#1 |
Member#: 15445
E. Canada
Vehicle:1986 Leone STi EJ22T JDM White |
ATT ! no more room on the first page so everything will be as i go
The Subaru Leone TURBO 1986 Subaru GL-10 TURBO 29,000km 18,000miles all oem, weight of the car 910kg ! ![]() ![]() ![]() ![]() the parts car for awd and 5x100 86 xt6 swap ![]() my other baby now a parts car ! 93 legacy turbo on pump 94, 426hp 390tq. built forged ej22t, with ver8 STi heads all oem, soon on its way ! a full race twin scroll bw S200SX 7670 to make some more power. on pump 94 with the full race i should be about 470hp 450tq... with race gas ?????? ![]() ![]() the refresh block to my legacy block which is going in the GL-10 400,000km ej22t block, sent out ready for me to put together. ![]() plug the breather hole ![]() EJ20G STi type RA crank ![]() what i have done so far: (pic soon) striped down the xt6 for all its parts to convert the gl-10. the block will take me a day to build, so ill get it ready on a later date. the full race should be on its way soon and my legacy turbo is still my dd. when it gets warm out, i pull the legacy apart for the rest of my parts to go in the GL-10 whats in store quick run down; a AWD 990kg car with pump sunoco 94 470hp 450tq.. with Race Gas ! something just silly (in legacy) built forged ej22t, oem STi ver8 heads, STi spec-C RA 3.9 6mt non dccd, r180, Vi-Pec 044, bosch pump, BREMBO, BBS, cusco motor tranny mounts. what is on the way: full race twin scroll bw S200SX 7670, a barrel of Race Gas, new bushings bearings oem + powder coat allot of stuff. most likely: hsd coilovers, whitline products all over the place for what ever fits on this car ?? maybe: not brembos but wrx 4pot 2pot (leaning this way for light and stupid fast) + enkei rally racing rims RC-G4 15" gold, r comp racing tires.
#2 |
Member#: 15445
E. Canada
we start of with a stock 1986 Subaru GL-10 FWD TURBO 28,000kms. weight is 910kg 2002lb car !!
![]() ![]() so what we have hear is to add the 4WD system into one of these cars, those are 20MM sway bars, above the sway bars is what holds the diff, about that is a mix and match of old and new to hold the STi 6mt, above that is a updated version of control arms to hold the 5x100 knuckle. ![]() rear axle XT6 for the R180 3.900, there is a trick to these where i mix the outer with the new style inners to run a R180. or i could just stay light weight and put a R160 in it. ![]() cusco motor tranny mnt ![]() ARP head studs, Cam & Crank sensor new oem ![]() Spare EJ22T Built @ SUBARU TECNICO INTERNATIONAL ![]() this is the motor that will be put in this monster ! a EJ22T full built version 8 STi heads big port, with a Full Race twin scroll turbo kit on its way. ![]() the end result will be a -2300lb GL-10 with 500whp 94 Pump, 550whp Race Gas. brakes will be subaru 4pot 2pot Last edited by NICO TURBINE; 03-28-2012 at 07:52 PM. |
#3 |
Member#: 15445
E. Canada
(ECU adaptation)
so what we have hear is the female plugs i need from a stock 1986 turbo ecu that i destroyed for these plugs ![]() ![]() just got a little eye candy from Jon at full race coming soon !! ![]() Well got half the brakes sorted out for the project ![]() so got a little oem new parts in today xt6 wheel bearings, xt6 steering tie rod, mustache bar bushings, and new diff support. also have 2006 wrx 2pot rear backing plates, but i sent them out to a friend's machine shop to make a ring for the centering ring ![]() this saturday i should have my xt6 rear control arms in, the ones i took of the xt6 i cant get bearings out the locking nut is rusted shut Last edited by NICO TURBINE; 04-11-2012 at 07:01 PM. |
#4 |
Member#: 15445
E. Canada
new turbo set up full race twin scroll
![]() ![]() ![]() ![]() ![]() ![]() Last edited by NICO TURBINE; 04-21-2012 at 12:32 PM. |
#5 |
Member#: 15445
E. Canada
well i sold my legacy turbo as is so im just going to buy new stuff like a STi ver 8 for its heads, wires, 6MT, then swap the built ej22t block i built.
so parts list is VER 8 Sti complete Vi-PEC V88 EXEDY ?? dont know yet maybe multi plate to hold the power SPARCO seats: maybe, kind of want it stock but need support lol Rims: gc8 and volk jdm if i can find them Tire's : RACE SLICK lol for evey day haha !! new rotor pads that wont stop this much power to weight lol ![]() my rear control arms, that me and my dad had to make a tool becuase no one on the plant has one lol ![]() ![]() ![]() little thermal coat so then i can wrap them ![]() got some tubes to make my wastegate pipes longer away from everything ![]() Little powder coat action ![]() Got my 2006 wrx backing plates all fixed up so they can fit on the hub the xt6 hubs as instructed from Suberdave ! ![]() ![]() Last edited by NICO TURBINE; 05-11-2012 at 02:39 PM. |
#6 |
Member#: 15445
E. Canada
So I went and picked up a Jdm spec c version 8 (maybe type RA) motor swap Ej207DW7ER TY856WB6JA for heads and tranny diff and what ever else I need to twist my leone in to pretzel lol
![]() ![]() Also I was driving to see the boys at Nvauto and I seen a gc impreza on top of another car scrap yard ! so I found the rims I wanted for a steal 250. So I sent them out to the sand blasters to get ready for the powder coating. I'm thinking world rally blue color for the rims ![]() ![]() started stripping for what i need ![]() ![]() Last edited by NICO TURBINE; 05-19-2012 at 08:37 PM. |
#7 |
Member#: 107571
NESIC
Vehicle:2004 OBS JDM V8 Sti UsVERSUSThem WFC #197 |
wow too cool
#8 |
Member#: 122598
SCIC
Vehicle:2006 WRX Wagon |
This is going to be exciting to read!
#9 |
Member#: 312147
#10 |
Member#: 65856
Vehicle:2000 S4 Black 1992 Miata Red |
#11 |
Member#: 294461
NWIC
Vehicle:1997 Outback Sport Acadia Green Metallic |
That is going to be the sleeper from hell. I can't wait to hear about stanced out STis getting walked on by an 86 sedan!
#12 |
Member#: 210790
Vehicle:2002 WRX PSM EJ207 power plant |
WO! thats awesome
#13 |
Member#: 177880
South East
Vehicle:2002 Wrx Wagon 6sp Where can I get some cake |
I miss my loyale
#14 |
Member#: 15445
E. Canada
^ glad all you guys love it lol
little update also |
#15 |
Member#: 166324
NESIC
Vehicle:02 V8 Spec C 03 V9 Limited 2013 Legacy |
Very clean!
#16 |
Member#: 275888
Vehicle:2011 WRX Limited SWP |
Wow, no rust to boot. Man is that CLEAN!!!
#17 |
Member#: 55963
Vehicle:99rs sti v5 LISC #57 |
your crazy man....i like it
#18 |
Member#: 137812
Subscribed! U should keep it looking as stock as possible.
#19 |
Member#: 65856
I love this!
#20 |
Member#: 255281
Vehicle:2002 WRX WRB |
this is going to be epic
#21 |
Member#: 242947
NESIC
Vehicle:13 WRX Hatch SWP |
subscribed. looks like its going to be incredible.
#22 |
Member#: 198935
VIC
Good god, this thing is going to be a beast. As said above, I can't wait for some stupid stanced car to get it's door blown off by this
#23 |
Member#: 219492
Vehicle:11' STi, RIP CSK. 13' Galaxy Blue Breeze |
#24 |
Member#: 207830
Vehicle:2002 Precision Built www.PrecisionCustoms.us |
love it!!!!
#25 |
Member#: 15445
E. Canada
lol glad everyone is enjoy the build !
update on ecu set up |
| Thread Tools | |
| Display Modes | |
| WTB/WTT : 1986 gl-10 parts | conifersubaru | Private 'Wanted' Classifieds | 1 | 07-17-2011 11:25 PM |
| 1986 GL-10 Turbo | deathwagon | 'Old School' Subaru Forum | 5 | 10-26-2009 01:12 PM |
| Free to a good home: 1986 GL-10 Turbo Wagon | WJM | Private Vehicle 'For Sale' Classifieds | 10 | 04-01-2007 10:23 PM |
| 1986 Subaru GL-10 4WD Turbowagon FS | Flowmastered87GL | North West Impreza Club Forum -- NWIC | 11 | 06-08-2003 02:52 AM |
