Old 03-06-2012, 11:25 AM   #1
belacane
Member#: 284180
1986 BRAT
Question intermittent rough idle, then stalls - P0303 code
Hi all,
...looked around on the forum, but did not find an answer to my question, so I'm asking here.
The Car:
-'02 WRX wagon (td04 turbo) no mods
-idles at about 600rpm
The Issue / Symptoms:
- intermittent rough idle that changes rapidly between 500 and 1200rpm (when stopped at a light for example)
- about 1/5 times, the car will stall with this rough idle and require a few restarts
- poorer than usual milage per gallon (don't know if it's related)
- gave me a P0303 code (cyl. 3 misfire)
I have not yet done any compression or leak down tests, but plan to when I get access to tools to do so.
Otherwise performance is fine. It has never stalled/quit on me while moving. It only stalls when I'm idling at a stop.
What I'm looking for:
I'm posting this hoping that someone might have some hints on what to check out from their own experience, but please, if you have nothing nice or helpful to say, don't waste your energy posting a response.
Thanks in advance!
belacane is offline   Reply With Quote
Old 03-06-2012, 11:31 AM   #2
mt1101
Member#: 291990
2003 BUGEYE WAGON
From numerous searches on this topic do the compression and leak test then come back with results.
mt1101 is offline   Reply With Quote
Old 03-06-2012, 11:34 AM   #3
mt1101
Member#: 291990
2003 BUGEYE WAGON
Just pray it's just the coils or plugs
Old 03-06-2012, 12:17 PM   #4
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
Try cleaning your maf.
jerbull88 is offline   Reply With Quote
Old 03-06-2012, 03:22 PM   #5
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
Clean you MAF with MAF cleaner, and clean your IACV with gasoline. This may cure your idle hunting issues. Sometimes the IACV can be beyond fixing and require a new one however.
WRXSD is offline   Reply With Quote
Old 03-14-2012, 01:11 PM   #6
belacane
Member#: 284180
1986 BRAT
Thanks much guys. Gonna get this done.
Old 03-14-2012, 01:13 PM   #7
belacane
Member#: 284180
1986 BRAT
why pray?
Old 03-14-2012, 01:35 PM   #8
mt1101
Member#: 291990
2003 BUGEYE WAGON
Bc it could be a lot worse. Definitely do what others have recommended first but for me the compression test saved a bunch of money and time...plus its easy. Good luck!
Old 03-16-2012, 10:38 PM   #9
belacane
Member#: 284180
1986 BRAT
well, before I even got to doing the compression test, I started poking around today, and found that the hose to the turbo was coming right off.
It's back in place, and we'll see if that fixes my problem!
I'll keep updated.
Old 03-17-2012, 12:42 PM   #10
bigbadbronxy2k5
Member#: 260708
Default Code 0303
I got this code on a NA 06 2.5 and unplugging the MAF and cleaning it with MAF safe cleaner from CRC cleared it up.
bigbadbronxy2k5 is offline   Reply With Quote
Old 03-19-2012, 04:12 PM   #11
belacane
Member#: 284180
1986 BRAT
I just replaced the MAF just a few months ago....hmmm.
Old 04-21-2012, 11:19 PM   #12
belacane
Member#: 284180
1986 BRAT
been away for a little while, but here's an update.
compression test results:
cyl 3 - 160 (dry) 180 (wet)
cyl 1 - 160 (dry) 175 (wet)
cyl 2 - 160 (dry) 170 (wet)
cyl 4 - 160 (dry) 175 (wet)
Spark plug from cyl 3 has oil on the threads.
any thoughts?
Old 04-22-2012, 10:29 PM   #13
nasiocanuck
Member#: 288559
2004 WRX Wagon
i had the same problem a few weeks ago, bad spark plug wire. coilpack possibly aswell?
nasiocanuck is offline   Reply With Quote
Old 04-23-2012, 12:02 AM   #14
sol_tegra
Member#: 259406
02 WRB WRX
swap coils 1 and 3 and see if the mil comes on in cylinder 1 if so then its a coil.
the oil in cyl 3 could be from leaking valve cover plug seal.
sol_tegra is offline   Reply With Quote
Old 05-06-2012, 12:14 AM   #15
belacane
Member#: 284180
1986 BRAT
are you saying that replacing the above fixed your problem?
Old 06-27-2012, 09:54 AM   #16
archangelf16
Member#: 143613
06 WRX
Bump. I'm having this same issue on my 06. What ended up fixing the problem? Did cleaning the MAF do it?
archangelf16 is offline   Reply With Quote
Old 06-27-2012, 01:12 PM   #17
iamcgr
Member#: 141685
2002 WRX (ots stg 2)
Check your ground wires.
I had a similar issue after having my clutch and timing belt replaced. The shop suggested my spark plugs needed to be replaced. While doing plugs, I noticed my ground wire was loose at the battery terminal. I tightened it and the symptoms went away. While it may not cure your issue, it's worth checking. Good Luck!
iamcgr is offline   Reply With Quote
Old 06-27-2012, 03:25 PM   #18
Performance Race Solutions
Member#: 248291
2005 Your Dream Car
What color are the plugs. is that #3 plug a different color?
Performance Race Solutions is offline   Reply With Quote
Old 06-27-2012, 06:32 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
any thoughts?
run some chevron techron injector cleaner or the lucas injector cleaner through it and replace the front o2 sensor if it is more than 5 years old
and that coilpack may be bad and you may wanna change the cam cover gaskets and the sparkplug tube seals
Old 06-27-2012, 10:14 PM   #20
dollar5th
Member#: 324540
why doesnt any post the fix to their issues?
dollar5th is offline   Reply With Quote
Old 07-01-2012, 06:07 PM   #21
jgrove15
Member#: 304184
2004 Impreza Wrx
I am having a similar issue. 04 Wrx with:
20g Bosch turbo
Invidia up pipe, downpipe and q300 catback
Car was idling very low and stalling wgen i would come to a stop. Cleaned air filter, MAF sensor IACV, visual check for leaks. Now car is idling what seems to be normal but when I stop at a light it idles around 1800 to 2000. If I rev it the idle drops back to normal between 500 and 750.
Also, I have a AEM wideband gauge that has recently stop reading. It is not reading at idle and when it does have a reading while driving it is all over the place. It runs up to 18 and then doesn't read.
Any advice or suggestions would be great.
jgrove15 is offline   Reply With Quote
Old 07-01-2012, 06:57 PM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
most rough idle issues that are not a dead/low cylinder are vac leak issues.....that means between the throttle plate and the heads
Old 07-01-2012, 06:57 PM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
20g Bosch turbo
you sound like your o2 sensors are dead
Old 07-01-2012, 07:13 PM   #24
jgrove15
Member#: 304184
2004 Impreza Wrx
Is there an easy way to check the o2 sensor or should I just replace? Are you talking about the stock 02 sensor or the wideband sensor or both.
Old 07-01-2012, 07:23 PM   #25
jgrove15
Member#: 304184
2004 Impreza Wrx
Do you think it could be the stock o2 sensor or the wideband sensor or both? Is there a way to check if they are bad or just replace?
Running rich, trouble starting & intermittent rough idle turbojoe Service & Maintenance 2 09-23-2012 12:20 PM
VERY Rough Idle then Stall (wanna borrow HKS SSQV) Scoobie2.0 Mid West Subaru Owners Club Forum -- MWSOC 2 10-04-2009 11:13 AM
05 OBS very rough idle after service - intermittent Im a sock Newbies & FAQs 5 11-26-2007 07:40 PM
Rough idle and stalling directly related to MAF kingtut12 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-21-2005 05:39 PM
boost then low idle then stall? please help me!!?? zavala Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-03-2004 04:58 PM
