Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 03-07-2012, 05:27 PM   #1
Member#: 305343
1996 WRX STI Wagon
Dark Mica Blue
Default Coolant Temp Sensor compromised?
Recently I undertook the task of tracking down a hesitation issue. To be as descriptive as I can it's as if the car is being hit by gusts of wind, most prominent when cold and just cruising away (still happens at WOT on the highway). Anyway I currently have the intake manifold off and am replacing anything and just about everything that looks in poor shape.
Naturally now would be a good time to check the CTS and im kind of glad I did as the sensor was coated in a sort of sticky yellow paste. The photo below shows the tip cleaned off while the rest of the sensor is still covered in the unknown substance.
My question is, does this look normal? Never had a CEL for the CTS and besides the random hesitation, the car seemed to drive well (albeit maybe a little rich). Either way the sensor has been replaced but I was more or less curious if anyone else has come across this. Going to be sure to put subaru approved coolant and probably some conditioner in.
Engine = EJ20K, stock, 70,000km.
Sorry about the novel, wanted to be sure I got all the information in there.
zagarus is offline   Reply With Quote
Old 03-07-2012, 10:06 PM   #2
Elbert Bass
Member#: 283429
Not sure if they are valid specs for your car (I only have access to US model specifications) but the temp sensor should measure 2,000 to 3,000 ohms at 20 degrees C, 700 to 1,000 at 50C, and 300 to 400 ohms at 80C. If it measures in those ranges then the coolant sensor is NOT your problem.
The slime is normal and does not affect the sensor operation.
Elbert Bass is offline   Reply With Quote
Old 03-18-2012, 08:34 PM   #3
Member#: 243590
07 forester
my 04 2.5rs n/a fluctuating temp gauge overheat changed therm and rad cap better for few days but them temp fluct again and rad fans seem to cycle late changed cts now fans don't come on and temp red lines after couple minutes operating at idle . gonna pull therm and verify opening. any suggestions?
Have excellent heat inside through entire process before and now.
47businesscoupe is offline   Reply With Quote
CEL = engine coolant temp. sensor jrlegac8195 Service & Maintenance 1 10-30-2002 02:14 PM
Help finding Intake Air Temp or Coolant temp sensor jacksonww Legacy Forum 1 08-27-2002 01:42 PM
Stock coolant temp sensor Jewbaru Normally Aspirated with bolt-on Forced Induction Powertrain 7 07-17-2002 09:23 PM
Coolant temp sensor LVSUBARU Normally Aspirated with bolt-on Forced Induction Powertrain 11 03-19-2002 12:28 AM
