Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > 1993 - 2001 Impreza Specific Parts
Old 03-05-2012, 06:36 PM   #1
danverco
Member Sales Rating: (6)
Member#: 156015
2001 GM8-t STi swap
Default 2001 RS parts, Blow out sale! make offer
Below are from a 2001 2.5 RS Impreza parts only have 73k miles. Some parts will not be shipped please check with me first. PM me for quickest response, thx
>Radiator with fans and hoses! 150$
>Front brake calipers will fit WRX and RS 2.5
>Cruise control module unit 87022FA130
>AC condenser in working condition some bends but still holds pressure fine, 80$
>Drive shaft (off the 5 speed manual RS 2.5), 50$
>Steering column with good key and ignition, 45$, (one lever is jacked up)
>Top and bottom covers to the steering column the plastic clam shells, 30$ for the set
>Entire Fuel tank with working Float level and evaporative system only 73k miles on it, 65$ OBO!!!
>Rack and Pinion steering rack, perfect working condition, 160$ (New these are $350 + a core deposit charge)
>Brake Master cylinder and vacuum chamber 50$
>Brake ABS in engine head unit with brake lines 75$ obo
>Brake wheel sensors good working condition, 45$ each (these are 150$ new)
>NA. Front Cross Member 45$
>Left (driver) side control arm 30$
>End mount for both control arms 20$ a side
>Rear rotors USED 5x100 in usable condition, 25$ a set
>Front rotors USED 5x100 in usable condition, 25$ a set
>Trailing arms 30$ each side 50$ for both sides
>Sway bars, front or rear 20$ each
>Door lock timer unit, 20$
>N/A exhaust header 2.5L, 60$ OBO
1997 Impreza L parts below with unknown miles:
>2.2L rear drum brakes and knuckle and hubs with working wheel bearings not sure how good. 100 both side
>SOHC heads off a ej22t
>SOHC timing belt cover
>VF11 working turbo, 80$
>5 speed transmission unkniwn miles, make offer
>R160 4.11 rear differential open NON-LSD, make offer
>Gauge Cluster 40$ with 197,xxx on it
>HVAC controls, working condition 25$
>dash pad in good condition 35$
>front or rear sway bars and endlinks, offer
>SOHC heads working condition off a ej22t
>Intake manifold, make offer
>control arms 30$ each side
danverco is offline   Reply With Quote
Old 03-05-2012, 10:56 PM   #2
Gonz#75
Member Sales Rating: (3)
Member#: 101841
1998 2.5RS
mostly black
You don't happen to have the stock end links do you?
Gonz#75 is offline   Reply With Quote
Old 03-06-2012, 02:36 PM   #3
danverco
Member#: 156015
2001 GM8-t STi swap
yes I have rear endlink for sale too.
Old 03-06-2012, 09:48 PM   #4
2001Impreza
Member#: 312511
2001 2.5rs
Gloss black
how much for the wheel my stitching is worn out and shipped to 17350
2001Impreza is offline   Reply With Quote
Old 03-12-2012, 11:29 AM   #5
danverco
Member#: 156015
2001 GM8-t STi swap
steering wheel is still here
Old 03-21-2012, 11:29 AM   #6
danverco
Member#: 156015
2001 GM8-t STi swap
everything is still for sale
Old 03-22-2012, 02:09 AM   #7
RALLCRAP
Member#: 177038
2001 Impreza 2.5RS
BRP
do you have the radiator? if so, how much?
RALLCRAP is offline   Reply With Quote
Old 03-22-2012, 05:52 PM   #8
danverco
Member#: 156015
2001 GM8-t STi swap
FYI
Subaru OEM radiators could possibly be the cheapest most unreliable P.O.S. ever manufactured.
IMO it’s the first thing you should replace on any Subaru.
I know for a fact that EBay all Aluminum radiators for around 100$ (yes Chinese made) are 10X better!
Get yourself one they are tits!
no I dont have a radiator for sale
Old 03-30-2012, 03:07 PM   #9
danverco
Member#: 156015
2001 GM8-t STi swap
still for sale
Old 03-31-2012, 01:15 AM   #10
ThaPuertoRican15
Member#: 245018
01 RS
STM
you wouldnt happen to be selling the wiring harness, would you? PM me and let me know. thanks
ThaPuertoRican15 is offline   Reply With Quote
Old 04-02-2012, 04:07 PM   #11
danverco
Member#: 156015
2001 GM8-t STi swap
no wiring harness for sale, everything else is still for SALE!!
Old 04-05-2012, 01:45 AM   #12
bouncer2326
Member Sales Rating: (2)
Member#: 246333
1996 L Wagon w/ ej25
Any chance you have headlights?
bouncer2326 is offline   Reply With Quote
Old 04-08-2012, 10:49 AM   #13
danverco
Member#: 156015
2001 GM8-t STi swap
I found: >Shifter w/linkage and the Pedal assembly see ad for details
Old 04-09-2012, 06:06 PM   #14
Jynxi
Member#: 315462
97 Impreza OBS
do you have the downstream O2 sensor?
Jynxi is offline   Reply With Quote
Old 04-12-2012, 04:37 PM   #15
danverco
Member#: 156015
2001 GM8-t STi swap
prices lowered bump
Old 04-16-2012, 11:05 AM   #16
danverco
Member#: 156015
2001 GM8-t STi swap
good parts still left bump
Old 04-19-2012, 05:26 PM   #17
peanutloc
Member Sales Rating: (5)
Member#: 269273
1999 GM4
Aspen White Gurl
is your cruise module for manual tranny?
peanutloc is offline   Reply With Quote
Old 04-23-2012, 08:19 PM   #18
07wrxstage2
Member Sales Rating: (28)
Member#: 262366
2006 OBP STI
2000 BRP IMPREZA 2.5RS
How much shipped to 21157 for steering rack and pinion?
07wrxstage2 is online now   Reply With Quote
Old 06-13-2012, 10:59 PM   #19
danverco
Member#: 156015
2001 GM8-t STi swap
updated ad bump
Old 08-13-2012, 12:46 AM   #20
lovemetal626
Member Sales Rating: (1)
Member#: 327820
do you know if the rack and pinion would fit in a 98 impreza outback?
if so, i would like to purchase it.
lovemetal626 is offline   Reply With Quote
Old 08-13-2012, 03:18 AM   #21
93GC8AWD
Member#: 245268
1993 Impreza L Wagon
If you still have the HVAC control in 2 Weeks, I'll buy it
93GC8AWD is offline   Reply With Quote
Old 08-17-2012, 11:40 PM   #22
Roly2288
Member#: 329467
How much for the ej22t heads?
Roly2288 is offline   Reply With Quote
Old 08-19-2012, 12:50 PM   #23
stevo
Member#: 56437
Any interior trim?
stevo is offline   Reply With Quote
Old 05-18-2013, 11:04 AM   #24
danverco
Member#: 156015
2001 GM8-t STi swap
updated list everything is still for sale
Stock 2001 RS parts for sale Halforc Private 'For Sale' Classifieds 4 11-06-2004 12:19 PM
2001 RS parts blowout! cheap! Darwin Bay Area Impreza Club Forum -- BAIC 0 07-22-2004 05:23 PM
2001 RS Parts on 2002 RS NowUcMeNowUdont Normally Aspirated Powertrain 12 08-15-2002 08:41 PM
2001 2.5 RS Parts for Sale emat5 North West Impreza Club Forum -- NWIC 22 05-09-2002 09:40 PM
2001 RS Parts for sale imprezaf Tri-State Area Forum 0 03-11-2002 07:29 PM
Message Board Statistics All times are GMT -4. The time now is 08:30 PM.
