Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 03-03-2012, 09:29 AM   #1
scottie1134
Member#: 214655
2001 Audi S4
Default New Mexico's highest power WRX 715 hp
scottie1134 is offline   Reply With Quote
Old 03-03-2012, 11:10 AM   #2
Eisenbergs blue boo
Member#: 297902
Your going to need a mod list around these here parts sir
Eisenbergs blue boo is offline   Reply With Quote
Old 03-03-2012, 11:34 AM   #3
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Yup. Please read this and update your first post with the required format. Thanks.
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 03-03-2012, 12:59 PM   #4
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
mod list and some freaking coil's or springs stock suspension on that much hp is crazazay!
907Bum is offline   Reply With Quote
Old 03-03-2012, 02:26 PM   #5
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
are we even allowed to post other peoples cars we know nothing about? I think not
this could be just some 35r with inflated #'s, nothing to see here
go see Phatbotti Tuning for any of your tuning needs, even if they aren't local to you, tunes can be emailed until everything is perfect
Irv Weissmanhowerton is offline   Reply With Quote
Old 03-03-2012, 03:37 PM   #6
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Subaru's cant make 715hp..........
JMK508 is offline   Reply With Quote
Old 03-03-2012, 04:14 PM   #7
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
must be a dyno with 30% cf.Pull was too slow revwise for a 700whp suby.I say BS.
john 1badSTI is offline   Reply With Quote
Old 03-03-2012, 04:31 PM   #8
DerickRyoung
Member#: 178050
02 hybrid-wrx
psm
I am not sure about the video either. Cam tuning in NM is trying to hit over 700whp on his wagon. He many have already but I havent checked in awhile.
DerickRyoung is offline   Reply With Quote
Old 03-03-2012, 04:43 PM   #9
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
I have no clue if that was 700 whp or not, but the pull was long due to it being a 4th gear pull and not 3rd. Phil did a 4th gear pull in my car John and it took forever to rev it out to 8500.
Md05STI is offline   Reply With Quote
Old 03-03-2012, 05:17 PM   #10
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.8@150
I was there. 4th gear pull with 1.16 cf. I managed 705 sae last year.
06rexwagon is offline   Reply With Quote
Old 03-03-2012, 06:25 PM   #11
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
iirc sae is crank hp rating not whp.So takeaway 20% and you are at 600whp which is believable.
Old 03-03-2012, 06:27 PM   #12
06rexwagon
Member#: 114730
9.8@150
Sae is only for run conditions and doesn't take drivetrain loss into account. Scottie probably has the uncorrected graph.
Old 03-03-2012, 06:34 PM   #13
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
cool I am not trying to take anything from it just making sense so those who don't know how to interpret the #'s can.
Old 03-03-2012, 07:18 PM   #14
06rexwagon
Member#: 114730
9.8@150
No problem dude. I didn't build or tune this car and now I need to get to work on mine so I can beat it.
Old 03-03-2012, 11:55 PM   #15
Junior2JZ
Member#: 64908
10.8 XT+9.2@155 GR+
9.1/157mph 2015 STI
715 SAE is no joke, what were the numbers in uncorrected?
BTW that is WHP, SAE/DIN/UNC/STD are just types of WHP readings with different temp/elevation corrections.
+1 for at least being on a real dyno, lets see some 145+mph passes now!
Junior2JZ is offline   Reply With Quote
Old 03-04-2012, 03:05 PM   #16
Clark Turner
Member#: 178047
02 WRX STI Spec C
Ya gotta love skinny roller dynojets and 4 second dyno pulls!
C
Clark Turner is offline   Reply With Quote
Old 03-05-2012, 11:58 AM   #17
Member#: 278519
30r E85 sti 450+whp
kb'izzle
not gonna happen with this car
as I was saying above, just a regular 35r car at best
If someone is going to post the crank hp, they need to CLEARLY say that to avoid all confusion and people calling out, %99 use whp on ppb
Old 03-05-2012, 12:50 PM   #18
Motiva
Member#: 304763
2004 WRX
Rally blue
Dynojet dyno
GTX35R turbo at 29 psi
2.5 block
Forged piston and rods
Sleeved
2000cc injector dynamics injectors
E71 fuel tested by Cam (06rexwagon)
AEM EMS series 1 ecu
AEM 5 bar map sensor
AEM Tru boost boost controller
STi 07 transmission
DSS driveshaft
Cosworth intake manifold
Full Blown dual fuel pump hat
Aeromotive 340 LPH fuel pumps
RS Machine CNC ported heads
4th gear pull on the dyno to 8000 rpm.
DynoJet is wheel horsepower. The correction factor is predominately based on barometric conditions. Ambient temperature has very little to do with it's correction factor. I use SAE corrected numbers.
Location was at Pro Power Dyno in Rio Rancho, NM
Motiva is offline   Reply With Quote
Old 03-05-2012, 03:14 PM   #19
BoostInc
Member#: 176520
1994 Legacy SS
black and mud
^This
car made 620ish corrected, dont really remember.
Pic of set up while under construction
BoostInc is offline   Reply With Quote
Old 03-05-2012, 04:43 PM   #20
Member#: 278519
30r E85 sti 450+whp
kb'izzle
very nice, thanks guys
is the owner interested in dragging it?
Old 03-05-2012, 11:05 PM   #21
kpadill2
Member#: 266208
I stumbled upon my own car lol! Here is a full mod list of the car. She is still very much a work in progress, including things like suspension, coatings, exhaust cutout, axles, brake rotors, so on and so forth.
Engine:
-RS Machine EJ257
-Darton Sleeves
-CP pistons
-Eagle rods
-Micropolish Crankshaft
-Balanced
-Bearings (Std Mains/Race Rods/Thrust)
-Jdm 12 mm oil pump
-2 liter heads
-RS Machine CNC port/valve job/recondition complete heads
-SuperTech +1mm Valves (intake nitrate)
-SuperTech Valve Train(Springs/Retainers/Spring Base)
-BC 280 Cams
-KillerB Oil pan/baffle/pickup
-Mishimoto radiator
-gtx3582r with a tial 1.03 ss hotside
-KillerB Holly Header modified for rotated
-bellintercoolers 2.5 in inlet 3 in outlet
-Custom Boostinc fabed intercooler piping
-rotated cosworth intake manifold modified for drive by wire
-Grimmspeed TGV deletes
-Tial 44mm gate
Fuel
-AEM EMS
-Fullblown twin pump top hat
-Dual Aeromotive 340's
- -8 feed -6 return
-Injector Dynamics 2000 cc injectors
-Agency Power fuel rails
-Aeromotive FRP
-inline Aeromotive Fuel Filter
Drivetrain:
-2007 sti 6 speed
-2006 r180 with 2004 sti rear subframe
-Turninconcepts super shifter set
-Tic crossmemer bushings
-GroupN transmission/motor mounts
-Drive Shaft Shop aluminum drive shaft
-DCCDPro
-ACT 6 puck
-Stock sti flywheel
-gold brembos and black bbs
-tires - undecided?
I'm sure I'm missing a lot of stuff
Yeah I plan to drag the car but not to a crazy level. Albuquerque's track frequently has a DA of 8000' during the summer and getting into the 10's would be a great achievement. Camtuning has got me on experience and skill so it'll be fun
kpadill2 is offline   Reply With Quote
Old 03-05-2012, 11:20 PM   #22
BoostInc
Member#: 176520
1994 Legacy SS
black and mud
Uhhh we used scotty because hes been a AEM beta tester for years an what would of taken days if not weeks for emailing stuff back an forth we had scotty do and still made this awesome number on this little turbo.... In 3 hours....
Old 03-07-2012, 01:36 PM   #23
inursteye
Member#: 271879
Albuquerque is throwing down some big numbers. Congrats Kyle on an awesome car, Harrison of Boost Inc., and Scottie of Motiva. Great work and awesome build. Haters on here gonna hate I'm sure they will do the same thing when I post my numbers, they already did once.
inursteye is offline   Reply With Quote
Old 03-16-2012, 01:56 AM   #24
r o y c e
Member#: 253742
I found you on nasioc KYLE!!!! LOL
I still can't wait to run em again, It just doesnt seem right walking you with so much less HP
r o y c e is offline   Reply With Quote
Old 03-16-2012, 01:57 AM   #25
r o y c e
Member#: 253742
And what's up with using the brake on the dyno "kinda like brake boosting it on the dyno" Are you checking AFR's or something
MWC Women's Soccer: New Mexico's Elizabeth Lambert vs BYU SQ3.0dotJP Off-Topic 13 11-07-2009 10:19 AM
04 WRX HAWK HP+ Break Pads Front BRAND NEW Rudywrx04 Suspension/Brakes/Handling 1 08-18-2009 08:38 PM
If you had to pick between great suspension/low power, or high HP/terrible suspension brucelee Off-Topic 67 07-11-2008 12:00 AM
New Mexico's newest WRX swapped RS joscolem Member's Car Gallery 27 08-09-2007 01:19 AM
Highest Power SVX? driving2.5sti Proven Power Bragging 2 06-18-2007 10:23 PM
