Old 03-27-2013, 02:25 PM   #126
ALamb
Member#: 351590
Default Impreza hard start
I just brought my 2012 Impreza to the dealership for this problem last night. I've driven about 16,000 miles with it, and it intermittently will not start on the first try or will take a long time to crank over.
They called and said they ran a computer update to resolve the long crank time.
We'll see if that works...
ALamb is offline   Reply With Quote
Old 03-27-2013, 02:55 PM   #127
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I didn't know there was a computer update for that problem. I thought the TSB solution was shims for adjusting the cam position sensors.
sgoldste01 is offline   Reply With Quote
Old 03-27-2013, 03:03 PM   #128
PuyallupCoug
Member#: 337092
2013 Impreza SLTD 5d
Originally Posted by flyboy1100 View Post
do you have a light on, i don't, and from reading the TSB's it isn't clear if the light will be on or not.
I didn't have a CEL on and did they find any codes in the system. They updated the ECM to a new firmware version and sent me on my way.
It promptly happened again a day later but since I had no CEL on, I doubt anything can be done.
PuyallupCoug is offline   Reply With Quote
Old 03-27-2013, 03:06 PM   #129
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Again, there's always the solution I mentioned above (shimming the cam position sensors).
Old 03-27-2013, 04:20 PM   #130
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
only if the dealer will do it. mine didn't even want to attempt it but knock on wood my problem hasn't returned after the ECU update
Old 03-27-2013, 04:26 PM   #131
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yeah, my Impreza hasn't done that in many, many months (like 5 or 6 months). So I'm not worried about it.
To my knowledge, the only firmware update I've received was for the coolant temp recall, so unless they also gave me the ECU update at the same time, I don't have it.
Old 03-27-2013, 04:34 PM   #132
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
there is a tsb that refers to hard starting and an ecu update, so I'm not sure if that is the same update or not.
Old 04-02-2013, 04:51 PM   #133
PuyallupCoug
Member#: 337092
Yeah I gave the dealer both TSB's and they said since no codes were thrown, they won't do anything.
Old 04-02-2013, 04:54 PM   #134
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I did the same, but at least in my case they found an ecm update
Old 11-15-2013, 01:53 PM   #135
mrcoolio
Member#: 352732
Default 2012 Impreza Hard to start? Fails to start the first time?
I am having this same problem. Very frustrating living in a cold climate. I installed a remote starter and some it does not start on first try. Thought maybe it was the remote starter but I am experiencing the same problem when I start with a key.
Seems like a manufacturers problem. Recall?
mrcoolio is offline   Reply With Quote
Old 11-15-2013, 01:57 PM   #136
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
There are a couple TSB's that may or may not help you. They don't directly deal with this problem though.
Xafen is offline   Reply With Quote
Old 11-15-2013, 02:04 PM   #137
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Right, it might be the result of improperly aligned camshaft position sensors (there are four of them). I believe the TSB has the technician install some kind of shims beneath the sensors to bring them into alignment.
Old 11-17-2013, 07:47 PM   #138
hi5.0
Member#: 340456
2013 Impreza
Had a minor manifestation of this issue crop up once about 2 months ago. Cranked for a while before firing - by the time I thought about turning the key back to OFF because it was taking so long, it finally started. Have been unable to duplicate since.
hi5.0 is offline   Reply With Quote
Old 12-11-2013, 10:33 PM   #139
john_coctostan
Member#: 369384
2014 Impreza SL
Hard start yesterday. Today, CEL has come on with the cruise light flashing and the traction light illuminating in rare instances. It is not the gas cap. Appt Thursday afternoon. 1200 miles. Sheesh.
john_coctostan is offline   Reply With Quote
Old 12-25-2013, 02:29 AM   #140
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Mine has only ever failed to start the first try once in a year. But it often "stumbles" when it starts. It's kinda like "ok, I guess I'll turn over". It drives fine after, but it often does this hesitation.
I have been trying to keep the gas above 1/4 tank (especially in the winter), and letting the gauges do a full sweep before starting. It seemed to help a little, but still iffy.
Fresh oil change, new air filter, OEM battery, and 15k on the clock. 13 Sport CVT.
averagewhiteboy is offline   Reply With Quote
Old 12-25-2013, 02:31 AM   #141
GarbageDay
Member#: 371213
2013 Imp Spt Lmtd
Ice Silver Metallic
My car stumbled once or twice when it started. Freaked me out too. I try to let the gauges do a full sweep before starting as well but yeah, I agree it is still iffy. A little over 1,700 miles right now. All stock and OEM, haven't changed anything yet.
GarbageDay is offline   Reply With Quote
Old 12-25-2013, 02:35 AM   #142
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
At first I thought it was just it being ~19 degrees, the car sitting outside all day, and the crappy OEM batteries CCA's (what, like 320?!). But I remember the iffy starts over summer time too.
When I go in for my inspection next month I'm gonna have them check for these advisories, as well as tighten my e-brake up. It's a bit sloppy.
Old 12-25-2013, 01:26 PM   #143
DNA Performance
Member#: 372528
2013 Impreza Sport
DNA Performance is offline   Reply With Quote
Old 12-25-2013, 01:27 PM   #144
DNA Performance
Member#: 372528
2013 Impreza Sport
I think there is a recall on the crank possition sensor on our cars, causes hard start.
Old 12-26-2013, 09:37 AM   #145
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
Taking my car in for it's first oil change today @4pm, and actually had the hard start this morning. I will inquire about any tsb for it.
Tha Chakal is offline   Reply With Quote
Old 12-26-2013, 04:26 PM   #146
Tha Chakal
Member#: 372100
Got off early, service guys said that there is no recall or tsb about hard starts or crank sensors.
Old 12-26-2013, 05:16 PM   #147
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I'm pretty sure that's incorrect, but I'm sure someone else will confirm it. The TSB I'm thinking of isn't for "crank sensors", though. It's for the camshaft position sensors, of which there are four on this car. As I recall, the camshaft position sensors might need to be "shimmed" in order to be positioned correctly.
Old 12-26-2013, 05:28 PM   #148
Tha Chakal
Member#: 372100
Ahh. I only saw DNA's post.
It's funny that the tsb you referred to is about the cam sensors. With a mere 200 miles on it, I got a CEL with a code for the camshaft positioning sensors. After the dealer checked the cam spacing and couldn't find anything wrong, SOA told them to swap them with each other (they told me there were two, not four).
Old 12-26-2013, 05:40 PM   #149
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
No, there are four. Two are the intake camshaft position sensors (two: left and right), and two are exhaust camshaft position sensors (two: left and right). This is a typical boxer engine configuration.
Old 12-26-2013, 05:54 PM   #150
Tha Chakal
Member#: 372100
I guess it was one of the pairs they must have been referring to. Thanks for the boxer info!
Obviously, whatever they did then didn't prevent me from having a hard start this morning.
going to be like driving for the first time! ThaPuertoRican15 General Community 35 12-27-2010 02:42 PM
going to autox this weekend for the first time... CiViCKiDD General Community 12 03-21-2006 07:15 PM
I'm about to ride a Harley for the first time. Sharkbait Off-Topic 48 12-01-2005 11:23 AM
im going to watch american idol for the first time Protege Menace Off-Topic 5 05-19-2005 11:35 PM
Finally got to drive my WRX for the first time in a while! MGAMAN Alaskan Impreza Club Forum -- AKIC 3 07-24-2003 09:31 PM
