/14tyQpb
Rememo is offline   Reply With Quote
Old 03-26-2013, 07:58 PM   #236
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I would be interested to try it, but our snow is rapidly dissapearing
Old 03-27-2013, 11:26 AM   #237
Dirt Bringer
Member#: 340297
Ice Silver
VDC wiring:
Yeah well I assume both are linked to the computer where everything communicates. A few people have tested this (check the thread I posted) and stated that it does in fact work. I can't attest to this myself (yet), but at this point it does appear to work.
Old 03-27-2013, 01:27 PM   #238
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Myth busted, does not work watched a steady brake light and low traction light flash
Old 03-27-2013, 02:18 PM   #239
Dirt Bringer
Member#: 340297
Ice Silver
This conflicts with two previous reports suggesting it does work. Things are getting strange here.
Old 03-27-2013, 02:23 PM   #240
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I propped the lever up below first click. Brake light on. Found a snow covered gravel lot, attempted figure 8s, denied. I tried swerving aggressively enough that my friend who is a better driver and not easily scared had to grab the oh **** handle. Upon losing traction you could hear the abs going trying to straighten the car. We both saw the brake light on with the low traction light flashing as we heard abs working, attempted to continue for a few seconds after we saw both lights (and the low traction one flashing) but it was hopeless. tucked tail and drove home.
I know that if you don't turn the wheel vdc will not limit your fun, verified again before attempting this.
I think the only way to do this is trick the computer into not seeing the steering input
edit:
i reread the post where someone said this worked (only saw 1 confirmation btw) and it sounds like they have a CVT and when sliding around the corners i bet they weren't on the gas. as soon as you let off the gas, VDC stops trying to ruin your life too.
i tried it one more time in the offchance somehow I had re-enabled the button (i hadn't) but it still performed the same. I tried to video it but w/o a mount as soon as VDC kicks in i get tossed to the side and therefore the lights move out of frame. sorry but Rememo has it correct, there is no correlation between VDC and the parking brake and the wiring diagrams show there isn't.
we need a way to trick the computer into not seeing one of the inputs, i don't think it matters which because it seems that if you don't turn the wheel it won't kick in, if you let off the gas it quits, etc.
Old 03-27-2013, 03:01 PM   #241
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
Hm, probably not an option, because electric power steering.
soobie doo is offline   Reply With Quote
Old 03-27-2013, 03:08 PM   #242
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
right. i haven't looked at the steering wiring diagram, but after the sensors, etc, i believe it goes to the VDC box and not through it to the electric assist. so there may be someway to trick it into seeing whatever value (resistor for this?) is "neutral"
or maybe speed sensor, as it doesn't kick it at very slow speeds?
either way there seems to be a lot of ways that it will cancel or not kick in (steering, throttle, speed all for sure) and it seems if one of those drops out of the equation, so does VDC.
Old 03-27-2013, 04:27 PM   #243
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i just read through the entire chapter in the service manual about VDC
it uses a lot of inputs, I'm not sure if it could be fooled, and if it can it will probably set a code.
the subaru scan tool looks like it can access a lot of information, i wonder if there is a way to disable it? i didn't see it mentioned, but that doesn't mean it can't be done.
Old 03-28-2013, 12:56 AM   #244
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
I'm going to be making a switch, maybe tomorrow. I have confirmed that completing the circuit when the factory e-brake switch is pressed down and opening the circuit (e-brake off) will engage the the light on the dash. If that makes any sense???....
So just tap in to the single wire going to the switch factory switch and hook it up to a SPST push button or toggle switch then ground the switch...boom e-brake light on dash comes on while the e-brake is all the way down and disengaged.
apexracer is offline   Reply With Quote
Old 03-28-2013, 06:37 AM   #245
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Why waste your time, 2 confirmed reports it doesn't do anything for vdc on/off
Old 03-29-2013, 10:49 AM   #246
Dirt Bringer
Member#: 340297
Ice Silver
Three confirmed. It doesn't work.
Old 04-02-2013, 11:52 PM   #247
Paradis
Member#: 334647
2012 POS Impreza
four confirmed
Old 04-04-2013, 03:14 PM   #248
enfinityx
Member#: 326440
2012 impreza
Late to the party, but to put in my experiences with VDC, even with it turned off the display I have on the car says the VDC was activated anytime it senses any sort of rotation, so I'm pretty sure its still on.
enfinityx is offline   Reply With Quote
Old 04-04-2013, 06:55 PM   #249
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
That's because even though the Subaru manual calls it a VDC switch, it's really not! It's more of a traction control switch because when turned off, it allows for wheel slippage or spinning without cutting throttle.
jsteg is offline   Reply With Quote
Old 04-19-2013, 02:55 AM   #250
Dirt Bringer
Member#: 340297
Ice Silver
Anyone else made any progress with this? Maybe a way to reprogram it to an off position?
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
2012 Impreza 2.0i Gas Mileage Thread Benchmark General Community 934 10-08-2013 02:49 PM
[REQUEST TO MODS] 2012 Impreza 2.0i only forum please? tornado542 General Community 10 04-26-2012 05:07 PM
2012 Subaru Impreza 2.0i Break-In Period Arseezy Newbies & FAQs 7 02-14-2012 08:28 PM
Impreza 2.0i durid Newbies & FAQs 2 02-07-2012 03:54 PM
