Old 03-07-2012, 12:12 AM   #1
jollyblue84
Member#: 292300
01 GC8
blue
Default 95 jdm sti rev limit?
Ok so 95 jdm sti or the ej20g motor. What is the rev limit on these motors? I'm wondering because I don't think mine has a rev limiter and really don't want to test it.
jollyblue84 is offline   Reply With Quote
Old 03-07-2012, 08:15 AM   #2
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
mine's around 7300?
sizzflair is offline   Reply With Quote
Old 03-07-2012, 11:38 AM   #3
jollyblue84
Member#: 292300
01 GC8
blue
Originally Posted by sizzflair
mine's around 7300?
Did you do anything to raise the limiter or is that stock?
Old 03-07-2012, 02:41 PM   #4
sizzflair
Member#: 94268
2010 Exige S240
I believe that's stock (at least on my dash). Haven't had any problems going up that high either, but then again I'm not on my stock ECU anymore.
Old 03-07-2012, 05:08 PM   #5
jollyblue84
Member#: 292300
01 GC8
blue
What ecu are you running. Mine is a prova
Old 03-07-2012, 05:49 PM   #6
gtu89rx7
Member#: 108029
2000 2.5RS
Rally car
my 1995 EJ20G (stock ecu) is about 7000. sounds like fuel cut
gtu89rx7 is offline   Reply With Quote
Old 03-07-2012, 06:28 PM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
V2 STi should be the "6K" ecu which has the same rev limiter as the standard WRXs.
7100RPM
-Rob
rob is offline   Reply With Quote
Old 03-07-2012, 06:31 PM   #8
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
I will also add that the 3 or 4 prova tunes I have looked at all have the same stock rev limiter. Then again with random tune, you have no idea what you are running.
Rob
Old 03-07-2012, 07:36 PM   #9
jollyblue84
Member#: 292300
01 GC8
blue
Rob
No sir. I still need to send you a pic of mine. Be doing that tomorrow. So would you guys think 7000rpm would be a safe bet?
Old 03-07-2012, 07:39 PM   #10
eg33GC
Member#: 206851
56 Belair
Pro Street
take a picture of the prova with the cover off the ecu
eg33GC is offline   Reply With Quote
Old 03-07-2012, 07:45 PM   #11
jollyblue84
Member#: 292300
01 GC8
blue
Will do in the morning around 8am central time. So don't forget to check your email.
Old 03-07-2012, 10:01 PM   #12
sizzflair
Member#: 94268
2010 Exige S240
I'm running Hydra 2.6... but not sure if V2 STi vs. V2 STi RA are any different.
Old 03-07-2012, 11:18 PM   #13
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
For completeness sake;
Ver1 STi-RA :: SB :: 7800 RPM
95/96 WRX RA :: Z5 :: 7700RPM
Ver2 STi-RA :: 7k :: 7700RPM
All others are 7100RPM
-Rob
Old 03-08-2012, 08:32 AM   #14
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
There are only two valve train layouts on the early EJ20G engines (those equiped with 4-plug ECUs):
- WRX & WRX.STI version with HLA and 7100 rpm limit (although 2 versions of HLA have been used, both with the same sprins)
- RA & STI.RA version with shim under bucket and 7700 rpm limit
The Version 1 STI type RA is not in the factory documentation unfortunately (STI specific parts/tuning).
Marnix is offline   Reply With Quote
Old 03-08-2012, 02:13 PM   #15
Aphex28
Member#: 11506
2015 WRX
is this just the STI? or does the same apply to the z4 wrx ecu?
edit: Nevermind! It is. Search rules
Aphex28 is offline   Reply With Quote
Old 03-08-2012, 02:54 PM   #16
sizzflair
Member#: 94268
2010 Exige S240
-Rob
That is good to know. Thanks! I just estimated it was 7300 from the tach but 7700
I've been safe and shift around 7k, but this gives me assurance
Old 03-10-2012, 05:46 AM   #17
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Just that it can do those revs doesn't mean it will do it all day long. I strongly advise to shift at 6500 rpm to stay in the powerband, especially when running a stock bottom end.
Old 03-10-2012, 10:39 AM   #18
suberdave
Member#: 101865
88 GL-10 STi
Dyno chart on my stock EJ20G with bolt-on mods and standalone ECU, show the torque and HP drop off after 6500RPM anyhow. so no since taking it to 7200RPM for no reason. that is just 5-700RPM not making any increase in power. Shift to the next gear to get the engine back in the power band...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 03-10-2012, 12:27 PM   #19
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Higher rev limit really helps me for rallyx (and I am sure any other racing) where a shift mid corner would kill your time.
Old 03-10-2012, 01:36 PM   #20
jollyblue84
Member#: 292300
01 GC8
blue
Thanks for all the input guys.
Old 03-10-2012, 03:08 PM   #21
eg33GC
Member#: 206851
56 Belair
Pro Street
-=Suberdave=-
unless you're drag racing
but i feel the .825 5th gear and shorter would be just fine for the last 100ft
06 STI REV Limiter? Screwbal Newbies & FAQs 24 08-09-2009 06:27 PM
STi rev limiter settings zmanoside Newbies & FAQs 6 07-06-2008 05:33 PM
2006 STI rev limit - ECU and user set? MitchP General Community 11 12-02-2005 10:08 AM
05 sti rev limiter wrecked Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 05-23-2005 05:54 AM
