Old 03-06-2012, 10:44 PM   #1
The G.O.A.T.
Member#: 149724
1999 leggy gt 5speed
Blood red
Default 99 Legacy GT questions
Hi all
I just picked up my first lgt, and so far I love it!
Just have a few questions
1. Does it have a lsd (front center and rear?)
2. Can the ecu be open sourced?
3. Got some clutch chatter, could it be that the clutch needs to be replaced, or just an adjustment?
4 Any common things to do for maintenance @ 283,000 km?
5.Where is the fuse box (so I can pull the ****ing abs fuse out)??
Thanks
Nick
The G.O.A.T. is offline   Reply With Quote
Old 03-06-2012, 11:04 PM   #2
CosmoTheCat
Member#: 3409
1) front - no, center - viscous coupler or clutches, depending on manual/auto, rear - doesn't look like it.
2) Doubt it.
3) Most likely the flywheel is tweaked, replace it.
4) That's what, about 170k miles? Do you know the maintenance history? Has the timing belt been changed? If not, do it. Check all of your fluids and flush those that don't look good. Check your brakes, check for leaks and fix.
CosmoTheCat is offline   Reply With Quote
Old 03-08-2012, 12:39 PM   #3
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I'm with Cosmo on this.
I hear there's a dual-mass clutch available now, from Subaru, which might help the clutch stuff.
DLC is offline   Reply With Quote
Old 03-08-2012, 05:45 PM   #4
The G.O.A.T.
Member#: 149724
Blood red
Thanks. It is my winter beater and I eventually plan to Rally it out (light bars, 3" lift, weld center and rear difs)
I guess I should ask, will springs and struts from a similar year outback fit and work?
FS/FT : Parting out 99 Legacy GT and 96 Legacy L bcorn Legacy Specific Parts 36 07-07-2012 11:41 PM
Question about the engine in the 99 Legacy GT josh04 Legacy Forum 4 08-15-2005 10:24 PM
Parting out 99 Legacy GT chris300zxtt Legacy Forum 8 05-25-2001 11:02 AM
what is the 1/4 mile time for a stock 99 legacy gt zx2boy Legacy Forum 7 04-11-2001 12:27 AM
99 Legacy GT on Ebay 99LegacyGT Legacy Forum 1 06-22-2000 09:22 AM
