Old 03-02-2012, 10:01 PM   #1
etidatreyu
Member#: 285495
2004 WRX
Default Engine Trouble, V2 STI
I was driving the car today and the power cut off a couple times like i stalled, but I was driving so theres no way I stalled. So i assumed it was a wiring issue and was planning on getting it checked out, then on my way to work I heard a popping, the engine lost a **** ton of power, and now feels like its REALLY bogged down. Almost sounds like a lawn mower. Anyone ever experience this or know what the problem could be.
etidatreyu is offline   Reply With Quote
Old 03-02-2012, 10:34 PM   #2
suberdave
Member#: 101865
88 GL-10 STi
check to make sure you didnt loose a charge pipe. anything between the maf and intake will cause all kinds of issues.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 03-03-2012, 12:24 AM   #3
etidatreyu
Member#: 285495
2004 WRX
alright ill check it out in the morning, thank you
Old 03-04-2012, 05:57 AM   #4
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
renhoek is offline   Reply With Quote
Old 03-04-2012, 10:46 AM   #5
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
So what came loose?
TommyAtomic is offline   Reply With Quote
Old 03-04-2012, 02:20 PM   #6
etidatreyu
Member#: 285495
2004 WRX
looks like one of the spark plugs melted and shot out of the engine and i was running on 3 cylinders. thank god there was no internal damage
Old 03-04-2012, 06:42 PM   #7
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Melted and shot out? Unless I've gone completely mad I could swear an EJ20 engine uses an aluminum cylinder head. How are you melting and shooting a plug out without damage to the head and or at the bare minimum the spark plug threads.
Hopefully it was something far less dire like an improperly torqued plug that vibrated loose.
Old 03-04-2012, 07:14 PM   #8
etidatreyu
Member#: 285495
2004 WRX
Well the spark plug itself is definitely melted. But I'm not really sure, the guy that looked at my car said it looked like it "shot out" but then again he also told me I had to lift the engine out to replace the plugs because of how snug the engine fits. Which doesnt appear to be true. So who knows. But he replaced that one plug with a different kind then I was currently running on so I could get it home, which is about a 2 minute drive thank god, and it appeared to be running fine, a little hesitating, but once all the plugs are replaced and the correct type hopefully it will be running 100%
Old 03-05-2012, 05:43 AM   #9
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
How bizzare. What part of the spark plug was melted?
Old 03-05-2012, 10:15 PM   #10
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
pics please!
elislider is offline   Reply With Quote
Old 03-05-2012, 11:45 PM   #11
etidatreyu
Member#: 285495
2004 WRX
I actually don't have the spark plug, but it was down by the ground electrode/firing end or whatever you want to call it.
Old 03-06-2012, 06:18 AM   #12
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
You might have a bigger problem than you think.
Old 03-06-2012, 10:00 AM   #13
etidatreyu
Member#: 285495
2004 WRX
Yeah im looking into it. I was told a new coil pack and sparkplugs, but we'll see what it ends up being.
Old 03-06-2012, 10:02 AM   #14
etidatreyu
Member#: 285495
2004 WRX
Do you have any idea what the "bigger problem" could be by any chance?
Old 03-08-2012, 05:38 AM   #15
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Well, for a spark plug to melt (electrode end), it usually is a sign of very hot/detonation present. *This is not a normal situation, so something must have caused it. *
If you have changed absolutely nothing on the engine and it just did it, then it could be a cylinder running unusually lean because, for example, that fuel injector is blocked. *You need to track down the cause.
then, you could have done other damage to that cylinder, eg piston damage if it was detonating.
All this is speculation but you need to work it through thoroughly.
Cheers
Old 03-08-2012, 01:36 PM   #16
etidatreyu
Member#: 285495
2004 WRX
Alright thanks alot man, ill definitely look into it. Thank you
Old 03-08-2012, 01:51 PM   #17
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Might be time for you to invest in a wideband A/F guage. Also may be worth going to a colder plug and verifying plug gap.
What Make/Model of plugs are you using? NGK, Denso, Champ, etc?
I'm the first person to try out new types of plugs Like PulsePlugs or Diamondfire plugs and I am telling you dont. Stick with a good old fashioned Copper J-Wire plug like an NGK V-power BR6EK gapped at .028 . Use antiseize on the plug threads and squirt some dielectric grease in the plugboot on the coilpack.
Run them for 3-4 days of periodic driving and then pull each one and check the condition.
Something like running lean will show up right away. There is a cheatsheet floating around with Pic's of spark plug electrodes in various condition and a guide showing you what it means.
Figure out which cylinder(s) are causing you trouble. If its just one cylinder fine you can troubleshoot that. If its all of them you likely did something wrong. Wrong temp plug, wrong gap, wrong fuel, running more boost without tuning for it, etc.
Old 03-08-2012, 02:24 PM   #18
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
A google search of "Spark Plug failure Analysis" will provide you with a wealth of information
Old 03-09-2012, 02:06 PM   #19
etidatreyu
Member#: 285495
2004 WRX
Alright awesome thank you. Yeah I'm running NGK bkr7e and it seems to have somewhat gotten rid of the issue, I still plan on looking into what made it melt though. It seems like it may be running a bit rich, and I already have the Wideband gauge and went to hook it up yesterday actually but the spot on my down pipe for the 02 sensor seems to be too small for the 02 sensor itself and thats the only spot on my exhaust so I havta figure something out to get the settled. But I will definitely take all of that into consideration, thank you very much
Old 03-14-2012, 12:20 PM   #20
lele
Member#: 156792
94 Ver2 STI
with everything said above would it not be a good idea to replace those V2 coilpacks as well? (GD wrx coilpacks)
lele is offline   Reply With Quote
Old 03-14-2012, 01:17 PM   #21
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Agreed the USDM coilpacks are a good upgrade and solve alot of problems. They in many cases are quite a bit cheaper then getting new JDM coils. One must be willing and capable of doing some soldering but its totally worth it.
Old 03-14-2012, 09:02 PM   #22
etidatreyu
Member#: 285495
2004 WRX
Yeah the previous owner of the car had it installed so I could get the USDM wrx coilpacks as well. Which, as you said I have heard is much better and cheaper than the V2 ones
V1 WRX STi RA engine into V2 WRX STI car renhoek Pre-2002 Factory Turbo Powertrain 14 12-27-2010 01:33 PM
Chipped V2 STi engine hail2theTheif NWIC Private Classifieds 4 06-24-2008 10:48 AM
Chipped V2 STi engine hail2theTheif 1993 - 2001 Impreza Specific Parts 4 06-23-2008 05:43 PM
Chipped V2 STi engine hail2theTheif RMIC Private Classifieds 4 06-23-2008 03:10 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 09:04 PM
