#1 |
Member#: 11005
TXIC
Vehicle:2006 spec. B silver |
This weekend I built an OEM Switch for my garage door and hard-wired it into my WRX.
This overall was pretty easy – I build the switch, then took apart the garage door opener. I soldered a second switch to the button and run the wires out through a hole put in the case. The wires are epoxied into the case, so they won’t pull off.
#2 |
Member#: 11005
TXIC
Completed fob modification.
#3 |
Member#: 11005
TXIC
Completed system with switch.
#4 |
Member#: 11005
TXIC
And... finished product.
![]() Just to the left of the change tray on the inside is where the fob is located. |
#5 |
Member#: 12119
Vehicle:2002 Impreza WRX Saltiest Cracka N Da Hood |
That looks great! I assume you wired it up to the cars power system?
#6 | |
Member#: 11005
TXIC
- that completely skipped my mind. I'll throw that on my to-do list for tonight. |
#7 |
Member#: 7170
NESIC
Vehicle:Aut Kaiser, aut nullus. |
Would that require changing the voltage? I thought garage door openers run on like 3 or 6 volts max?
#8 |
Member#: 12119
Get a voltage regulator. You're going to need to step the power down from 12V. You can get a voltage regulator IC at the Shack for $2.00
#9 |
Member#: 19971
Vehicle:2003 Impreza WRX the best blue- WR Blue |
whered you get the switch?
#10 |
Member#: 44927
Vehicle:'04 WRX STi WRB |
Just put in a battery and change it once every two or three years.
#11 | |
Member#: 32636
Vehicle:2004 Impreza STi Silver/Silver |
offset |
#12 |
Member#: 12537
Vehicle:'02 WRX Sportwagon WR Blue Pearl |
Both my garage door openers used a twelve volt battery. So no voltage shift necessary. I took the cases apart and bundled up the circuit boards with insulating material and duct tape and installed them in the headliner to the right of the map lights. Power comes from the map light circuit -- constant power. I have two switches from Radio Shack mounted in the same location as maclif.
There is a write up on Scoobymods on this that I think I contributed to. |
| Thread Tools | |
| Display Modes | |
| Hr: Help Garage Door Opener Wont Open | ultraspdWRX | Mid Atlantic Impreza Club -- MAIC | 3 | 06-27-2009 11:53 AM |
| Need info on garage door openers and installation | wrx2k4blue | Off-Topic | 21 | 08-28-2006 01:44 PM |
| Mirror w/Garage door opener | Pow | Baja Forum | 2 | 12-15-2005 03:13 PM |
| Garage Door Opener Switch | mosqito16 | Interior & Exterior Modification | 4 | 03-27-2004 12:08 PM |
| Gauging Interest: Garage Door Opener FS | rogue | Mid Atlantic Impreza Club -- MAIC | 2 | 07-03-2003 07:19 AM |
