Old 03-04-2012, 06:09 PM   #1
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Default Koni install assistance requested (2011 WRX)
I started my Koni install today and got most of the way through the assembly process for the front struts.
I used '09 WRX struts as cores and had no issues in removal, disassembly, cutting, etc. When I got to the assembly stage, I got stuck. Before I go beating things with a deadblow hammer (recommended by Koni), I wanted to make sure that I got things right on the cutoff.
So I made it to here:
The strut insert seems to be at the correct location when looking from the top of the housing, but when it comes to the interference fit, I feel like just pounding the insert is a bad idea.
I read some thread on here that recommended using the bottom bolt to draw it into place, but the bolt does not reach the threads on the insert.
The directions state that if the interference nubs are 46mm from the top of the insert, you come down 40mm onto the body and make the cut.
Here are my measurements:
The bolt is 1" long. The insert is 1 5/16" inside of the housing.
What is the best way to go?
Longer bolt to draw it in (then replace with proper bolt)? Does anyone know the bolt size/pitch?
Dead blow hammer?
Cut the housing down by a few more mm to make it easier?
Thanks in advance!
Edit: For those not familiar with the process, I found this thread informative about the general process, but not about drawing/pushing the insert into the OEM housing:
http://forums.nasioc.com/forums/show....php?t=1219607
phenryiv1 is offline   Reply With Quote
Old 03-04-2012, 06:17 PM   #2
teiva-boy
Member#: 22825
I used a press.
Though did on another car use a block of wood and a deadblow just fine when a press wasnt handy.
teiva-boy is offline   Reply With Quote
Old 03-04-2012, 07:39 PM   #3
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Where did the press make contact with the insert?
I have access to some large furniture clamps that I can use in place of a press. Good idea? Bad?
Another thought that I had was some PVC pipe with a large enough ID to fit around the shaft and then use that to try to pound the nubs into the housing far enogh to engage 4-5 threads and then draw it in from there.
Old 03-04-2012, 11:19 PM   #4
whitevo8
Member#: 255920
03 Evolution
Dont cut the housing any more than what is said to. Typically a buffer and sanding off a lot of the paint helps it fall into place a little easier.
whitevo8 is offline   Reply With Quote
Old 03-04-2012, 11:42 PM   #5
teiva-boy
Member#: 22825
PVC isnt going to cut it. It needs to be a metal pipe. But you have the right idea.
As suggested sanding the paint could help some
Old 03-05-2012, 02:49 PM   #6
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
After talking to Koni, I determined that the allen bolt that comes with the kit is an M12-1.5 x 25. For those who don't know how to read the specs, the size is an M12 with 1.5 threads per millimeter and a length of 25mm (about 1" for we Americans).
I decided that I will first try to draw the insert into the housing, but with the bolt being too short, that means that I need a longer bolt. I got excited when I realized that the bucket of a couple dozen BMW e30 lug bolts that I have from stripping parts cars during a track car build are the same M12-1.5 size/pitch, but then I found that they are the same 25mm length as the Koni bolt.
I went and ordered 2 more bolts in M12-1.5 in 40mm and 45mm lengths. I will use them to draw the insert into the housing and then replace them with the Koni bolt (complete with LocTite).
Old 03-05-2012, 03:01 PM   #7
teiva-boy
Member#: 22825
Take a 2x4, put it on the top yellow area around the shaft. Pound away... That worked in 2003 when I had a bugeye.
Though a press is preferred and much easier. Sure you can't find someone with one? Or ask a shop if you can use theirs for 10min?. I did this a couple years ago on my Forester.
Old 03-05-2012, 10:53 PM   #8
msennati
Member#: 238247
2010 WRX Hatch
WR Blue
Using a longer bolt to draw the strut into the body is OK, just make sure the body is not too long or the insert will not bottom out in the strut housing.
More info:
http://forums.nasioc.com/forums/show....php?t=2225818
http://forums.nasioc.com/forums/show...219607&page=18
msennati is offline   Reply With Quote
Stock tweeter housings- how hard are they to gut? (2011 WRX) phenryiv1 Car Audio, Video & Security 27 11-25-2014 02:17 PM
1-touch window control stopped working after speaker install (2011 WRX) phenryiv1 Car Audio, Video & Security 5 06-25-2011 09:10 PM
Help with thunk/clunk on stock suspension w/ aftermarket swaybars (2011 WRX) phenryiv1 Brakes, Steering & Suspension 3 06-13-2011 09:54 AM
Install Day Assistance Request - Sunday June 8th mav1c Mid Atlantic Impreza Club -- MAIC 25 06-09-2008 01:51 PM
Request for stereo installation assistance STI05 Southern California Impreza Club Forum -- SCIC 0 05-06-2005 01:26 AM
