Old 03-05-2012, 02:03 AM   #1
Ndasilva
Member#: 311112
2004 WRX Wagon
Default AC problems 04 WRX
So I bought my car and they didn't tell me the A/C didn't work. Shame on me for not testing it. So I am very lost. When I turned my AC on it was blowing outside temp air. I purchased the recharge can with the gauge. It was pretty much all the way low before I charged the system, It blew cold air but when I parked my car it had alittle bit of steam coming from the engine bay, couldn't locate where though. 4 hours later I got in my car and turned the AC on and back to outside air temp.... Help please?
Ndasilva is offline   Reply With Quote
Old 03-05-2012, 02:23 AM   #2
Rally Monkey
Member#: 36310
03 WRX Sedan
Could be a leak in many places....but the high pressure hose is notorious for going bad.
Rally Monkey is offline   Reply With Quote
Old 03-05-2012, 10:53 AM   #3
Ndasilva
Member#: 311112
2004 WRX Wagon
Ok, sounds like I should recharge with a uv can then?
Old 03-05-2012, 06:10 PM   #4
Rally Monkey
Member#: 36310
03 WRX Sedan
The system is empty from a leak, you have contaminates and moisture in there now. It should be under vacuum for a while to clean out before recharging, I would take it somewhere that has an A/C machine. They can use an electric sniffer or UV to find the leak and charge it properly with the right amount of refrigerant and oil. If you have the gear, do the UV test, repair the leak and then take it to a charging machine.
Old 03-05-2012, 06:29 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Go to a shop and have it diagnosed, repaired and recharged properly. The DIY-in-a-can recharge kits are crap and while you might get working AC in the short term, you can end up with very expensive problems later on.
Old 03-07-2012, 01:37 PM   #6
lolol
Member#: 311801
If you have a small leak, continuing to top off before going totally flat will prevent the system from ingesting contamination. Once its totally flat, the system is likely contaminated with moisture, so a new dryer at the time of repair is recommend. Before the new dryer, the system will have to be evacuated and held at several microns of vacuum for a few hours to remove moisture.
The lubricant used with R-134a has greater affinity for water and vacuuming will not totally remove it like mineral oil in R-12.
lolol is offline   Reply With Quote
FS : AC Condensor 04 WRX Penguin_02 SCIC Private Classifieds 10 09-01-2010 06:54 PM
WTB DFW: AC Compressor 04 WRX qjumpr TXIC Private Classifieds 1 04-15-2009 04:37 PM
Koyo Radiator Problems! 04 WRX peteypabs163 Water/Methanol Injection, Nitrous & Intercooler Cooling 6 02-23-2008 03:23 PM
04 Forester AC problems anyone else? jrhyno Forester Forum 4 08-07-2007 11:20 PM
Boost Problem? 04 WRX xchristensen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-03-2007 04:05 PM
