Old 03-08-2012, 06:51 PM   #1
squarebush
Member#: 173656
Default P1722 after 5mt swap
Car: 2001 subaru outback sport.
Engine: EJ222
Car was a 4EAT
Swapped in a JDM WRX 5MT
Already wired in:
Neutral safety switch.
Reverse lights
Shift/key locks
Vehicle speed sensor
At first I had 3 codes. 2 for torque convertor, and one for AT diagnosis signal. Once I plugged in the TCM, The two for the torque convertor disappeared, but the P1722 is still there. I have done a LOT of reading up on this, and most people agree that for this kind of swap, there is a signal wire to the ECU, that you can ground to put the ECU in MT mode. I saw one one thread that someone said the pin was B135-25. the ECU connectors didn't have a pin in that slot, so I hacked something together to get connection to the pin on the ECU. I grounded it, but It made no difference, I still have the pending P1722, no mater how may times I delete it.
squarebush is offline   Reply With Quote
Old 03-08-2012, 09:44 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Are you sure that is the correct sheet for your exact year of ECU? They moved pins around on cars even when the plugs were the same.
Old 03-08-2012, 10:46 PM   #3
squarebush
Member#: 173656
No, I am not, but I have herd reference in several threads to b135 25. The Service manual I have for the 2001 does NOT show a AT/MT selector pin.
Old 03-09-2012, 12:07 AM   #4
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Hi
The older Subarus definitely used one ecu for both - I've had more than one....but sometime since 2000+ they went to separate ECUs. Check the part number on your ECU and look it up on ebay for the 5-speed/manual ECU for you car...to see if they're different. Also, opposedforces.com MAY have this info...not looked for ECUs there.....found THIS...Subaru calls it an EGI Control Unit
For F.s.m. info check post 11 HERE. Should have one.
GL,
TD
wtdash is offline   Reply With Quote
Old 07-02-2013, 12:24 AM   #5
Julian913
Member#: 344226
1998 Impreza
Im getting the same problem after my 4eat to 5mt RS swap. Ecu is from a 98 2.2 L tranny is a 2001 RS
Julian913 is offline   Reply With Quote
02 5mt swap with ej205 engine swap Gamble_WRX Drivetrain 11 04-01-2010 05:40 PM
4EAT to 5MT swap? erice1984 Subaru Conversions 6 05-06-2004 10:42 PM
engine torque control with 4eat -> 5MT swap mbtoloczko Transmission (AT/MT) & Driveline 1 04-13-2004 10:33 AM
Implications of complete JDM 5MT swap? ebeck Transmission (AT/MT) & Driveline 5 03-09-2004 07:55 PM
RS 4EAT to WRX 5MT swap....? Boost4U Subaru Conversions 1 07-24-2003 08:30 AM
