Old 06-19-2013, 01:24 PM   #276
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by soobie doo View Post
I think there actually may be a switch to turn off the engine.
And everything else listed lol
Old 06-19-2013, 02:00 PM   #277
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Lmao, true but then you can't drive and I think he wants to be a "drifter!" Maybe he just got done watching the new fast and the furious!
jsteg is offline   Reply With Quote
Old 06-19-2013, 09:42 PM   #278
Cogito8888
Member#: 328981
2012 Impreza 2.0i
Hatch 5MT Camellia Red
Just tested the crosstrek solution it works. In love with this car all over again
Cogito8888 is offline   Reply With Quote
Old 06-19-2013, 11:42 PM   #279
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Anyone figure out a switch yet? I don't want to pull a fuse every time
Old 06-20-2013, 10:11 AM   #280
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Honestly it wouldn't be too hard. You could just solder a couple of wires to the contact points on the fusebox, or even a modified fuse so as to avoid modifying the fuse box itself. Wire that to a button and attach it to the dash somewhere as a hardpoint and you're all set. Maybe wire in a fuse on the path just for safety too.
Dirt Bringer is offline   Reply With Quote
Old 06-20-2013, 10:19 AM   #281
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Exactly what I was thinking but I haven't looked down there recently to even see where this fuse is at
Old 06-20-2013, 03:07 PM   #282
Dirt Bringer
Member#: 340297
Ice Silver
It would be extremely easy. I think that modifying a fuse so as to not modify the car itself is the best idea but the area is very accessible. I think I could probably pull the fuse with my hands, if not a pair of pliers will get it out in a second. It's pretty obvious as to which one it is too. Where you would mount the switch is my question. However, I don't know how good an idea a switch is, because we don't yet know the effect pulling the fuse would have on the car while it is running (effective to hitting the switch on purpose or by accident. I'd rather not damage the ECU for some stupid mistake like that.
Old 06-20-2013, 03:54 PM   #283
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
wouldn't be any different than if the fuse blew while driving
i am thinking of putting the switch in the unused switch holder near the VDC button
Old 06-22-2013, 03:36 PM   #284
Dirt Bringer
Member#: 340297
Ice Silver
i am thinking of putting the fuse in the unused switch holder near the VDC button
I suppose not, though I wonder how it would interpret it (the ecu) and go about disabling and enabling it. Plus, surging the ECU with power when it's on with a reconnected fuse might not be a good idea, I've heard this may damage ECU systems on autos where people hotwired a switch to disable AWD when the handbrake was pulled. If it was up to me, I wouldn't enable or disable it at all unless the car was fully turned off.
Old 06-22-2013, 10:29 PM   #285
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I'm thinking it is safe to disable when driving, like I said the ecu would view it the exact same way as if the fuse blew.
I won't re-enable until I shut it down, chances are if I disable it I am planning on having fun for the rest of my drive.
Old 06-24-2013, 03:51 AM   #286
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
Found this bypass switch
http://blueox.com/Uploads/AppGuides/BX88272.pdf
Originally it's used for disabling fuses for towing behind an rv and what not. It costs $70 which is crazy. So just take a look at the pic and read the instructions. Should be pretty simple to make.
apexracer is offline   Reply With Quote
Old 06-24-2013, 06:53 PM   #287
apexracer
Member#: 257754
Camilla Red Pearl
I made a switch to disable that 7.5 fuse.
I used an inline fuse holder attached one end into one side of the empty fuse slot, and attached another wire in the other side. Then I put the other ends to a switch and viola. I kinda forgot to take pics, but it's so simple. I started making a video but my phone was not cooperating. As stated earlier, once you disable the fuse, just step on the brake and it shuts the vdc stuff off. To enable the vdc again, flip the switch and turn off the car and restart.
Old 06-24-2013, 06:58 PM   #288
apexracer
Member#: 257754
Camilla Red Pearl
I would recommend using the GTC CT6100 atm fuse connector for a final install.
http://www.gtc.ca/EN/CT6100_EN.html you can find it on amazon.com shipped is about $12 but you get 3 sizes. I used a toggle switch with a light on it, but it really does no good, considering every time you hit the brake it turns he light on and off. The lights on the dash should be an even better reminder that it's on and off anyway.
Old 06-24-2013, 07:14 PM   #289
Paradis
Member#: 334647
2012 POS Impreza
Oh MY GOD !!
So happy
Paradis is offline   Reply With Quote
Old 06-24-2013, 07:26 PM   #290
apexracer
Member#: 257754
Camilla Red Pearl
I just tested on some gravel and it works.
Old 06-24-2013, 07:43 PM   #291
jsteg
Member#: 329271
Ice Silver Metallic
Wait though, this isn't new right? I mean I swear I've read this same exact thing before on the forum somewhere....
Old 06-24-2013, 07:51 PM   #292
apexracer
Member#: 257754
Camilla Red Pearl
I think it was a different abs fuse, that disabled a lot more than abs, vdc, hill assist, and cruise. This is the right fuse (7.5) under the dash.
Old 06-24-2013, 08:10 PM   #293
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
Awesome! I don't really desire to use this for fun, but if I were to get stuck in mud/snow this would be very much needed.
Xafen is offline   Reply With Quote
Old 06-24-2013, 08:28 PM   #294
apexracer
Member#: 257754
Camilla Red Pearl
I cut a ring connector and filed it to match as much as I could to the fuse. Better Option is the GTC fuse connector
These are the lights that come on when you flip the switch and apply the brake.
You also lose cruise control, but you don't need it anyway when this is activated.
Inline fuse, one end to fuse slot, other side to switch (RED). All black wire is straight from the switch to the fuse slot.
Left is inline fuse wire, right side is straight wire to switch. Doesn't matter what sides you use by the way.
This is the switch, I'd recommend just a plain switch or some OEM subaru switch you could pop in. The light function doesn't work like you'd want it to. If I grounded the switch the light would come on when I pressed the brake (pointless).
Old 06-24-2013, 10:26 PM   #295
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i'm thinking of blowing a fuse then soldering wire onto it and to plug back in rather than spade/ring connectors. otherwise same idea i had. need to find that VDC switch though
Old 06-24-2013, 11:40 PM   #296
apexracer
Member#: 257754
Camilla Red Pearl
. I thought about doing that, I couldn't get the cut rings in at first. I didn't want to make another trip and spend money on solder. I'm going to swap it with the GTC fuse connector.
Old 06-25-2013, 12:02 AM   #297
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
That thing is exactly what I was looking for
Old 06-25-2013, 04:51 AM   #298
jsteg
Member#: 329271
Ice Silver Metallic
But this also disables power steering...what else is there? I'm pretty certain this disables the same thing as before, but I could be wrong.
Old 06-25-2013, 04:53 AM   #299
jsteg
Member#: 329271
Ice Silver Metallic
Not true. All you need for that is wheel spin and the switch we have in our car is actually a traction control switch, not a VDC switch like the manual states. All you'd need to do if stuck in mud or snow is press that switch and the car will allow wheel spin.
Old 06-25-2013, 06:36 AM   #300
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
pulling the fuse under the hood kills power steering and limits engine rpm to 4000. Also when you put this fuse back in you need to disconnect the battery to reset the computer
According to the post that discovered this, this does not have any of those effects
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
2012 Impreza 2.0i Gas Mileage Thread Benchmark General Community 934 10-08-2013 02:49 PM
[REQUEST TO MODS] 2012 Impreza 2.0i only forum please? tornado542 General Community 10 04-26-2012 05:07 PM
2012 Subaru Impreza 2.0i Break-In Period Arseezy Newbies & FAQs 7 02-14-2012 08:28 PM
Impreza 2.0i durid Newbies & FAQs 2 02-07-2012 03:54 PM
