Alaskan Impreza Club
Old 03-07-2012, 04:54 PM   #1
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
Default Boost Gauge
Hey guys. I still need to figure out something for the boost gauge. Does anybody make one that plugs into the intake? Not sure if Paul did this to the rally car. If anyone knows let me know.
granny is offline   Reply With Quote
Old 03-07-2012, 05:58 PM   #2
QwikEVO
Member#: 44172
2006 Lancer Evo 9
Plasti-Dip is for TOOLS
A boost gauge pre-turbo?
QwikEVO is offline   Reply With Quote
Old 03-07-2012, 06:07 PM   #3
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
No I was thinking about tapping into the throttle body. Would this work?
Old 03-07-2012, 06:09 PM   #4
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
Pick any vacuum line post throttle body and tee into that line for your vac/boost source.
retrac is offline   Reply With Quote
Old 03-07-2012, 06:11 PM   #5
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
Would any gauge work? What do I need to make it work?
Old 03-07-2012, 06:13 PM   #6
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
As long as it's quality and isn't going to fail on day one. I recommend making sure you pick one that measures both vacuum and boost, it's valuable for tuning and troubleshooting.
Old 03-07-2012, 07:28 PM   #7
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
What's your max psi expected to be?
Old 03-07-2012, 07:32 PM   #8
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
Not sure. I'm just trying to get it running first.
Old 03-07-2012, 07:44 PM   #9
chanomatik
Member#: 159474
SNOSLO
I ask because I've been wanting to get a Defi Racer series boost gauge to replace my SPT boost gauge. SPT goes to 20psi and my car is tuned to high 19, almost 20. Let me know if you might be interested.
Old 03-07-2012, 07:52 PM   #10
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
Pm sent.
Old 03-07-2012, 07:53 PM   #11
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
Been thinking the same thing.. Plus it would be nice to have just two gauges that I actually want/need.
Boost and Oil Pressure.
And that way they would fit perfectly into a SMY bezel.
Whenever I upgrade gauges, I'm definitely going the Defi Racer route.
kyletakahero is offline   Reply With Quote
Old 03-07-2012, 08:17 PM   #12
chanomatik
Member#: 159474
SNOSLO
Defi Racer series are standalone units, they don't use the Link Control unit, so that's something to consider if you are planning on multiple gauges. For now I just care about boost, but eventually I'd like to add others.
Old 03-07-2012, 08:28 PM   #13
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
Mhm, which I like about the Racer series.
I figure if I really want to log parameters I'll just pull a retraC and buy a mini-book and a Tractix cable. Otherwise I'ld like to be able to just watch those two points when I drive hard.
But the thing I like about the SPT is the fact it is Anaglog and not using a digital sender to give your the reading. Which, in theory, gives you a faster and more precise reading.
Old 03-07-2012, 09:08 PM   #14
AK_Ford
Member#: 257415
2007 Sti
I would think slower since the air in the line and gauge has to compress. A signal travels way faster than air does.
I noticed a big difference in response between the biggish vac line I have on the sti and the 1/8" plastic line I used on the wrx.
AK_Ford is offline   Reply With Quote
Old 03-09-2012, 02:22 PM   #15
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
If the STI had a stock gauge once upon a time and the line for that was used there is a constrictor (small brass tube) in the line right after the manifold. This causes the gauge to be smooth response wise but very slow. Also many gauge kits that come with a plastic tee also have this as well that can cause delays in gauge response.
P3Auto is offline   Reply With Quote
Old 03-09-2012, 02:27 PM   #16
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
@Granny,
Not sure if you got it up and going but I would start with wastegate only pressure(manifold pressure routed straight to wastegate actuator), you may even find this is a bit high for your setup depending on the turbo and the wastegate pre-load. Watch for boost creep towards redline. Looking forward to hearing more!
FS : Blitz DTT DC2 turbo timer/boost gauge Osus14 Interior/Dressup/Audio & Security 2 03-08-2012 05:38 AM
OEM lamco boost gauge wire diagram bbun Electrical & Lighting 1 03-07-2012 05:45 PM
Mech. Boost Gauge vs. Elec. Boost Gauge YooperWRX Newbies & FAQs 9 07-09-2009 10:37 AM
$17 Boost gauge -vs- $135 Boost gauge Mattr762 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-14-2003 01:05 AM
No boost gauge! Is an EBC with boost gauge good enough madmmt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-06-2002 04:27 PM
