Old 02-23-2013, 12:27 PM   #226
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Updated my first page with all the new parts and accessories. Still no update on the car though hopefully soon.
Januch09 is offline   Reply With Quote
Old 02-23-2013, 02:07 PM   #227
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
Originally Posted by Januch09 View Post
sorry if this has been asked and answered, but what are the specs on these xt7s? 18x8.5 +38 all around? how about tires?
Mr. Lin is offline   Reply With Quote
Old 02-23-2013, 02:12 PM   #228
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Post
Wheel Size: 18x9.5+38
Tire size: 245/40/18
Old 02-23-2013, 02:47 PM   #229
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
wow that fitment is on point then. im guessing a simple fender roll and maybe a degree or two of camber?
Old 02-23-2013, 03:37 PM   #230
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Yupp, that's about right.
Old 02-23-2013, 03:53 PM   #231
Jive Turkey
Member#: 219492
11' STi, RIP CSK.
13' Galaxy Blue Breeze
that fitment is weak. and a 245 isn't the right size for a 9.5' wheel.
Jive Turkey is offline   Reply With Quote
Old 03-12-2013, 02:08 PM   #232
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Should I go with the clutch masters FX300 or FX400?
Old 03-12-2013, 08:47 PM   #233
Ricanracer21
Member#: 334871
Hey Januch, how much was it to get a rear view camera installed in your trunk? Also with that double den did you keep the BT functionality?
Ricanracer21 is offline   Reply With Quote
Old 03-12-2013, 08:51 PM   #234
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Uhm, right around 200 installed is what you'll pay for a camera. Yes Bluetooth is fully functional.
Old 03-12-2013, 09:03 PM   #235
Ricanracer21
Member#: 334871
Sweet, I appreciate it bro. How's the car coming along? Haven't seen anything in a while. By the way I'm thinking of doing a similar sub set up in my trunk.
Old 03-12-2013, 09:08 PM   #236
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Just waiting on cams. Then I have to break it in and get it tuned and it should be good. Once weather gets nice have a lot of parts going on the car. Big plans.
TBH, if you plan on doing subs, make sure you spend the money on sound deadening to prevent really bad rattle and what not. I've tried multiple things and nothing seems to work perfect, but I'd invest in foam, dynomat, and w.e. else will create a layer between the trunk and rear deck.
Good luck.
Old 03-12-2013, 11:21 PM   #237
Jive Turkey
Member#: 219492
11' STi, RIP CSK.
the gallo 24
Old 03-13-2013, 12:15 AM   #238
Ricanracer21
Member#: 334871
Good luck.
So in your sti does the plastic rattle a lot? Like I continue to take it to the dealership because the plastic just rattles when it's cold mainly, and its not just the rear end, it's also in the plastic sides that connect to the dash and seatbelts, is this normal for you as well? They've replaced the back altogether and it took care of the problem, but then it came back, I currently have that little crappy sub ordered from Subaru and I took it to the shop where I get my other sound things done and he said he doesn't believe that little box is what's doing it..the sound deadening for JUST the trunk is about $600 with labor, that's too much to pay for that :/ although I would like it. Please let me know!
Old 03-13-2013, 08:30 AM   #239
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
You drive a Subaru lol, rattles are built into the car. Everything will eventually rattle hahaha but for me, the rear deck is by far the worst.
Idk who quotes you 600 for that stuff but that's rediculous. Do the work yourself and it'll cost you less then 100 in parts. Rear deck takes 20 min to get out. There plenty if write-ups on it.
The sub will add to the rattles but sound deadening will help a huge amount.
Old 03-16-2013, 11:39 AM   #240
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Still need help with the clutch situation? FX300 or FX400? Anyone running it on your GR w/ 400+whp?
Old 03-16-2013, 11:43 PM   #241
kuchar
Member#: 345674
2013 WRX Hatch
World Rally Blue
The FX300 is more for daily driving but is still able to hold big power , the FX400 made for the track because it is alot more grippy and would suck to drive on a day to day basis.
Just all depends what you want to use the sti for (dd or track)
kuchar is offline   Reply With Quote
Old 03-16-2013, 11:46 PM   #242
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
well being that the car is my daily but is going to be very track oriented, idk lol. Decisions decisions, thanks for the clarification.
Old 04-11-2013, 01:50 PM   #243
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Look what came in finally
Old 04-18-2013, 04:33 PM   #244
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Well motor is assembled. Just gotta throw it in the car and put some miles on it
Old 04-18-2013, 05:51 PM   #245
Ricanracer21
Member#: 334871
Yay! Finally man! Haha, can't wait to see what it's putting out!
Old 04-18-2013, 05:55 PM   #246
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Hahahha. You and me both. These break-in miles when I get it back are going to be so hard. I miss boost!!!!
Old 04-18-2013, 06:45 PM   #247
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Clutchmasters FX300
Old 04-26-2013, 09:20 PM   #248
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
Well, I got it back today finally! Break-in begins!
Old 04-27-2013, 12:34 AM   #249
Ricanracer21
Member#: 334871
4-26-13
Yay!!!
Old 05-05-2013, 11:07 PM   #250
Januch09
Member#: 309459
2011 STi Sedan
Satin White Perl
6 hours of porter cable: clay, compound & wax......B-E-A-UTIFUL!
Added some gloss black vinyl for the chrome window trim delete.
I'm at about 450 miles on the new motor. Did one oil change so far and no metal shavings in the oil at all.
Scheduled to be tuned on the 16th of this month!
Here's some pics!
My 2011 WRX limited Hatch TGUN11 Newbies & FAQs 11 08-10-2011 06:19 AM
Brake and Rotor Upgrade for 2011 STI limited aznboi0204 Brakes, Steering & Suspension 10 04-06-2011 07:37 AM
Trade in 2008 STI for 2011 STI Limited ericsson Newbies & FAQs 17 10-07-2010 12:54 AM
2011 STi limited interior pics..... 3rdsubaru Member's Car Gallery 1 09-22-2010 07:31 PM
2011 STi Limited soon to be delivered! oscarmayer Texas Impreza Club Forum -- TXIC 13 07-22-2010 01:05 PM
Message Board Statistics All times are GMT -4. The time now is 09:46 AM.
