#1 |
Member#: 254088
Vehicle:2008 Legacy GT silver |
I bought a STI high pressure cap (ST4511355010) My car is a 2007 subaru wrx, with sock front radiator. Can I use this cap? some places say yes on the radiator, others say use it by the top mount, yet others say do not on stock radiators!!!!!!
![]() What is it does anyone know for sure? If not I will just throw this thing away rather than risking harm to my car and blowin hoses and radiators. Thanks for any professional advice and empirical evidence ![]()
#2 |
Member#: 36310
SWIC
Vehicle:03 WRX Sedan Silver |
#3 | |
Member#: 155598
NESIC
Vehicle:2004 AW Subaru WRX JDM v7 STI spec-C |
#4 |
Member#: 254088
Ok cool thanks it has two lil ears so top mount res. I read on another forum to do the same thing. Where did you get your info? i am just uncertain because of so much contradictory info out there..
#5 |
Member#: 254088
Why would you wanna raise the pressure of the intercooler and not the radiator? It seems to small to really make a difference, unlike bigger front mount. can I use this if I have a stock intercoolers? I have heard yes and no? anyone know about this. Thhanks
#6 | |
Member#: 250152
Vehicle:2006 WRX Limited OBP |
I suggest before you go buying anything for your car from here on out, you should consult a professional, as you CLEARLY don't have the slightest clue of what you are doing. What was the reason for needing the cap anyway? Just to say you have Sti parts on your WRX? Last edited by 2Fast4U1DAY; 03-03-2012 at 04:13 PM. |
#7 |
Big Ron
Moderator Member#: 18062
What does the Cooling System FAQ tell you about this subject....you DID read the sticky threads BEFORE posting right????
#8 |
Member#: 254088
Yeah the sticky facts arent clear and are vague thats why I am asking for clarification and intercooler was used as a loose term lol dont get your panties in a bunch. Plus I had money falling off my money tree so I bought this shiny pink cap to put on my car not realizing it could EFF stuff up. Sorry I did not consult my dad or a professional prior to this purchase Shame on me for not finding my answer in the FAQs. Does anyone else want to take their stress out on me?
#9 |
Member#: 254088
According to the sticky FAQ
"What about higher pressure radiator caps? Higher pressure radiator caps increase the boiling point of your coolant. Higher pressure = higher boiling point. Higher coolant pressures also transfer heat from the cylinder heads more efficiently. There have been several reported cases of higher pressure radiator caps causing ruptures in the endtanks on any OEM Subaru radiator. These should generally be reserved for aftermarket radiator users. See vague. Ps I bought this thing cuz I beat the hell out of my car and thought it would help it keep from overheating in the hot ass summer due to increased temp. Last edited by DerekDaniel; 03-04-2012 at 12:23 AM. |
#10 |
Member#: 257043
VIC
Vehicle:1993 JDM WRX Wagon Black |
This sounds a bit like a Troll post. I dont want to believe that the OP is rooting around under the hood and messing about when he doesn't know the difference between a radiator and an intercooler.
I'm slightly shocked that he quoted the exact Part of the FAQ specifically answering his original question. I'd like to say I'm stunned but im not. If there are issues with overheating then a radiator flush, refill with appropriate coolant and burp is called for. Possibly a heavier weight engine oil unless the recommended weight oil is not being used in which case stop letting them put 5w30 in the car when your mom takes it to jiffy lube. If properly maintained the factory coolant system is sufficient to deal with the factory engine power output. A high pressure Rad cap is no substitute for proper maintenance. If the engine is making additional power in a warmer climate without appropriate upgrades to the cooling system (aftermarket radiator, oil cooler) then you kind of had it coming. |
#11 |
Member#: 254088
not all my questions were answered by that FAQ either. did ya ever imagine that? JUBERT thanks for your response
| Thread Tools | |
| Display Modes | |
| For Sale STi High Pressure Cap | Hometown Baller | Engine/Power/Exhaust | 5 | 06-04-2009 02:55 AM |
| FS: JDM Hazard Switch, SPt Battery Tie Down, SPt Oil Cap, STi High Pressure Cap | Kumar | NWIC Private Classifieds | 9 | 04-20-2008 12:30 PM |
| FS: STi High pressure cap | KiraFayt | VIC Private Classifieds | 8 | 01-09-2008 04:33 PM |
| STI high pressure cap problem? | SLowery | Factory 2.0L Turbo Powertrain | 4 | 01-02-2003 09:17 AM |
| STi high pressure radiator cap | TWRX12 | Service & Maintenance | 2 | 05-16-2002 04:05 PM |
