Old 03-04-2012, 10:09 PM   #1
hella_sti
Member#: 139289
2003 WRX Wagon
Default washing car outside with hot water-in the winter
so I live in the upper midwest and today I decided to take my 50 foot hose and hook it up to my washing machine valve downstairs and wash my car in the 28 degree weather outside. It worked fantastic! I was able to melt all the snow and ice from my driveway at the same time and also get all the grime and grit off easily (maybe even easier) than I could with cold water I normally use int he summer. My question being is what if any drawbacks besides potential hard water spots do I incur from a straight hot water wash? I'm thinking about hard plumbing a hot water spout in my garage now, I got a quick lesson in physics when I unhooked the hose from downstairs
here is a quick picture, notice the car buried in the snow across the street
hella_sti is offline   Reply With Quote
Old 03-04-2012, 10:59 PM   #2
silvercookie
Member#: 180033
2005 WRX
I do luke warm water washes during the winter as well at my aunts house.
good thing her washing machine/sink is in the garage lol.
Just be careful when you spray the hot water on the windows.
It could cause them to crack from the quick temperature change.
silvercookie is offline   Reply With Quote
Old 03-04-2012, 11:11 PM   #3
DavC825
Member#: 201736
12 IS-F..its white
07 Sti Blk
your windows might crack. not the best idea, but hey if it makes you happy....
DavC825 is offline   Reply With Quote
Old 03-04-2012, 11:55 PM   #4
2001Impreza
Member#: 312511
2001 2.5rs
Gloss black
Haha thats crazy i would have never thought of doing that may have to next winter
2001Impreza is offline   Reply With Quote
Old 03-05-2012, 12:37 AM   #5
hella_sti
Member#: 139289
2003 WRX Wagon
The window thing did come to mind, but then I remembered how many things have bounced off of them and I doubt a little warm water will do anything. Has anyone ever seen anything like that actually happen? THe windshield is a laminate so I know it won't crack. Maybe its best to do this after I've been driving a while with the defrost on.
edit:I just googled it and it more the hot glass going into cold water theory transcending everyone on here, when in all actuality the temperature difference would have to be over 100 degrees Fahrenheit at minimum to break the glass, the windows being 30 degrees and the water heater being set at 130 and the thermal loss through the hose I think I'm safe.
Old 03-05-2012, 12:59 AM   #6
thought
Member#: 190441
2011 STi Hatch
lost 2 windshields from a small rock chip followed by defroster air & highway cold driving "crack!" it is intense.
but warm water wont give you that temp difference with the car stationary (no wind chill)
thought is offline   Reply With Quote
Old 03-05-2012, 11:41 PM   #7
hella_sti
Member#: 139289
2003 WRX Wagon
wind chill is the feeling that your skin has as a direct affect on temperature and wind combined. Your car or anything with out skin or nerves is not or cannot "feel" wind chill or a perceived difference in cold as it becomes more "windy" your car's temp is -30 regardless if the wind is blowing at 0 mph or 100 mph, there is zero difference.
Old 03-05-2012, 11:55 PM   #8
Electioneer
Member#: 284866
1998 Full RSTi Swap
Metallic Grey
Well put. I've never been able to articulate this when I try to explain it to people.
Electioneer is offline   Reply With Quote
Old 03-05-2012, 11:58 PM   #9
Tdaz250
Member#: 310744
02 WRX
X2. Be careful with the windows. I usually fill my bucket up with hot water when washing the cars but i've never hooked the hose up to hot water
Tdaz250 is offline   Reply With Quote
Old 03-06-2012, 04:17 PM   #10
unparent
Member#: 124821
2006 wrx wagon
silvery
One of my friends with a DB9 had a hot water tap installed on the outside next to the normal tap. Used a second hose and it was awesome during winter months. Not the most economical method, but awesome if you can afford it...
unparent is offline   Reply With Quote
Old 03-07-2012, 09:55 PM   #11
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
I suppose it depends on what temperature you keep your water heater at. Anyone with children shouldn't have it above 120 degrees F. That would seem safe to wash a cold car with. I prefer mine around 140. If I had a tank-less heater I'd even go up to 160, which probably I wouldn't want to wash a cold car with.
Xafen is offline   Reply With Quote
Old 03-13-2012, 12:19 AM   #12
GFB
Member#: 281725
2006 STI
While I don't disagree with what you found, I have seen this happen, but a different method. Neighbor many years back took a bucket of hot water outside to wash the salt off his windshield, just tossed the whole thing on at once. Poof.
GFB is offline   Reply With Quote
Old 03-13-2012, 12:22 PM   #13
2ndSubie
Member#: 313418
2012 IMPREZA
(first post, yeah!)
I have managed for 2 different express wash companys over the past 8 years. My experience is that the windshield would not crack if it were not already damaged in some way. An average day washes about 400 cars, why would that one car be the only one that cracked its windshield unless its intregrity had already been compromised. (This is not an excuse either, we have always taken care of those customers unless it was obviously cracked already.)
Hot and cold expands and contracts everything from metal to concrete. Think about the expansion cracks in a drive way or roadway (they're there for a reason.) Think about the old dry ice trick for popping out a hail dent (from extreme heat to extreme cold causes the sheet metal to bend itslef back.) I dont know if glass can exp./cont. in that same way but the temp change must aid in the glass cracking if it is already damaged. So my suggestion would be to stay away from adding any more stress to an already stressed piece of glass in such cold weather if it already has chips that may lead to a crack across the whole thing.
2ndSubie is offline   Reply With Quote
Old 03-13-2012, 12:32 PM   #14
2ndSubie
Member#: 313418
2012 IMPREZA
BTW, if its below freezing outside any water still on the vehicle will freeze shortly after application be it heated or not. Be sure to dry it off thoroughly and quickly. A clean car covered in ice is not the best sealant; stick with wax. And no matter how well its dried, if it sits outside you may have a little trouble getting back into the car (dang frozen door handles!)
Old 03-13-2012, 01:20 PM   #15
mejifair
Member#: 11356
2012 WRX STi Hatch
The user manual says that we should not use hot water to wash the car.
Section 10-2 of my manual (2012 STi) says "Do not wash the vehicle with hot water and in direct sunlight"
Not sure why, but it was specifically stated, so it should at least be noted.
mejifair is offline   Reply With Quote
Old 03-14-2012, 02:52 PM   #16
guitarman19853
Member#: 290734
2012 WRB WRX Hatch
2015 Forester XT
Check out Optimum No-Rinse Wash & Shine. I just washed my car in my garage with no hose using this method and am very surprised with the quality of the results. Follow the directions and you won't mar your paint. I would be comfortable doing this outside (if you don't have a garage) in the winter with warm (not hot) water just so your hands don't freeze.
guitarman19853 is offline   Reply With Quote
Old 03-14-2012, 10:17 PM   #17
emazz104
Member#: 281811
04 WRX
World Rally Blue
I don't wash mine on really cold days, but I try to lightly spray the windows at first, I know it probably won't matter, but whatever.
We have a hot water spout with a cold water one, and I used it a few times over the winter, then dried it, and left it in the garage overnight to make sure the water was completely out of the doors/windows/all that stuff, and it's worked out great!
emazz104 is offline   Reply With Quote
How do you wash your car during the winter? PoweredbyJun Mid West Subaru Owners Club Forum -- MWSOC 63 01-12-2007 11:11 PM
Do southern states get annoyingly inundated with birds during the winter? Cosworth Off-Topic 21 09-26-2006 07:49 PM
how do you guys wash your cars in the winter??? 516_WRX Tri-State Area Forum 35 12-09-2005 11:07 AM
Anyone else sticking with RE70's for the winter? AaronWRX Mid Atlantic Impreza Club -- MAIC 33 11-09-2004 06:22 PM
