Welcome to the North American Subaru Impreza Owners Club Friday April 18, 2014
Old 03-08-2012, 08:39 PM   #1
SoCaL417
Member#: 173414
2012 WRX
Default Is it time to change my timing belt??
I'm at 60k miles on my 08 wrx. My friend said it was about time to change/check the timing belt. He than began to say that if it goes out while driving. Say "goodbye" to your motor and warranty won't cover a dime.
SoCaL417 is offline   Reply With Quote
Old 03-08-2012, 09:08 PM   #2
CobbsSTI
Member#: 245242
2006 STI
E85 Power
At 60,000 it is required maint. So they prolly won't cover it since technically it was supposed to be done at 60,000. If it does go while driving, yes you will be needing a new motor. I changed mine before 60,000 and put on a gates racing timing belt. My advise just change it now before you get into more trouble.
CobbsSTI is offline   Reply With Quote
Old 03-08-2012, 09:09 PM   #3
Cobrakai
Member#: 176408
2006 Acura TSX
Unless your friend has hard evidence it's due at 60k I would take it with a grain of sand... If you are worried about it call the service dept at the dealership.
Cobrakai is offline   Reply With Quote
Old 03-08-2012, 09:12 PM   #4
tibug
Member#: 273906
2003 Outback
I like trees
I thought it was 105k for pretty much all Subarus...
Although it's never a bad idea to check it just to be sure everything is working properly.
tibug is online now   Reply With Quote
Old 03-08-2012, 09:14 PM   #5
CobbsSTI
Member#: 245242
2006 STI
E85 Power
In the service guide it is required to change at 60,000 miles. So if he blows the motor it is likely they won't cover it. If indeed that is the reason why the motor blew.
Old 03-08-2012, 09:22 PM   #6
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
Inspect it definitely, if the service manual says to replace it. i would. Remember the harder you drive the more likely it is that something fails.
Though i do believe for non-turbo cars, it's 100K or something.
DHRDAN is offline   Reply With Quote
Old 03-08-2012, 09:30 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
It should be inspected at 60k but the requirements are to replace at 105k
Old 03-08-2012, 09:38 PM   #8
CobbsSTI
Member#: 245242
2006 STI
E85 Power
Yes you are right I haven't looked at the guide in a while, just checked and it is inspect at 60k replace at 105k. My bad guys.
Old 03-08-2012, 09:41 PM   #9
CobbsSTI
Member#: 245242
2006 STI
E85 Power
I more or less replaced mine cause of the power I'm putting down and didn't want to take a chance at stretching the belt and skipping a tooth at high rpms.
Old 03-08-2012, 09:52 PM   #10
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
for the last 5ish years I've known it to be 105K miles. There's also a certain amount of months, but it slips by me.
Old 03-08-2012, 10:33 PM   #11
02redwagone
Member#: 87067
02 Old but tasty
SRP
If they inspect through a side of the timing cover to get eyes on the belt then you can have that done in ten minutes yourself (well on a bugeye anyway). Wear marks on the back help you know your idler pulleys are crapping out too.
02redwagone is offline   Reply With Quote
Old 03-09-2012, 03:30 AM   #12
jaypt802
Member#: 149730
2002 Impreza WRX
Just a google search would have given you this as the first link....
http://www.cars101.com/subaru/subaru_maintenance.html
All the maintenance schedules are listed there.
jaypt802 is offline   Reply With Quote
Old 03-09-2012, 08:15 AM   #13
wrxlaunch
Member#: 181298
02 , Vf43 Inside..
12 seconds at a time
I guess u didn't check your manual....
wrxlaunch is offline   Reply With Quote
Old 03-09-2012, 08:51 AM   #14
speedy mike
Member#: 265056
2002 wrx
wrb
Change the belt and possibly the tensioner and water pump.
Cheaper than motor!
Live Long and Prosper
speedy mike is offline   Reply With Quote
Old 03-09-2012, 09:13 AM   #15
wrxlaunch
Member#: 181298
02 , Vf43 Inside..
If the manual says 105k why change it before u are close to it?
Old 03-09-2012, 09:36 AM   #16
rkramer
Member#: 118209
2002 WRX Sedan
Wow, the fail in this thread is strong!
105 months or 105k miles. Simple as that. No USDM WRX has ever had a shorter interval, EVER.
Subaru's are also not known for breaking belts. It happens, but it is very rare. The ones taken off at 105k miles look pretty much like new. You are far more likely to lose an idler bearing and have that trash your timing system. Also, a bad bearing won't generally not show up in a visual inspection. (usually there is some noise before it happens though)
Old 03-09-2012, 10:08 AM   #17
leecea
Member#: 37359
2003 WRX
10 years or 105k miles. Simple as that. No USDM WRX has ever had a shorter interval, EVER.
I'm sorry but you are also posting the wrong information. The change interval is 105 months or 105K miles. 10 years is 120 months so is longer than recommended.
I just changed mine because I hit 105 months. Belt looked fine but that's normal. Same thing when I changed another car at 105K miles. No visible wear.
leecea is offline   Reply With Quote
Old 03-09-2012, 10:34 AM   #18
jaypt802
Member#: 149730
2002 Impreza WRX
Timing belt: parts and labor $735
Motor: Minimum or parts $1000
Old 03-09-2012, 10:37 AM   #19
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
I know a guy that's on original t-belt @150k and drives hard.
However on my current Subaru I'm on my 2nd one @20k.
slava from goshen is offline   Reply With Quote
Old 03-09-2012, 03:08 PM   #20
rkramer
Member#: 118209
2002 WRX Sedan
yeah you got me on that one, (ninja edit fix!) Although at least in my opinion the month recommendation is fuzzy at best anyway. Rubber ages at substantially different rates depending on the environment it is in. A belt that is exposed to either extreme cold or extreme heat (ND or Arizona for example) will not last anywhere close to something that is driven around Florida its entire life. In either case, again, subaru belt failures are rare. They generally will always outlast the maintenance intervals.
Old 03-09-2012, 04:57 PM   #21
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
+1, except on the time, but I agree, I have never seen a belt snap. I have seen a few tensioner pulleys go though. I have 5k left until I hit 105 and then replacing the belt and tensioner.
blackfang is offline   Reply With Quote
Old 03-09-2012, 10:11 PM   #22
Tdaz250
Member#: 310744
02 WRX
This x2. If i had to replace the timing belt every 60k i'd be kinda pissed...
Tdaz250 is offline   Reply With Quote
Old 03-10-2012, 08:08 AM   #23
ciper
Member#: 15543
90BJ Legacy LS ABS
I had a belt snap from age that was below the maximum mileage. It bent many valves in my XT6.
Old 03-11-2012, 09:11 AM   #24
Munstermotorsport
Member#: 313126
I changed the timing belt 4 years ago but the car has only 10K miles done on the new belt. I'm worried about belt age, should it be changed again? Any one to advise.
Munstermotorsport is offline   Reply With Quote
Old 03-11-2012, 10:37 AM   #25
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You don't read so well do you? READ above. R E A D.
is it time for me to change my timing belt? 80k miles h1gh Newbies & FAQs 16 12-28-2011 12:20 PM
Time to change my Timing Belt kastkc Normally Aspirated Powertrain 27 07-11-2006 02:49 PM
Is it possible to change my name? rekondyte Newbies & FAQs 7 03-09-2006 07:44 AM
Is it possible to change my.... cvp76 Off-Topic 15 10-20-2004 09:49 PM
is it possible to change my HID's to 8000k instead of 4300k?? patpod6 Interior & Exterior Modification 12 08-08-2004 07:13 PM
