Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 03-09-2012, 12:43 PM   #1
jamesfacts
Member Sales Rating: (134)
Member#: 51282
98 RS
black & blue from parking
Thumbs up Danbury, CT: STi sideskirts, Exedy flywheel, Centerforce Clutch, more. LOCAL
Hi everyone,
It's time for a little spring cleaning... I have amassed a ton of parts from three different Subaru projects over the past two years and need to get this stuff out of my buddy's basement.
Local pick-up in Danbury, CT, 06810, please. These items are bulky and awkward to ship so come and get them!
Many other parts available, too. Leftovers from 3 WRX partouts / swaps over the last two years. If thereís a stock part youíre looking for there is a good chance I have one.
First up, a set of damaged 18 x 8.5 ET44 Rota Grid rims in Hyperblack finish. Tires are Falken Azenis that should last you through the summer. Three rims are decent with some curb rims. Two of the four centercaps are missing. The fourth rim has a damaged sidewall, but the tire is still good. May be fixable. Replacement rims are available from Wheeldude. (Runs about $230)
$sold
jamesfacts is offline   Reply With Quote
Old 03-09-2012, 12:45 PM   #2
jamesfacts
Member#: 51282
98 RS
Next up, a 2005 STi top mount IC. Includes silicon Y-pipe, fins are overall good condition.
$sold
I am missing one of the bolts for the y-pipe inlet, for some reason.
There's also a dent on the mounting tab, doesn't affect performance and can't be seen when mounted:
Old 03-09-2012, 12:51 PM   #3
jamesfacts
Member#: 51282
98 RS
WRB STi sideskirts. Include all the little white pop clips. Good condition, a couple very light scratches, but nothing serious.
$sold
Old 03-09-2012, 12:55 PM   #4
jamesfacts
Member#: 51282
98 RS
Set of WRX wagon roof rail deletes - I have most of the hardware either in the deletes or brand new from the dealer. Might be a couple clips missing here and there.
All 6 pieces plus hardware $80 picked up
Old 03-09-2012, 12:57 PM   #5
jamesfacts
Member#: 51282
98 RS
Exedy 13lb flywheel, in excellent condition. Fits the 02-05 WRX 5spd with pull-type clutch, and many other Subaru transmissions as well. About 13k miles on this part.
$sold
Clutchmasters FX400 6 puck clutch for 5spd pull style clutches. Clutchmasters 6 puck clutch - for the 5spd WRX pull transmissions. Only 6k miles on this - itís a serious clutch to handle 300+ whp. Some heat marks on flywheel, normal with a puck clutch. Lots of meat left on the disc. Includes disc, pressure plate and OEM flywheel. $250 picked up. Clutch is sold, still have an OEM flywheel for $35
Part # is 15-016-HDCB6. Fits 05 and down pull turbo 5spd transmissions.
Stock info:
The FX400 System uses the Power Plus I Pressure Plate with a custom, extremely durable, Sprung Ceramic disc. This is the ultimate extreme duty street and/or road/drag racing system. It is available in a 4 or 6 wing (paddle) configuration, with the 4-wing being the more aggressive setup (please specify which type you prefer). The sprung hub design allows for moderate dampening in high-torque applications, rendering it much more streetable than solid or rigid designs. This disc is designed for long life, outstanding holding capacity, and rapid heat dissipation.
Old 03-09-2012, 01:01 PM   #6
jamesfacts
Member#: 51282
98 RS
TREperformance fuel pump - this unit flows like a 255 Walboro - but is much quieter!
$sold
Generic 3" bellmouth downpipe.
$50 picked up.
Old 03-09-2012, 01:03 PM   #7
jamesfacts
Member#: 51282
98 RS
OEM WRX front subframe / u frame. Good condition, some surface rust but overall clean and straight.
$sold
OEM 06 WRX TMIC w/ Y-pipe.
$40 picked up
OEM 03 WRX TMIC w/ Y-pipe
$40 picked up
Old 03-09-2012, 01:06 PM   #8
jamesfacts
Member#: 51282
98 RS
Radiator (s) from an 02 and 04 WRX. Include overflow tanks, and fans.
$60 picked up each.
02:
04:
Also have AC condenser and AC lines from these WRXs too:
Old 03-09-2012, 01:08 PM   #9
jamesfacts
Member#: 51282
98 RS
Axles and diffs:
Steering rack - fits all 02 - 04 Imprezas, can be massaged into many other year Subarus. Good shape, all joints and dust covers intact. $sold
Rear 4.11 VLSD diff w/ axles. From 4eat WRX. Mileage unknown, good working condition. $sold
OEM 3.54 04 R160 rear diff w/ axles. Good working condition. 82k miles. $sold
WRX R160 rear crossmember, nice shape. $25 / good beer.
Early style 04 axles - male to female. 80k miles, nice shape. $sold.
Old 03-09-2012, 01:13 PM   #10
jamesfacts
Member#: 51282
98 RS
Finally, a few body panels: Doors / fenders / lights from a 2004 WRX wagon.
Passenger side headlight - absolutely mint.
$100 picked up
Three doors are available - they have been resprayed stock color, paint is decent.
Passenger side front: $100
Driver side rear: $100
Passenger side rear: $100
Front bumper - pretty beat but could absolutely be repainted.
$50 picked up
Old 03-09-2012, 01:17 PM   #11
jamesfacts
Member#: 51282
98 RS
Passenger side WRX wagon Fender - some scratches but no major dents, definitely useable:
$60 picked up.
Passenger side EDM STi fender with sidemarker. Again, some scratches, minor dings.
$sold
Many other parts available, too. Leftovers from 3 WRX partouts / swaps over the last two years. If there’s a stock part you’re looking for there is a good chance I have one.
Old 03-09-2012, 03:18 PM   #12
singincanary
Will mod for Guinness
Member Sales Rating: (78)
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
Will the front subframe "u" fit an '02 rs?
singincanary is offline   Reply With Quote
Old 03-09-2012, 03:32 PM   #13
jamesfacts
Member#: 51282
98 RS
Hey Bruce, thanks for posting.
To the best of my knowledge, yes, it will fit an 02 RS. You're welcome to test fit to confirm.
Old 03-09-2012, 03:38 PM   #14
NY02subi
Member Sales Rating: (4)
Member#: 309306
2005 Legacy gt
GRP
Pmed about skirts!
NY02subi is offline   Reply With Quote
Old 03-10-2012, 10:37 AM   #15
jamesfacts
Member#: 51282
98 RS
PMs replied...
Old 03-11-2012, 06:44 PM   #16
jamesfacts
Member#: 51282
98 RS
Couple things sold...
Old 03-12-2012, 09:55 AM   #17
jamesfacts
Member#: 51282
98 RS
PMs replied...
Old 03-12-2012, 10:27 PM   #18
Unearthed
Member#: 272449
Any trunk lids laying around?
Unearthed is offline   Reply With Quote
Old 03-13-2012, 09:00 AM   #19
jamesfacts
Member#: 51282
98 RS
Sorry, that's one thing I definitely don't have.
Old 03-13-2012, 10:31 AM   #20
Stevieb_812
Member Sales Rating: (7)
Member#: 244539
2015 WRX Limited
Ice Silver Metallic
I understand the large sizes of them but just for kicks is there any way you're willing to ship the sideskirts? I live in southern NH but the drive there is over 3 hours one way, too much time and too much gas I think. Let me know!
Stevieb_812 is offline   Reply With Quote
Old 03-14-2012, 09:02 AM   #21
jamesfacts
Member#: 51282
98 RS
Maybe? I'll PM you...
Old 03-16-2012, 10:22 AM   #22
jamesfacts
Member#: 51282
98 RS
Lots of stuff still here!
Old 03-18-2012, 02:09 PM   #23
jamesfacts
Member#: 51282
98 RS
Ttttt
Old 03-19-2012, 10:32 AM   #24
jamesfacts
Member#: 51282
98 RS
bump bump
Old 03-20-2012, 10:16 AM   #25
jamesfacts
Member#: 51282
98 RS
ttttttt
FS CT: OEM STI TMIC, OEM STI suspension EJ2point0 NESIC Private Classifieds 4 02-18-2010 03:53 PM
FS in CT: 2006 STI TMIC sodo Engine/Power/Exhaust 15 11-28-2006 02:06 PM
For Trade CT: 2004 STi hoodscoop, sideskirts, wing XXTony Private 'For Sale' Classifieds 0 12-26-2005 10:13 PM
sti driveshaft, 12lb. exedy flywheel, sti starter, sti tranny mount, r160 wrx diff. mcu81 Private 'For Sale' Classifieds 7 11-01-2005 12:00 PM
Stock WRX sideskirts for sale, CHEAP, local only Impala SS AutoXer Bay Area Impreza Club Forum -- BAIC 5 08-13-2002 09:24 PM
