#1 |
Member#: 130985
Got a 1998 outback here. The high beam lights just stopped working, the bulbs are good. The fog lamps also stopped at the same time. When you turn on the high beams the indercator lights as it should. When you push the fog lamp switch the high beam indercator comes on dimmly, if you turn the headlights off then on the fog lamps come on but if you try the high beams the fogs go off but you cant turn them on again untill you turn off and on the key.
I was thinking either the combination switch or the fog lamp relay
| Thread Tools | |
| Display Modes | |
| 09 Impreza - park lights and fogs/fogs and high beams | ST3 | Electrical & Lighting | 2 | 07-24-2009 12:40 PM |
| Fogs & High Beams Too Much Juice? | zarseven | Car Audio, Video & Security | 5 | 01-19-2003 10:58 PM |
| NEED HID looking fog and high beam bulbs to match | IA Performance | Interior & Exterior Modification | 8 | 11-07-2002 05:14 PM |
| Fog light + High beam | Jerry | Interior & Exterior Modification | 1 | 08-17-2001 06:22 AM |
