Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 06-25-2016, 10:09 PM   #1
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Default Poor AC performance from the factory
check your ac coolant pressure, mine was hovering around 25 and had not done a good job cooling from the factory when i got the car in 2012. Filled it to around 40-45 on the refill gauge and thats all it needed.
hope this helps someone out.
Old 06-25-2016, 10:38 PM   #2
drpoop
Member#: 421858
This is something I wouldn't be doing without a shop. Something about two hoses you need to check. A high and low pressure side or something. And those ac refill kits you get at autozone don't connect to two hoses.
drpoop is offline   Reply With Quote
Old 06-26-2016, 07:57 AM   #3
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
it fixed the issue and i didnt have to pay anyone to do it. So i guess im lucky..... on all 4 cars ive done it on.
Old 06-26-2016, 09:39 AM   #4
chevytruck_83
Member#: 448981
Default Poor ac
Some cars just have poorly designed ac systems. I purchased a 2005 Chrysler 300 new. From the day I got it it would only get cool. To get cold air you had to be doing 65 plus on the highway. On the other hand every ford I've ever owned. Be it 15 years old or 2 years old I had to turn the ac down because they get so cold. Just because a car is new or a couple years old doesn't mean they come with decent ac. As hard as it is to believe.
chevytruck_83 is offline   Reply With Quote
Old 06-26-2016, 07:25 PM   #5
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
I dont think that is the case with the impreza
When i got my engine replaced i had a rental crosstek and that AC was very impressive. so basically the same compressor and components compelled me to look into my freon level.
Old 06-27-2016, 03:01 PM   #6
DrummerDaveB
Member#: 67721
My AC sucks and has since new, so I'll check that out as a possibility. I think I even have one of those refill kits sitting around somewhere.
DrummerDaveB is offline   Reply With Quote
Old 06-27-2016, 08:18 PM   #7
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Check the service manual, you have now way overcharged it...maybe
more refrigerant doesn't mean better cooling, usually means worse, unless you were below factory specs.
Old 06-28-2016, 01:13 AM   #8
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Old 06-28-2016, 02:21 AM   #9
Discombobulated
Member#: 384793
2009 STI hatch
Just did the same thing on my other car and it did the trick, thanks for the post
Adding some refrigerant was more cost effective than taking it to a shop to drop it off and get billed 100-200 bucks.....
Discombobulated is offline   Reply With Quote
Old 06-28-2016, 01:16 PM   #10
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Originally Posted by flyboy1100 View Post
Great chart, @95 degrees i was reading 25psi on the gauge i made sure to stop at 45psi knowing 50 is about as high as i wanted to realistically go.
Old 06-28-2016, 02:07 PM   #11
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
obviously I added the PSI numbers, but the chart is straight out of the service manual.
our cars only are spec'd for 1.05lbs of 134a. my full size pickup with probably 1/3 the interior volume is spec'd for 2.0lbs
Old 06-29-2016, 12:03 AM   #12
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
A lot of that has to do with hose length.
Old 06-29-2016, 12:23 AM   #13
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
and i assume condensor size too?
i understand more refrigerant doesn't necessarily mean better cooling unless the system is designed to utilize more refrigerant.
Old 06-29-2016, 12:46 AM   #14
Commander Keen
Member#: 319157
That too. Basically the overall system volume.
