Old 03-08-2012, 07:46 PM   #1
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
Default Radiator has two extra nipples
So my 2000rs radiator started to split.
Napa guys said he can get a replacement by morning
Looks like the right one from a quick once over in the box
Drain and remove old broken radiator easily
Take new one out of the rest of the packaging and noticed extra nipples.
Normally thats good
...on radiator that's bad cause i don't have a tranny cooler
i'm guessing thats what its for?
Can they be plugged or looped to close it out, or am i destined to return it?
moogoob is offline   Reply With Quote
Old 03-08-2012, 08:29 PM   #2
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
They are for an automatic transmission cooler. If you don't have an AT, then you just don't hook anything up to them. Most aftermarket radiators are set up this way to prevent needing two part numbers. Don't sweat it.
JamesWilson2 is offline   Reply With Quote
Old 03-08-2012, 08:42 PM   #3
moogoob
Member#: 7101
00RS I want to fill
Oh... so its not connected to the rest of the stuff? my initial thought was he samre coolant ran in and out of those.
Old 03-08-2012, 08:44 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
No. It warms/cools the ATF. Its a piece of spiral shaped copper pipe totally sealed from the coolant.
Old 03-08-2012, 09:50 PM   #5
moogoob
Member#: 7101
00RS I want to fill
sweet thanks for the help. Put it in and up n running with no problems.
Old 03-15-2012, 03:30 PM   #6
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
you can/should still plug/cover the nipples so crap doesn't get in there. (Specifically something that can eat through copper..)
DiscoGsus is offline   Reply With Quote
My Radiator has two gearbox oil lines feeding to it Special Built Motor Discussion 5 02-02-2010 08:53 PM
extra nipple on radiator? HELP! sike43 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-03-2008 10:40 PM
PC has DVI and VGA out..TV has two HDMIs Full_Clip Off-Topic 33 07-31-2007 08:53 PM
*Italian* chewing gum: now with extra nipple action Snowphun Off-Topic 14 10-29-2003 07:48 PM
Stereo has two wires, Impreza has one? susan Car Audio, Video & Security 5 11-20-2002 06:23 PM
