Old 09-01-2012, 10:47 AM   #76
Zeeper
Member#: 299286
2017 Legacy Limited
Originally Posted by ocellaris
Heck yeah. If I had a switch to fully disengage the rear drivetrain and gain 1 MPG, I would drive around like that 9 months out of the year.
Go trade your car for a kizashi, but your mileage would still be better with your impreza.
Zeeper is offline   Reply With Quote
Old 09-01-2012, 11:52 AM   #77
79letour
Member#: 302570
2013 XV
DGM!
Originally Posted by Cogito8888 View Post
Soooo, this was bothering me too the other day, wanted to slide couldn't had to resort to the hand brake.
However I did some digging according to the Forester people the VDC can be killed by removing the abs fuse in the fuse box.
http://www.subaruforester.org/vbulle...-thread-82168/
I looked at our fuse box under the hood looks almost Identical to the forester fuse box. May try removing it over the weekend and see what happens, seems to be the same fuse and everything.
Also I have a 5spd so may be different for cvt
Cool. Try that out and let us know what happens! That sounds like a lot of fun, killing two birds with one FUSE
79letour is offline   Reply With Quote
Old 09-01-2012, 02:11 PM   #78
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
The Kizash? I've seen like one of them on the road to date.
pkL is offline   Reply With Quote
Old 09-01-2012, 03:17 PM   #79
TObject
Member#: 320185
2012 Impreza 2.0i
I used to get only one MPG less in a Kizashi than what I am getting now in a 2012 Impreza. And the Kizashi is 250 lbs heavier.
TObject is offline   Reply With Quote
Old 09-01-2012, 03:44 PM   #80
pkL
Member#: 313093
2012 Impreza 2.0i
But you would agree the Impreza is more awesome no?
Old 09-01-2012, 03:53 PM   #81
79letour
Member#: 302570
2013 XV
DGM!
I've just never personally thought much of Suziki "cars".
Old 09-01-2012, 03:59 PM   #82
Cogito8888
Member#: 328981
2012 Impreza 2.0i
Hatch 5MT Camellia Red
Ok guys pulled the "abs sol" fuse under the hood. On the dash hill assist, abs, cel, traction off, and vdc lights went off.
Did some skid pad like testing and found no VDC interference, speed sensitive steering was also diabled, steering felt noticeably heavier, but in no way undriveable. I also did an emergency stop and got the brakes to lock up. After which TPMS light would flash.
Put the fuse back in started the car, cel and VDC light were on and stayed on. No functionality from the traction control button. Tried driving around a bit, restarted the car a few times with no change.
Unplugged battery by taking off and putting back the negative terminal. While unplugged pumped the brake. After reattaching the negative terminal, started the car, took a second but started. After starting as expected dash was totally clean.
Verdict... I believe we are free of the nanny state for doing dumb ****, autocross, rallycross and what have you. All you need is a wrench for the battery. Not as easy as a button but it will do.
If some one could do some further testing on snow or dirt that would be more definitive.
Cogito8888 is offline   Reply With Quote
Old 09-01-2012, 04:05 PM   #83
TObject
Member#: 320185
2012 Impreza 2.0i
Kizashi is a better car overall. Impreza has slightly better steering, AWD standard on all models, rear seats that fold level, available hatchback, and marginally better fuel economy.
Subaru has a much better dealer network in the USA.
Old 09-02-2012, 07:40 AM   #84
pkL
Member#: 313093
2012 Impreza 2.0i
Talk about a rare car.
Old 09-02-2012, 08:16 AM   #85
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Quite a few of them out here
Old 09-02-2012, 08:36 AM   #86
boudy
Member#: 174665
2011 WRX
Default The title of this thread is "('11+) 2012 Impreza 2.0i Stability Control Function"
Hey thread polluters, please exercise a little discipline and post other topics where they belong: in their own thread. Comments about FWD vs AWD, Impreza vs. other models are IRRELEVANT NOISE.
boudy is offline   Reply With Quote
Old 09-02-2012, 08:46 AM   #87
pkL
Member#: 313093
2012 Impreza 2.0i
Okay forum police. Thanks for contributing to the topic.
Old 09-03-2012, 11:26 AM   #88
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Originally Posted by Xafen View Post
Slightly off-topic, but your awesome autocross video also showcases one of the 2 things that irk me just slightly. You have to turn the wheel a lot to get anywhere. Even just turning a corner takes a full 360 degree turn of the wheel. Yes it has an awesome turning radius, but I just wish it turned faster. (The only other thing I don't love about the car is no automatic locks =0)
Exaggerate much?!?!
jsteg is offline   Reply With Quote
Old 09-03-2012, 11:40 PM   #89
pkL
Member#: 313093
2012 Impreza 2.0i
Well not every car has a turning radius like a smart, so that's just pushing it. I actually think the turning radius is pretty good.
Old 09-04-2012, 12:51 PM   #90
Yuck
Member#: 327734
2012 Impreza sdn MT
Have you tried going above 4k RPM? It cuts off, at least, in the Canadian vehicles
Before unplugging your battery, with the fuse in, did you test to see if you would have VDC interference?
Yuck is offline   Reply With Quote
Old 09-04-2012, 01:46 PM   #91
Cogito8888
Member#: 328981
2012 Impreza 2.0i
Originally Posted by Yuck View Post
Have you tried going above 4k RPM? It cuts off, at least, in the Canadian vehicles.
1. Are you saying that in the Canadian cars if you keep the RPM above 4k than the VDC will not interfere?
2.Or that with the fuse out about 4k RPM the car cuts out.
If 1 than I can't say for sure either way as I didn't specifically test this.
If 2 than this did not happen to me I'm sure I unintentionally went above 4k and nothing strange happened
With fuse in it definitely would, the VDC light would flash above the speedometer whenever I gave the car a lot of steering angle at speed trying to get the car to slide a little.
Old 09-04-2012, 07:09 PM   #92
79letour
Member#: 302570
2013 XV
DGM!
ok- what say ye about the topic then?
Old 09-04-2012, 07:11 PM   #93
79letour
Member#: 302570
2013 XV
DGM!
The turning radius IS good! As good as any car I've owned. FEELS as tight as my 96 and 97 Jettas, and they were lauded for their U-turn abilities.
Old 09-04-2012, 07:13 PM   #94
jsteg
Member#: 329271
Ice Silver Metallic
Nobody ever said it wasn't a good turning radius.
Old 09-04-2012, 07:31 PM   #95
Yuck
Member#: 327734
2012 Impreza sdn MT
I meant that with the fuse out, above 4k RPM, my engine would cut off (or it slowed down the RPM progression drastically, if that makes sense)
Old 09-04-2012, 09:14 PM   #96
79letour
Member#: 302570
2013 XV
DGM!
Hey I was just agreeing with above post and adding a few (rare these days) nice comments about the car.
Old 09-05-2012, 01:37 AM   #97
pkL
Member#: 313093
2012 Impreza 2.0i
Aww..man don't be so negative. It really does suck though with your horrible experience with your car.
Old 09-05-2012, 08:35 AM   #98
79letour
Member#: 302570
2013 XV
DGM!
Lol I WAS being positive
I'm trying to "make lemonade". Even bought some WeatherTech liners when I was in a good mood the other day!
Another POSITIVE- I'm still holding a small glimmer of hope that enough folks have problems for either a Subaru-fix or a class action type deal.
If the next WRX is actually based on the new Impreza, that could also be fun, if enough parts interchange.
Old 09-05-2012, 10:57 AM   #99
Zeeper
Member#: 299286
2017 Legacy Limited
Don't hold your breath on a class-action lawsuit. How many drivers on NASIOC have identified a problem with oil consumption?
I think you can count them on one hand. Good luck finding a lawyer to take that case on for you -- maybe Orly Taitz will be available soon...
They probably will come through with a fix, Rexygirl has already spoken about your particular car and the next oil consumption test.
But yet you continue to rant -- why not give it a rest and give Maestro a chance to deal with your issue before you cause them to tell you to take a hike, as well.
Old 09-05-2012, 10:59 AM   #100
jsteg
Member#: 329271
Ice Silver Metallic
Yeah I have no oil consumption problems so far at 1800 miles.
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
2012 Impreza 2.0i Gas Mileage Thread Benchmark General Community 934 10-08-2013 02:49 PM
[REQUEST TO MODS] 2012 Impreza 2.0i only forum please? tornado542 General Community 10 04-26-2012 05:07 PM
2012 Subaru Impreza 2.0i Break-In Period Arseezy Newbies & FAQs 7 02-14-2012 08:28 PM
Impreza 2.0i durid Newbies & FAQs 2 02-07-2012 03:54 PM
