Old 03-04-2012, 11:37 PM   #1
stsdude2
Member#: 307161
2008 wrx
Default everytime I Fill my gas tank, the car smells way to much like gasoline
Recently I have noticed that when ever I fill up my tank, whether its 10 dollars or 50 dollars, the inside of my wrx always smells really bad. my gas meter doesn't drop any faster, and I sniffed around the trunk to see if thats where it was coming from and found nothing. The car will air out and stop smelling after a few hours driving with the windows open, but next time I go to the pump it starts smelling, where should I be looking for a leak if I have one?
stsdude2 is offline   Reply With Quote
Old 03-04-2012, 11:45 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
take it to the dealer and have them figure it out....fuel leaks like this are bad juju....
Old 03-05-2012, 01:57 PM   #3
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Filler neck would be my guess, but if you can't find it before your next fill up, take to to the dealer, as uncle scotty suggested. Heavy fuel fumes are really bad for you, not counting if it ignites.
Bacon117 is offline   Reply With Quote
Old 03-05-2012, 02:40 PM   #4
1quickSTI
Member#: 301289
05 STi
If youve done a fuel pump install, make sure there are no broken bolts and you're not missing your gasket (happens alot ironically). If not, filler neck.
1quickSTI is offline   Reply With Quote
Old 03-05-2012, 08:14 PM   #5
stsdude2
Member#: 307161
2008 wrx
no fuel pump, probably the neck then, how can I access visibility of the filler neck from inside the car?
Old 03-05-2012, 08:51 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
you need a mechanic....
Old 03-05-2012, 08:58 PM   #7
EdHilario
Member#: 137398
2004 Impreza
^ Agreed.
EdHilario is offline   Reply With Quote
Old 03-05-2012, 09:24 PM   #8
stsdude2
Member#: 307161
2008 wrx
I am a mechanic, or at least in training. Thats why I am trying to get an idea of where I should be looking.
Old 03-06-2012, 09:30 AM   #9
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
What does "in training" mean? If you are at a vocational school, talk to your teacher about looking at it after class. The auto shop teachers I had were always willing to help.
And I mean no offense to you personally, but if don't know where to look for the filler neck, you are not as qualified yet as you need to be. It's like asking where the upper radiator hose would be. (Hint: start looking at the radiator). For the filler neck, start looking where you put gas in.
Old 03-06-2012, 09:48 PM   #10
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
This happened to me after I bought a SC300 with a 1jzgte swap. It turned out to be the tank vent. If I were you I'd work my way through the various components of the fuel system to rule them out and locate the issue. If any component of your fuel system has been worked on recently, start there. For instance, did you recently change your fuel filter or injectors?
1. Fuel filler neck (unlikely cause in my opinion) This is a simple system of a tube that runs to the tank. There is also an overflow hole beneath the gas cap.
2. Fuel lines - You've got 3 lines. 1 is the fuel supply 2 is the extra fuel return line and 3 is a vent line I believe (correct me if I'm wrong here guys)
3. Tank purge system - This system is designed to control tank pressure. There is a solenoid/valve that releases pressure into the carbon canister (This is a likely cause in my opinion)
Soarer is offline   Reply With Quote
Old 03-19-2012, 10:49 PM   #11
jimmy5814
Member#: 313659
2006 WRX
Ok guys. I am new here and to subies. If I am going at this the wrong way please let me know. I have an 06 WRX with an 07 STI motor. I just bought my car a month ago and I have a strong gas smell just with the windows down. I just replaced my right side tgv sensor and noticed an open vacuum line. It comes from the solenoid, or whatever it is, on the right fender bout a foot away from the firewall. It has two vacuum lines on it but 1 is disconnected and I cannot see where it would go to. I am hoping this could contribute to the fumes smell. Thanks for any info.
jimmy5814 is offline   Reply With Quote
Old 11-24-2012, 10:55 AM   #12
pmac225
Member#: 338742
1999 Impreza Outback
I have the exact same problem on my 1999 Outback Sport. I had a mechanic replace the filler neck recently and that's when it started. I took it back and he replaced the fuel lines. I still smell fumes, but only when the windows are open. I suspect that either the filler line is defective or something wasn't connected correctly. The dealer in this area cannot handle the most routine repairs (ie wheel bearings). It would be nice to have some good theories on the cause before I take it to another mechanic.
pmac225 is offline   Reply With Quote
Old 11-24-2012, 02:49 PM   #13
jimmy5814
Member#: 313659
2006 WRX
Cool Aggravating fuel smell
Ok guys. I found my problem and thought I would add to the post. I had a vent line by the solenoid by the fuel tank that had cracked and came disconnected. Fixed the line and smell gone!
Maybe enjoying the car a little to much! shakur45 Impreza Forum 11 01-24-2008 01:09 AM
45bucks to fill my gas tank!!!!!! SQ3.0dotJP Off-Topic 55 05-20-2007 02:21 PM
Cant fill up my gas tank !!!! datsbad Pre-2002 Factory Turbo Powertrain 1 09-09-2006 02:38 AM
I just paid $40 to fill my gas tank fatray Mid Atlantic Impreza Club -- MAIC 27 08-31-2005 01:42 PM
Cant Fill Up My Gas Tank!!! HELP!! TicalWRX New England Impreza Club Forum -- NESIC 11 01-14-2004 12:24 AM
