Old 06-25-2013, 07:11 AM   #301
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Originally Posted by flyboy1100 View Post
pulling the fuse under the hood kills power steering and limits engine rpm to 4000. Also when you put this fuse back in you need to disconnect the battery to reset the computer
According to the post that discovered this, this does not have any of those effects
Gotcha!!
jsteg is offline   Reply With Quote
Old 06-25-2013, 10:31 AM   #302
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
Originally Posted by jsteg View Post
Not true. All you need for that is wheel spin and the switch we have in our car is actually a traction control switch, not a VDC switch like the manual states. All you'd need to do if stuck in mud or snow is press that switch and the car will allow wheel spin.
Ah, thanks! Luckily I haven't been stuck in mud/snow yet =0 I did get 2 wheels stuck in a little ditch this past fall, and was really glad to have AWD, but that's another story lol...
Xafen is offline   Reply With Quote
Old 06-25-2013, 11:23 AM   #303
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
Ya the traction button is probably all you need in snow muddy stuff. But if you want to go play around in a large parking lot full of snow you gotta kill that fuse. If you haven't watched episode 2 of subiesport tv I suggest that you watch it. They do a race in an XV vs. a dirt fish rally car. Obviously the dirt fish car is faster and better prepped, but what the guy says about the vdc in the XV is true.
apexracer is offline   Reply With Quote
Old 06-25-2013, 01:47 PM   #304
JustaImpreza
Member#: 357515
2013 Sport - 5MT
Satin White Pearl
Originally Posted by apexracer View Post
This is the switch, I'd recommend just a plain switch or some OEM subaru switch you could pop in. The light function doesn't work like you'd want it to. If I grounded the switch the light would come on when I pressed the brake (pointless).
Any way to wire the fuse to the Traction control switch? So the switch would kill both VDC and Traction control. The way it should be.
Also, are you turning the car off before switching back to VDC ON?
JustaImpreza is offline   Reply With Quote
Old 06-25-2013, 05:00 PM   #305
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I don't think so because if you disconnect the wiring from the back the ecu will see it as permanently in the off positron
Old 06-25-2013, 05:35 PM   #306
apexracer
Member#: 257754
Camilla Red Pearl
Any way to wire the fuse to the Traction control switch? So the switch would kill both VDC and Traction control. The way it should be. Also, are you turning the car off before switching back to VDC ON?
. Maybe, but I don't know nor did I look. When you put the bypass switch in the traction button doesn't even work (no light on the dash when pushed). Yes you have to turn the car off to turn vdc back on.
Old 06-26-2013, 08:47 AM   #307
jsteg
Member#: 329271
Ice Silver Metallic
I'm pretty sure disabling VDC with the bypass would also disable traction control, as I believe traction control is PART of VDC. I can't see the computer allowing the car to drift around corners (using the mentioned VDC bypass) yet not allow wheel spin.
Old 06-26-2013, 09:42 AM   #308
JustaImpreza
Member#: 357515
2013 Sport - 5MT
Satin White Pearl
Since pulling the fuse/adding bypass switch disables traction control and vdc, why not disconnect the existing wiring clip from the traction control switch? Could use a jumper in the clip so the computer doesn't see the system as always off. Then connect the new VDC fuse bypass to the existing switch. Wouldn't be any easier than adding a new switch but it would look stock. Then should there be any electrical problems that require a trip to the dealer, simply disconnect the bypass and reattach the stock setup. And no one at the dealer would know.
Old 06-26-2013, 10:49 AM   #309
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
That could work, but I only plan to disable everything when I want to have fun, there are times in the winter I only want to disable traction control momentarily, I don't want to shut the car off after to reenable hence why I will add another switch
Old 06-26-2013, 11:57 AM   #310
JustaImpreza
Member#: 357515
2013 Sport - 5MT
Satin White Pearl
Understood. Makes good sense.
I think I read somewhere in this thread that the Traction Control switch is not an ON/OFF switch anyway. Wasn't it just an interrupter? If the bypass was connected to a switch like that would VDC be disabled if: the switch was held in then the brake pedal was applied, then release the switch? And of course it would remain disabled until the car was restarted. The traction control switch is available for $20. I'm only going down this road because I want things inside to look stock. Not to discredit what apexracer has done. I'm thankful he was the guinea pig on this! And I will definitely be doing some kind of switch.
Old 06-26-2013, 12:22 PM   #311
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
It might be just an interupter, but for sure when you press it it disables traction control. It should work for the other stuff too, even if you need to hold it longer, the computer just needs to see the signal has been interrupted somehow.
I need to get that switch ordered
Old 06-26-2013, 01:37 PM   #312
apexracer
Member#: 257754
Camilla Red Pearl
From what i've gathered from using the bypass fuse switch, it's like the ecu needs to shut down then start up for the vdc to come back alive. I don't know too much about interrupter switches. But let's try.
Old 06-27-2013, 11:25 AM   #313
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
if it is just a momentary switch, then after pressing the button the electricity can still flow back through the fuse box and into the ECU. that might be what we want to avoid, need to find a different switch solution that will still look factory
Old 06-27-2013, 11:48 AM   #314
JustaImpreza
Member#: 357515
2013 Sport - 5MT
Satin White Pearl
We know that when the fuse is pulled and replaced the VDC won't reset until the car is turned off and on. And with the fuse pulled VDC isn't disabled until the brake pedal is pressed. I think with the momentary switch, if you press and hold it, it would be the same has pulling the fuse. As long as the brake pedal is depressed while the switch is being pressed the VDC should be disabled. And not reset until the car is turned off and on. Even if the switch is released, completing the circuit.
The Rear FogLight Switch is probably a switch that would work best. I assume that switch is not a momentary switch.
There is also a small gray harness visible in the fuse box area. Does anyone know if that is for connecting to the rear foglight switch? If so, no matter what OEM switch we use, there's a possibility of tapping into that harness to make the switch illuminate.
Old 06-27-2013, 11:56 AM   #315
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i think that harness is for those w/o factory installed fogs, it would plug into the new foglight switch.
i believe the foglight switch is a toggle switch, just need to make a new label for it
Old 06-27-2013, 12:10 PM   #316
JustaImpreza
Member#: 357515
2013 Sport - 5MT
Satin White Pearl
... just need to make a new label for it
Too bad it's an illuminated switch. And the fog light symbol is cut through the switch.
I want that momentary switch to work. Just need a few minutes to go play around with it. Good thing it's not going to snow here for 4-5 months.
Old 06-27-2013, 03:16 PM   #317
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Me too, then I can label it "fun"
I need some one to test it though as I have zero tune right now and won't until fall
Old 06-27-2013, 09:48 PM   #318
apexracer
Member#: 257754
Camilla Red Pearl
We know that when the fuse is pulled and replaced the VDC won't reset until the car is turned off and on. And with the fuse pulled VDC isn't disabled until the brake pedal is pressed. I think with the momentary switch, if you press and hold it, it would be the same has pulling the fuse. As long as the brake pedal is depressed while the switch is being pressed the VDC should be disabled. And not reset until the car is turned off and on. Even if the switch is released, completing the circuit. The Rear FogLight Switch is probably a switch that would work best. I assume that switch is not a momentary switch. There is also a small gray harness visible in the fuse box area. Does anyone know if that is for connecting to the rear foglight switch? If so, no matter what OEM switch we use, there's a possibility of tapping into that harness to make the switch illuminate.
I think the gray harness is for the foot lighting and dash storage in front if the shifter. I could be wrong.
Old 10-10-2013, 09:22 PM   #319
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Installed my traction control kill switch today, time for some snow now!!!
kinger37 is offline   Reply With Quote
Old 10-10-2013, 10:02 PM   #320
apexracer
Member#: 257754
Camilla Red Pearl
Looks good man.
What shifter boot is that?
Old 10-10-2013, 10:09 PM   #321
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Cheap Sickspeed boot off eBay. Fitment wasn't great but I made it work
Old 10-21-2013, 12:23 PM   #322
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i finally figured out the switch i want for my VDC disable, and it looks like it should fit in our cars, but I have no idea how to find the part number to be able to order it.
other thing i'm not 100% sure on is if it is a momentary switch or not
Old 10-21-2013, 01:56 PM   #323
apexracer
Member#: 257754
Camilla Red Pearl
i finally figured out the switch i want for my VDC disable, and it looks like it should fit in our cars, but I have no idea how to find the part number to be able to order it. other thing i'm not 100% sure on is if it is a momentary switch or not
Looks like the outback switch. Just look under the oem catalog on www.subarugenuineparts.com
Old 10-21-2013, 07:24 PM   #324
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
But is it a momentary or toggle switch?
Old 10-21-2013, 09:26 PM   #325
apexracer
Member#: 257754
Camilla Red Pearl
are you wanting to use the parking Brake switch or one if the other ones?
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
2012 Impreza 2.0i Gas Mileage Thread Benchmark General Community 934 10-08-2013 02:49 PM
[REQUEST TO MODS] 2012 Impreza 2.0i only forum please? tornado542 General Community 10 04-26-2012 05:07 PM
2012 Subaru Impreza 2.0i Break-In Period Arseezy Newbies & FAQs 7 02-14-2012 08:28 PM
Impreza 2.0i durid Newbies & FAQs 2 02-07-2012 03:54 PM
