Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2014
Old 03-12-2013, 07:54 PM   #76
isotopesope
Member#: 265783
2008 wrx
my front excel g struts have a 2" OD where you would cut them.
isotopesope is offline   Reply With Quote
Old 03-13-2013, 07:08 AM   #77
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Originally Posted by isotopesope View Post
the front '11+ wrx struts are also a half inch longer from the spring perch to the mounting bracket. i wanted to put stock 2012 wrx stuff on my 08, but am going to avoid it for the lack of negative camber and extra front height.
I did not know about the length difference. Great info!
phenryiv1 is offline   Reply With Quote
Old 03-13-2013, 10:04 AM   #78
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Originally Posted by 13FLGT View Post
I can only have one vehicle here in Italy and it's my DD. Finding Legacy Donor Struts is a pain in the you know what right now. Especially 2011's. That would be awesome. I guess I can search EBAY again.
but.....if anyone is selling their 08 Koni's let me know. I am in the market.
again, not sure why youre hung up on the 2008 model year. 2008, 2009, 2010 are ALL the same dimensions, both WRX and Impreza (just not the STi)
gsrcrxsi is offline   Reply With Quote
Old 03-13-2013, 02:15 PM   #79
13FLGT
Member#: 308566
2011 Legacy GT 2.5
I'm not anymore just now sourcing for some.
13FLGT is offline   Reply With Quote
Old 03-14-2013, 11:46 AM   #80
13FLGT
Member#: 308566
2011 Legacy GT 2.5
I know a member that selling his set. His donors are from a 2011 wrx. It has 27K miles on it. Price is decent. $700. But I know they have a sale on Koni's right now. I can pretty much get a brand new set and donor bodies for about the same price. He does have the Race Comp springs on there. But I am sure I can get the RC Legacy springs. What do you guys think?
Old 03-14-2013, 01:52 PM   #81
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
go with NEW over used. if you buy used, you give up one of the best parts of having KONI shocks. and thats the lifetime warranty.
although im not sure if the lifetime warranty applies to you in Italy or not. if it does, the DEFINITELY buy new.
Old 03-14-2013, 03:48 PM   #82
13FLGT
Member#: 308566
2011 Legacy GT 2.5
thank you! I think I will do that instead!
Old 03-14-2013, 04:07 PM   #83
isotopesope
Member#: 265783
2008 wrx
wouldn't the extra length of the '11+ donors mess with your suspension geometry and lack of negative camber adjustment?
http://forums.nasioc.com/forums/show...7&postcount=56
i really thought gsrcrxsi set you straight on needing '08 to '10... NOT '11+.
i also REALLY don't understand why you're not using your existing struts as your donors.
Old 03-18-2013, 10:14 PM   #84
danns
Member#: 307197
2011 wrx
What a good site to buy from? koni directly?
danns is offline   Reply With Quote
Old 03-19-2013, 09:29 AM   #85
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Yes, it would.
Downtime, inability to return to stock, cost if he messes it up somehow...
I went with donor struts when I did this writeup because had I gone with my OEM parts as the cores I'd have been without my car for nearly a week.
Old 03-19-2013, 09:32 AM   #86
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Turn in Concepts
IDParts
THMotorsports
Pretty much go into Vendor subsection, search for "Koni" and rech out to those vendors. http://forums.nasioc.com/forums/sear...rchid=37236817
But do it fast, because the annual sale ends soon.
Old 03-19-2013, 09:53 AM   #87
13FLGT
Member#: 308566
2011 Legacy GT 2.5
Originally Posted by phenryiv1 View Post
Yes, it would.
this! That's the reason why I asked the questions. It also was confirmed on Legacy GT not to use my struts.
http://legacygt.com/forums/showthrea...nt-203685.html
Old 03-19-2013, 10:41 AM   #88
Dmochowski
Member#: 306478
2012 WRX limited
305whp/360tq TSM tuned
Follow the write up it took five min to do both front struts. Mark where to cut them put in vice cut with saws all put insert in and torque bolt slide rubber sleeve over and done...
Dmochowski is offline   Reply With Quote
Old 03-19-2013, 10:45 AM   #89
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Glad it helped. Did you press the insert in place or use bolts to draw it into the housing?
Old 03-19-2013, 12:53 PM   #90
Dmochowski
Member#: 306478
2012 WRX limited
Pushed them in and the bolt caught the the threads and pulled it down the rest of the way. You would be hard pressed to push them in with the nubs on the inserts
Old 04-16-2013, 01:49 AM   #91
OrbitalEllipses
Member#: 178811
2013 WRB BRZ
:banana:
Quick question: y'all are tightening the top hat while holding the piston in place with a hex key, but how are you doing final torque? Strut on the car then hit with torque wrench and hope you don't spin the piston?
OrbitalEllipses is offline   Reply With Quote
Old 04-16-2013, 02:04 AM   #92
teiva-boy
Member#: 22825
Two 1 second blasts usually is all i do once snug
teiva-boy is offline   Reply With Quote
Old 04-16-2013, 07:55 AM   #93
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Unfortunately, the common DIY methods are the IW "blips" mentioned above or good-n-tight by hand.
Old 04-16-2013, 08:04 AM   #94
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
or you can try to find a pass through torque wrench. im sure they exist, but i havent had any luck finding one.
Old 04-16-2013, 09:29 AM   #95
jay25RS
Member#: 4273
2011 GR-STI
& 2014 Legacy Ltd.
You can use a crow's foot wrench attached to a torque wrench. Calculate the torque and adjust your torque wrench as needed.
http://www.cncexpo.com/TorqueAdapter.aspx
http://www.engineersedge.com/manufac...e_wrench_1.htm
jay25RS is offline   Reply With Quote
Old 04-16-2013, 07:11 PM   #96
OrbitalEllipses
Member#: 178811
2013 WRB BRZ
:banana:
I thought about using a crowfoot, but wasn't sure it would reach the outer nut as it sits inside the top-hat. A crowfoot is cheaper than a new interchangeable head torque wrench though...
Old 04-17-2013, 07:02 AM   #97
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Crows foot won't fit.
Old 04-17-2013, 09:09 AM   #98
OrbitalEllipses
Member#: 178811
2013 WRB BRZ
:banana:
Didn't think so. Gudentite it is!
Old 04-17-2013, 10:45 AM   #99
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
if you could make your own "version" of a crows foot, that was a box end, and height offset, that would work.
sucks that some of these things dont exist for such a common thing to be worked on.
Old 04-17-2013, 11:27 AM   #100
OrbitalEllipses
Member#: 178811
2013 WRB BRZ
:banana:
Something like an O2 sensor socket would be great. Gudentite's gonna be good enough I guess.
How To: Install Evo X seats in wrx/STi xxscaxx Interior & Exterior Modification 171 12-25-2013 09:05 PM
Who installs Koni inserts? Rich10 Tri-State Area Forum 7 06-21-2005 04:11 PM
How is it to install koni inserts? titanium wrx Factory 2.0L Turbo Powertrain 2 07-08-2004 04:45 PM
Installing Koni Inserts... BlackEye Brakes, Steering & Suspension 9 06-26-2003 10:53 PM
Anyone here actually install Koni inserts? bbaerotek Brakes, Steering & Suspension 15 02-27-2002 01:20 PM
