Old 03-05-2012, 04:28 PM   #1
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
Default 2012 Impreza 2.0i Gauges &Center LCD Readout
While I was playing around trying to figure out the stabilty control functionality for another thread I started, I noticed that as the car started up (while all the lights on the dash and the gauges cycle) the word "SPORT" is displayed in the upper left corner of the center LCD screen between the tach and speedo.
Do I have a "Sport" mode? I can't think of any reason why my car would have this light. It does not illuminate when in "M" mode while driving, or when I press the VSC off button. Tried holding down a paddle shifter (or both) for a couple seconds to see if there is some hidden feature, nothin'. There is no reference to it in the owners manual anywhere, read the whole book through the other day, and re-checked again last night. The only reasonable explanation I can come up with is its a feature not offered in the U.S. Anyone have a Canada spec. Impreza with this?
riccnick is offline   Reply With Quote
Old 03-05-2012, 04:36 PM   #2
Furiousd1983
Member#: 295099
2013 Not so Hot HB
That probably comes from the fact that it uses the same cluster as the STI. Mine shows the Standard Sport Intelligent mode lights even thought the car doesn't have that functionality
Furiousd1983 is online now   Reply With Quote
Old 03-05-2012, 05:47 PM   #3
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
Completely different cluster. Is the image coming through? I noticed it was working at work, but now I'm home its not showing? Ill try again...
Old 03-05-2012, 06:27 PM   #4
Furiousd1983
Member#: 295099
2013 Not so Hot HB
broken image
Old 03-05-2012, 10:36 PM   #5
jweitzel24
Member#: 310957
2015 WRX Premium
CWP
I saw the exact same thing this morning, right above the gas gauge on the center readout. "Sport" flashes up and then disappears as soon as the car finishes starting up.
jweitzel24 is offline   Reply With Quote
Old 03-06-2012, 12:40 PM   #6
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
Image should be there now. Had to load it up on FB. Noticed the Forester that has the optional gauges has this, it is shown right on the Subaru website. Another thought that crossed my mind is: on the base models without the paddle shifters, but with the CVT, when you put it in "L", does this light up? Just curious. My dads Murano had a Sport mode, and all it did was keep the motor in the 3,000-6,000 RPM range instead of letting the CVT upshift. I understand that "L" should work the same way, although Subaru does not advertise this feature as sporty.
Old 03-06-2012, 01:27 PM   #7
Xarthan
Member#: 312318
2012 Impreza Sport
ISM
I found this on a Road and Track review
http://www.roadandtrack.com/tests/dr...subaru-impreza
When in sport mode, the transmission will hold the selected ratio, giving you the ability to run in higher rev ranges than would be allowed in full automatic mode.
Not sure how you turn it on.
Xarthan is offline   Reply With Quote
Old 03-06-2012, 02:50 PM   #8
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
The author must be referring to "M" mode as "Sport" mode. He didn't mention if the light was on. Jeeze, what was he thinking! Lol.
Old 03-10-2012, 08:41 AM   #9
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Can't you enable sport mode by moving the gearbox shifter to the right?
pkL is offline   Reply With Quote
Old 03-11-2012, 08:01 PM   #10
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
Nope, not on my car at least. Can you?
Old 03-13-2012, 12:58 PM   #11
pkL
Member#: 313093
2012 Impreza 2.0i
Yeah I can but I have a different trim on mine.
My gearbox shifter looks like this:
Old 03-13-2012, 10:45 PM   #12
Alairmore
Member#: 309242
2012 Impreza
So when you move your shifter over the the "M" area the word "sport" is displayed on the center LCD screen?
I have the exact same gear box with paddle shifters but "sport" isn't displayed when I'm in manual mode.
Alairmore is offline   Reply With Quote
Old 03-13-2012, 10:50 PM   #13
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
I have the same shifter my friend.
^This is what I'm getting at. My Sport light doesn't show up. pkl, does yours?
Old 03-14-2012, 01:36 PM   #14
pkL
Member#: 313093
2012 Impreza 2.0i
Yeah I do from what I recall, I will take a picture of it later. But then again mine is a Canadian spec sport though.
Old 03-14-2012, 02:20 PM   #15
tornado542
Member#: 280370
2012 Sport Premium
Ice Silver Metallic
I dont know what you guys are talking about...my 2012 shifter looks like this...
tornado542 is offline   Reply With Quote
Old 03-14-2012, 04:02 PM   #16
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
nice try
saabarupp is offline   Reply With Quote
Old 03-14-2012, 10:10 PM   #17
pkL
Member#: 313093
2012 Impreza 2.0i
LOL nice try there.
Old 03-15-2012, 12:19 PM   #18
pkL
Member#: 313093
2012 Impreza 2.0i
Hmm..I just checked and realized the word sport never lights up except when you start your car and even then its quite brief.
Old 03-15-2012, 04:57 PM   #19
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
^Almost....
yeah, pkl, thats what I'm gettin at bro, it cycles on when you start the car, but then goes off. This car is full of stuff that doesn't make sense electronic wise. Just like the stability control off button that doesn't actually turn the stability control off...
Old 03-15-2012, 08:20 PM   #20
kufman
Member#: 313453
2012 Sport Premium
What does everyone think of the new speedometer? Personally, I dislike it. I don't see the need to have every 2.5 mph marked. Makes it confusing when only the even 10's are numbered and there are so many marks in between. I find myself looking down a lot and saying, Where is 35? or 55? I don't know about other states, but Illinois doesn't have speed limits posted as 37.5 mph!
kufman is offline   Reply With Quote
Old 03-16-2012, 04:02 PM   #21
kevinsUBARU
Member#: 2263
2012 Impreza Sport
There is also a DIESEL indicator on the LCD. Next time you catch a glare on your display, you may be able to see it.
kevinsUBARU is offline   Reply With Quote
Old 03-18-2012, 08:19 AM   #22
pkL
Member#: 313093
2012 Impreza 2.0i
Wow really? I haven't really paid much attention, I guess they used the same electronics for the car worldwide. I'll upload a picture of my dash/tachometer later.
Old 03-18-2012, 11:26 AM   #23
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
There are many different indicators on the center display that are not applicable to the USDM Impreza. I am sure they reuse the display instead of making separate ones for each country.
ST Eye is offline   Reply With Quote
Old 03-19-2012, 10:51 AM   #24
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
Ive seen the Diesel light a couple times in direct sunlight. My guess for the Sport light is that its for the Forester. Anyone have a new Forester to confirm?
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
('11-'14) 2012 Impreza 2.0i Stability Control Function riccnick Impreza Forum 420 02-14-2015 05:53 PM
2012 Impreza 2.0i Gas Mileage Thread Benchmark General Community 934 10-08-2013 02:49 PM
[REQUEST TO MODS] 2012 Impreza 2.0i only forum please? tornado542 General Community 10 04-26-2012 05:07 PM
2012 Subaru Impreza 2.0i Break-In Period Arseezy Newbies & FAQs 7 02-14-2012 08:28 PM
