Old 03-06-2012, 02:03 PM   #1
Bpatts
Member#: 288358
2005 Wrx Sedan
Default Revving engine after oil change?
Car: 2005 WRX sedan
Mileage: 92722
I decided to switch from penzoil to Valvoline High Mileage 5w30 engine oil. I took it to a place down the road that is an independent oil change place and NOT a Jiffy Lube or anything like that.
Took the car in and they changed the oil. As soon as they changed it, he told me to start the car and then rev it a couple times to circulate the oil.
Revving the engine right after an oil change? Am I missing something or is that a big no no? I didn't rev the engine, just let the idle shoot up to 1500k then drop back down to 750.
Bpatts is offline   Reply With Quote
Old 03-06-2012, 03:49 PM   #2
JohnM10
Member#: 244231
2006 Impreza 2.5i 5M
Crystal Grey Metallic
Revving an engine is never a good idear untill it is up to operationg temp. I always start the car up while watching the oil light and let it idle normally.
JohnM10 is offline   Reply With Quote
Old 03-06-2012, 06:01 PM   #3
Bpatts
Member#: 288358
2005 Wrx Sedan
And that's what I did. Car was already up to operating temp. I didn't rev and the oil light went out a few seconds after I started the engine.
Old 03-06-2012, 06:58 PM   #4
A5un
Member#: 174095
2011 EVO X MR
So... Mitsubishi fsm actually tell u to do this right after you put in the oil before you measure with the dip stick.
A5un is offline   Reply With Quote
Old 03-07-2012, 01:06 AM   #5
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
Uhh, I do my own oil changes, and after pouring in the correct amount of oil, i wait 3-5 minutes to let the oil settle, check the dipstick (sanity check), start the engine and idle for 30 seconds, turn the engine off, recheck the dipstick and add more oil if needed. No revving the motor immediately after startup. That does not sound like a good idea to me at all.
furiouswrx is offline   Reply With Quote
Old 03-07-2012, 10:23 AM   #6
Tripintaz
Member#: 245218
2013 STI Limited
Anyone that is changing your oil is the lowest grade and lowest experience technician there is. Never listen to them. 99% of them have no clue.
Tripintaz is offline   Reply With Quote
Old 03-07-2012, 12:45 PM   #7
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
You were right not to rev the motor. If your oil light comes on the filter probably didn't have oil in it before it was installed. Your motor will be happier if the filter is pre-loaded with oil and you crank it for a few seconds after an oil change. The idea is to get oil circulating BEFORE it runs. Low revs without oil > high revs without oil
I'm not scared of Jiffy Lube oil changes under my supervision. Just walk into their shop and talk cars with the techs. They'll listen to you if you 'remind' them to do little things to your car. Hell, I've even poured oil into my own filter to lube the o-ring and pre-load the filter when the kid didn't get it. If the tech is an F-tard then I'll tell him straight to get the hell away from my car
imma_stocker is offline   Reply With Quote
Old 03-07-2012, 11:55 PM   #8
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
+1. I forgot to mention to pre load the filter with oil and lubricate the filter o ring with oil before installing. I doubt dealer or indy shop techs bother to do this.
Old 03-08-2012, 09:45 AM   #9
rkramer
Member#: 118209
2015 WRX Limitec
Although pre-filling the filter doesn't hurt, it certainly isn't a required step either. LOTS of engines have designs that point the filter downwards. No way you are going to pre-fill that filter, and those engines have lives that can outlast a subaru engine fairly easily.
Old 03-08-2012, 10:33 AM   #10
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Required, no. Beneficial, yes. Lots of variables go into oiling systems but oil in the filter before the motor cranks over is a good thing. Even if you're just getting the filter element wet and letting the bubbles float out before installing it.
Old 03-08-2012, 08:46 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I'm curious. What would be the reasoning behind the suggested revving. Why would you need to circulate the oil? Once the oil pressure warning light goes out everything is the way it should be.
Old 03-08-2012, 09:33 PM   #12
bluesubie
Member#: 767
04 FXT
Oil change dude's flawed logic.
Maybe he's thinking that the additives in the oil will form a layer and protect the engine more quickly. In fact, it takes hundreds of miles for that to happen. That's all I can come up with. Revving a turbo with cold oil is the absolute worse thing you can do.
-Dennis
Old 03-09-2012, 01:15 PM   #13
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Common idiotic logic is to get the pump primed faster (fewer seconds). These are the guys playing checkers in a chess game.
In their minds: Rev the engine, spin the oil pump, oil pressure light turns off
In reality: Rev the engine, turning your engine dry, little to no lubrication over your bearings and cylinder walls, excessive wear for no reason but impatience, oil pressure light turns off
The right way: Get your pump primed as much as possible BEFORE REVVING THE ENGINE, let it idle until oil is saturated again, wet bearings, wet walls, wet valvetrain, pressure is good, flow is good, happy motor, rev away
Old 03-09-2012, 01:27 PM   #14
ehiddenidentity01
Member#: 279169
2004 impreza wrx sti
wrb
i recommend u do your own oil changes or have someone u know and trust do them. type of oil is important as well as the filter depending how long u run them between changes. oil is the life of the engine and just like imma_stocker said everything wet everything happy
ehiddenidentity01 is offline   Reply With Quote
Old 03-09-2012, 10:15 PM   #15
Tdaz250
Member#: 310744
02 WRX
You only rev it it up to like 1500(if your idle doesnt do it automatically)...every time i've been to the oil change place they say to do it...even when they do it they only do it to like 1500-2000 they just want to see that the oil pressure has come back up.
Tdaz250 is offline   Reply With Quote
Old 03-10-2012, 08:07 AM   #16
ciper
Member#: 15543
90BJ Legacy LS ABS
Really? Thats one more reason I can use to convince people not to go to those places.
Old 03-11-2012, 03:49 PM   #17
SubaruWRXtreme
Member#: 307112
2009 WRX (hatch)
Satin White Pearl
Change the oil and just start it up and let the car idle that will just do fine.... NOT rev it when just minutes ago you poured new oil in the engine, some mechanics are insane !!
SubaruWRXtreme is offline   Reply With Quote
Old 03-11-2012, 07:54 PM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
stupid people......the idiot that changed the oil just wanted to see it blow up
Old 03-11-2012, 10:33 PM   #19
subi400
Member#: 216984
1996 Impreza outback
Green
To the OP,
The best way to get the oil circulating in the engine is simply starting it up and letting it idle like other people here have said. There's no science to this, just simple procedure.
A correction to a few people who said something about starting the engine up, letting it idle for 30 secs then turning it off and rechecking the oil and then adding some is a little off. Letting it idle for 30 secs or 1 min sends oil all over in the engine so when you go to check it the level will be slightly lower than what it would normally be if you had checked the oil after letting it sit for 10 plus minutes giving time for the oil that got spread around to drain back into the pan.
Since our cars take around 4.2 quarts of oil, I put in 4 quarts and then drive it that day. I check the oil the next morning or before I drive it again therefore giving me a more accurate reading of the oil on the dipstick. Doing it this way has worked great for me everytime!
Why did you go for the higher mileage oil? Do you not understand the importance of the proper oil in a turbo engine...??
subi400 is offline   Reply With Quote
Old 03-11-2012, 10:35 PM   #20
subi400
Member#: 216984
Green
They are insane.... Letting it simply idle will circulate the oil and at idle there is low load so nothing to worry about...
Old 03-11-2012, 10:53 PM   #21
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by subi400 View Post
To the OP,
you operate under a misconception
'our engines' take several different amounts of oil
and some of the amounts are quoted as being amount with and some without changing the filter in the owners manual.....the fsm usually lists both amounts
it is a bad thing to just ASSume...so dont
I have been buying 5 qt of oil and filling the filter and installing it and then pouring the remainder of the 5 qt in my car since day one...actually both my wrx's.....and never had any issue at all
Old 03-11-2012, 11:18 PM   #22
Bpatts
Member#: 288358
2005 Wrx Sedan
Is there something wrong with high mileage oil? I switched to Valvoline synthetic blend because my car has 92000 miles on it and others have had good uoa with them.
Am I missing something? High mileage oil is bad for turbos?
Old 03-12-2012, 07:47 AM   #23
bluesubie
Member#: 767
04 FXT
No.
No.
No.
Old 03-12-2012, 07:53 AM   #24
Uncle Scotty
Member#: 16200
OK buy Nates beans
yeah...just dont use the 5w30 in it
Old 03-12-2012, 03:11 PM   #25
subi400
Member#: 216984
Green
Then, I guess I need to read some of the newer owner manuals then because the one for my car says 4.2 US quarts But then again if you add oil to the oil filter then it comes out about 5 quarts so yes you are right about that part.
Why would exhaust note change after oil change? yobtah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-17-2013 12:13 AM
Weird engine noise after oil change 0_o wenzq622 Newbies & FAQs 5 09-26-2011 08:35 PM
Interesting engine noise after oil change wenzq622 Texas Impreza Club Forum -- TXIC 2 09-26-2011 02:23 PM
Engine noise change after oil change gathermewool Newbies & FAQs 8 08-29-2008 11:09 AM
Engine smoke after oil change??? innova Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-16-2006 12:51 AM
