Old 03-05-2012, 11:12 PM   #1
wiretap_MD
Member#: 276395
2011 GVF
Default DIY Turbo Timer Installation (Apex-i unit with HKS harness)
A turbo timer is a nice DIY mod project that helps cool down your turbo by allowing the engine to remain idling for a user-defined duration even if you turn off the ignition switch, exit, and lock the car. Theoretically, it helps prolong turbo life by allowing the oil to circulate in the turbo and give it enough lubrication, as well as allowing the coolant to circulate before shutting it off. Proponents say that shutting off the engine immediately after a hard or sustained run with lots of turbo spool prevents the turbo from properly cooling off, allows the oil to "cake", and would lead to problems later on. Installing a turbo timer in a subaru engine is very controversial, with lots of debate and discussion about it since it is already for both an oil and water-cooled unit. Let's leave the discussion to another time and topic but for now, I'd like to describe the steps on installing one in the GVF if ever you decide to go the route of installing a TT.
There are several TT units available in the market. I chose the Apex-i version because I had good experience with this in my Nissan Patrol diesel SUV and it was offered at a very good price that made it very tempting. What is good about the STI is that there are several aftermarket companies that have offered a plug and play solution to installing a turbo timer. One of this is HKS, whose wiring harness allows you to merely plug it in with no splicing whatsoever. Also, the HKS harness is also compatible with other TT brands like Blitz.
Unboxed Apex-i TT unit:
The unit comes with instructions (which need good English 101 corrections) for connecting to the optional harness or if you need to splice the wires directly. If ever you decide to go the harness route, you would still need to connect 2 wires manually: black wire which you hook up to any grounded bolt, and the gray wire to the handbrake wire. I believe it is essential that the gray wire be hooked up with the handbrake wire switch since it acts as a safety measure that prevents TT activation/countdown when the handbrake is not engaged.
Picture of the HKS harness:
This project was done in conjunction with my alcantara shift and handbrake boot install so I had the consoles out already making installation easier.
The drivers side underconsole should be removed to facilitate routing the wires:
Once done, I attempted to look for the ignition harness and connectors under the dashboard only to find out that the connectors are in the steering column itself, specifically on the left side just in front of the turn signal indiator levers. My bad!
Installing it was as simple as removing the main harness connector and inserting the HKS harness in between and plug it back. The free end then goes to the control unit of the TT. Before you do this, please make sure you disconnect the battery ground.
I mounted the TT control unit on the left dashboard steel frame using 3M mounting tape. The included wires have more than adequate length for grounding and tapping into the parking brake. The gray parking brake wire was then snaked through under the dash and just above the steering column and secured with zip ties. The wire then snaked through under the center console to the left side of the ECU and tapped into the parking brake switch wire:
Tap connector (supplied with kit) to tap gray wire into parking brake switch wire:
Ground was tapped into a body bolt near the TT control unit mounting location.
Put all the trim back together. I mounted the TT unit just below the left front aircon vents. The nice thing about the Apex-i unit is that its small form factor allows it to be mounted in just bout any location. This is how it looks:
The TT can be manually turned on and off. If the engine is turned off with the parking brake un-engaged, it does not deploy. If turned off with the handbrake engaged, it engages and keeps the engine idling for the specified duration selected. Once the countdown timer has engaged, you can turn off the engine anytime but disengaging the handbrake or by holding the joystick button towards the left.
Of course, make sure the you leave your gearshift in neutral unless you are an A/T.
Thanks for looking!
wiretap_MD is offline   Reply With Quote
Old 03-06-2012, 01:08 AM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
ahh, such things are not needed on the wrx. a quick search would have shown that. its more of a kiddy thing. but nice write up
PARANOID56 is offline   Reply With Quote
Old 03-06-2012, 01:13 AM   #3
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Yep. Nice writeup, but a TT is 1000% unnecessary.
XanRules is offline   Reply With Quote
Old 03-06-2012, 01:17 AM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
i wouldnt say 1000% unnecessary, as everybody knows walking away from your car wile is still running "cooling off the turbo" makes the chicks wet
Old 03-06-2012, 11:20 AM   #5
sorrowfulkiller
Member#: 170439
I <3 Lamp
Turbo timers are only necessary on air cooled turbos, it won't hurt on a water cooled turbo at all though.
sorrowfulkiller is offline   Reply With Quote
Old 03-06-2012, 09:13 PM   #6
sterfore
Member#: 235359
2004 Impreza
Nice write up doc.
sterfore is offline   Reply With Quote
Old 02-11-2013, 10:43 PM   #7
felya589
Member#: 201073
2004 WRX STi
did you have issues fitting the steering column cover after the harness was installed?
felya589 is offline   Reply With Quote
HKS type-1 turbo timer install (pics) BlueRidgeRS Electrical & Lighting 90 10-28-2007 12:42 AM
HKS turbo timer install alltractionWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-14-2002 11:15 AM
HKS Turbo Timer Install - Easy? wy_wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-06-2001 11:08 AM
('93-'01) HKS turbo timer installation sj208 Impreza Forum 2 08-07-2001 12:21 AM
