Old 03-02-2012, 04:06 PM   #1
tom bauer
Member#: 310141
Default 98 legacy ob turbo upgrade
i have the entire drive train from a 06 lgt in my 98 lob and it runs great. but after a couple of years you get used to it ya know? so i am upgrading the vf40 to a vf52. initially only 2 noticable differances in the actual turbo. first the vf52 does not have the mount to secure the oil pipe, will have to make a small bracket to keep it from vibration. second the vf52 surely does have a bigger turbine wheel! i was making 17 lbs with the vf40, will post the after install reading soon. i am using a 04 sti ecu. (simplest way to get away from the CAN data, imobilizer etc)
tom bauer is offline   Reply With Quote
Old 03-02-2012, 07:34 PM   #2
RexWagonWA
Member#: 221945
Default Upgrade
IMHO, the 2004 STi ECU does not play well with an 2006 Legacy GT engine? I think the cams are different.
You are right about the newer bus being a hassle. Check with someone like iWire or your regional forum. You do not need to reinvent the wheel.
GLWYS
RexWagonWA is offline   Reply With Quote
Old 03-02-2012, 09:11 PM   #3
tom bauer
Member#: 310141
i thought i read that iwire did not do anything with CAN data, could be wrong. i had tried a 04 forester XT ecu and the sti one ran much better (both stock config)
Do 04 STi steering wheel fit on 98 Legacy OB??? SONofSAM Legacy Forum 5 12-31-2010 04:07 PM
FS : (PA) 98 Legacy/OB parting out styng88 Legacy Specific Parts 68 10-28-2010 10:01 PM
Legacy OB Headlight upgrade TexasVet Outback Forum 0 06-11-2006 08:53 PM
98 legacy gt turbo pics (finished) dingy Normally Aspirated with bolt-on Forced Induction Powertrain 16 11-03-2005 09:27 PM
