Alaskan Impreza Club
Old 03-05-2012, 11:08 AM   #1
DaBlueSquirrel
Member#: 311480
Default Someone help PPPPLLLEEEAAAASSSSEEEE
So I can hook up my accessport, or even my computer using the access tuner, it will read at idle or REALLY light driving. Anytime I try to datalog a WOT pass it stops working and tells me that there is something wrong with the connection. Any thoughts ?????
DaBlueSquirrel is offline   Reply With Quote
Old 03-05-2012, 02:07 PM   #2
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
loose connection? make sure the cable is secure in the back of the AP and into the OBDII port.
Mavrik is offline   Reply With Quote
Old 03-05-2012, 03:34 PM   #3
AK SloPok
Member#: 56464
12 Ram
OK, I have had this issue several times before. First step is to update your AP to the latest firmware. Then, go by RadioShak or similar and get to barrel magnets to snap over your USB cord between the dongle and AP. You shouldn't have any more issues. If you do, check to see how many parameters you are logging and don's select more than 10. Let us know what you find...
AK SloPok is offline   Reply With Quote
Old 03-05-2012, 03:45 PM   #4
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
interesting solution........
i had this problem also with the cobb all the time. it happens occasionally with romraider but its loose connections normally
Alaskan EJ20 is offline   Reply With Quote
Old 03-06-2012, 04:28 PM   #5
White_Rice
Member#: 160049
For some reason Mine always came up as a JDM car lol.
White_Rice is offline   Reply With Quote
Old 03-15-2012, 06:33 AM   #6
DaBlueSquirrel
Member#: 311480
Ok so just a little update.
I checked to see if any cables or pins were loose and all seemed well (i work on electronics for a living) I went as far as taking apart the Dongle to make sure all the solder points were good. I then replaced the cable with a good quality NEW cable and tried again.
It will log up until I let off the gas. As soon as I let off the gas it switches back to the screen saying it lost connectivity and wont capture the log. I then have to unplug and plug it back in. I am getting irritated that I cannot do a damn log. Also it is set to default parameters so Im only logging the bare min.
Any ideas?
Old 03-15-2012, 12:05 PM   #7
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
Chad gave you some good points that most of us use... You most likely need ferrite beads for the cable, when the cable picks up high-frequency interference on the shield of the cable, it can cause these issues.
retrac is offline   Reply With Quote
Old 03-15-2012, 12:10 PM   #8
DaBlueSquirrel
Member#: 311480
Im not sure what exactly ferrite beads are . I havent heard of them before.
Old 03-15-2012, 12:12 PM   #9
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
http://lmgtfy.com/?q=ferrite+beads
Old 03-15-2012, 12:16 PM   #10
DaBlueSquirrel
Member#: 311480
LOL already googled it. Ive used them on larger scale but they werent called ferrit beads. I will try it out today and keep everyone informed of my results.
Old 03-15-2012, 04:28 PM   #11
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
Lol @ Ferrit Beads. I'm thinking "that's not legal is some states".
Dominator is offline   Reply With Quote
Old 03-15-2012, 05:20 PM   #12
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
Any ideas?
take the obd 2 port out of the under dash and tape them together.
Old 03-15-2012, 07:02 PM   #13
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
I found that using the tactrix OB2 extension cable worked very well. It's designed to plug in differently than most OB2 cables (from the side, not straight like an accessport or generic ob2 readers/etc)... so it fits better, less likely to knock it out etc. Plus it's like 15 dollars..
kayetealynn is offline   Reply With Quote
Old 03-15-2012, 11:26 PM   #14
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
The Cobb dongles are famous for failing this way. The port in the car may be worn as well. The above post is a good idea and then you can tape up or zip tie the cobb wires so they cannot move.
P3Auto is offline   Reply With Quote
Old 03-15-2012, 11:35 PM   #15
07_STi
Member#: 290953
grrr those dongles are a damn pain in my ass. i've been through like 3 already damnit, i recently just broke another and i still have to order one.
07_STi is offline   Reply With Quote
Old 03-16-2012, 11:39 PM   #16
DaBlueSquirrel
Member#: 311480
I would like to thank everyone for there help. I recorded my first datalog today i went and bought the Ferrite Chokes today and all is well. i was lost when everyone said ferrite beads. lol but all in all it works great now. Below is a link of what i used just in case anyone else needs the info. Thanks again for everyone's assistance.
http://www.iautomate.com/products/Fe...allations.html
Old 03-16-2012, 11:45 PM   #17
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
if you removed your whole EVAP unit (charcoal canister) i would like to see that at some point as i plan to do this as well...you live off badger?
cosseywrx is offline   Reply With Quote
Old 03-17-2012, 12:20 AM   #18
DaBlueSquirrel
Member#: 311480
Havent removed anything yet, Just trying to get the car up to par first. And yes I do live off badger lol right baout where you seen me that day. My wife works at Badger gas too so she comes home every day and tell me which Subies she saw LOL
Old 03-17-2012, 02:00 AM   #19
Quasimodo_ak
Member#: 310012
That's funny and cool at the same time lol. Hope to meet up with all you guys soon!
Quasimodo_ak is offline   Reply With Quote
('93-'01) Grrrrrr.... no smiley faces~! LttLDGN Impreza Forum 5 10-21-2001 10:48 AM
Grrrrrr! joltdudeuc Bay Area Impreza Club Forum -- BAIC 9 10-12-2001 12:42 PM
Grrrrrr! I hate my car now!!! Boom New England Impreza Club Forum -- NESIC 16 05-31-2001 02:25 PM
Grrrrrr, this board is gonna be the death of me... JC General Forum Archive 5 09-17-2000 11:12 PM
Flat spot in acceleration!!!!!! grrrrrr! SubieRacer Technical Forum Archive 29 05-23-2000 12:01 PM
