North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 01-29-2013, 03:11 PM   #2601
SRP02WRX
Member#: 292138
2005 STi
World Rally Blue
So I'm thinking about getting some front and rear sway bars here soon. Any suggestions on sizes?
SRP02WRX is offline   Reply With Quote
Old 01-29-2013, 03:39 PM   #2602
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
I have a 20 or 22 up front and a 22/24 adj. In back and am pretty happy with them. Are you still on stock wrx ones?
spackyscooby is offline   Reply With Quote
Old 01-29-2013, 04:09 PM   #2603
SRP02WRX
Member#: 292138
2005 STi
World Rally Blue
Yes sir.
Old 01-29-2013, 05:07 PM   #2604
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
Run both F&R 24mm adj. Whitelines.
Better than stock, but never felt like the GD's really get good until you get really big ones (which can get impractical). I guess I just don't like how much body roll they have compared to other cars.
neko is offline   Reply With Quote
Old 01-29-2013, 07:20 PM   #2605
SRP02WRX
Member#: 292138
2005 STi
World Rally Blue
I want very little roll if any, if possible and I want it to turn better than an Evo. I am determined to beat my buddy in his Evo in auto x this year.
Old 01-29-2013, 08:25 PM   #2606
neko
Member#: 46500
Now with 200% more
In that case you need better spool or lower torque, a much shorter steering rack, and depending on his suspension, probably some sways/struts/coils of your own (i don't know what you run now).
That's one of the things i do like waaay better about the Evo 7/8/9's is the steering rack. Amazing.
Old 01-29-2013, 08:28 PM   #2607
SRP02WRX
Member#: 292138
2005 STi
World Rally Blue
I'm already on coils. He didn't beat me by much last year so I'm hoping to eliminate some of the under steer so I can get closer to him and hopefully beat him.
Old 01-30-2013, 04:17 AM   #2608
InkyRail
Member#: 267266
'15 VA, E8H
'95 GM4, 307
Definitely match f&r. You'll understeer as long as the front is bigger than the rear. 24/24 is a good suggestion.
InkyRail is offline   Reply With Quote
Old 01-30-2013, 08:40 AM   #2609
RedCelicaTRD
Member#: 212731
If you match sizes make sure they are adjustable. A larger rear bar, or a equal size bar on a higher setting in the rear, will help with rotation. Unfortunately if you go to stiff a bar with a high spring rate coilover you will pick up a rear tire on corners and lose speed. It's a delicate balance between to tight and to soft.
RedCelicaTRD is offline   Reply With Quote
Old 01-30-2013, 10:18 AM   #2610
neko
Member#: 46500
Now with 200% more
or perhaps since you already have a 20mm front, upgrade just the rear if you want better rotation and see how you like it. really, a lot of getting the right match of sways i just changing and adjusting and feeling out the car to see if you like the results. Thankfully, oem and aftermarket sways are widely/cheaply avail 2nd hand, and easy to swap out.
Also, you have coilovers already (no clue how quality they are), you should have the capability to stiffen the car quite a bit as is. There are auto-x'ers/trackers out there in various cars that resort to not-upgrading, or even removing, their sways and relying on their upgraded suspension to do the job.
Old 01-30-2013, 03:57 PM   #2611
SRP02WRX
Member#: 292138
2005 STi
World Rally Blue
So if I just do the rear, how big should I go?
Old 01-30-2013, 04:14 PM   #2612
neko
Member#: 46500
Now with 200% more
You should be a 20mm now? (or do you have the 17, I can't remember when they switched, late 02, or 03...)
I would think going to a 24mm adj and starting off at the lowest setting, to see how ya like it. Then later if you move to a 22 or 24mm front, it will still be fairly biased. Try looking here and elsewhere for used ones, lots of people sell them when they trade in, since they're easy to remove.
Old 02-01-2013, 03:52 PM   #2613
TacSTi
Member#: 335122
I traded the STI. Bought a Titan and I'm getting a CBR 1000RR when a good one pops up on KSL or locally. It was either the STI, or a truck and bike. And I <3 me some motorcycles!
*Flame-protective suit ENGAGED!*
TacSTi is offline   Reply With Quote
Old 02-01-2013, 03:55 PM   #2614
DeathToad
Member#: 266010
'07 Leggy SpecB
gray
At least I'm trading mine for a Spec. B. Traytur!
DeathToad is offline   Reply With Quote
Old 02-02-2013, 01:17 AM   #2615
sinistermatti
Member#: 226446
2007 LGT Spec B
Dark Grey Metallic
April fools day is several months away. good try.
sinistermatti is offline   Reply With Quote
Old 02-02-2013, 08:20 PM   #2616
DeathToad
Member#: 266010
'07 Leggy SpecB
gray
I think I managed to snag one of the two clean, low mileage relatively unmolested Spec.B's in the northwest. It's an '07, got a nice lump of cash back trading in the STI that we'll plunk down to pay off the 'stang that much sooner. As near a I can tell it just has an SPT catback and intake. 43k miles. Stock downpipe, but I understand the one I kept from the '11 will fit nicely.
I'm liking this car, I could see myself owning this one for quite a while (but I always say that). Doors have a strange substantial feel when you close them (in that they have some...substance that is) and the cabin is relatively silent.
Old 02-03-2013, 12:28 AM   #2617
TacSTi
Member#: 335122
Nice man! I like that color a lot.
Old 02-03-2013, 04:19 AM   #2618
sinistermatti
Member#: 226446
2007 LGT Spec B
Dark Grey Metallic
Looks great! grats!!
Might want to look into losing the bug deflector though. I've read that it can reduce the airflow to the hood scoop, at least on the WRXs, not sure about the LGTs.
Old 02-03-2013, 04:40 AM   #2619
InkyRail
Member#: 267266
'15 VA, E8H
'95 GM4, 307
I imagine it's worse for LGTs, with the smaller hood scoop. Congrats DeathToad!
Old 02-03-2013, 09:34 AM   #2620
DeathToad
Member#: 266010
'07 Leggy SpecB
gray
Thanks all.
Good idea on ditching the deflector... was going to ditch it anyway 'cause they look hokey, but that's an even better reason.
Old 02-03-2013, 10:54 AM   #2621
RedCelicaTRD
Member#: 212731
I'd just clear bra it. Works and looks better then the dorky deflector.
Old 02-03-2013, 08:22 PM   #2622
SRP02WRX
Member#: 292138
2005 STi
World Rally Blue
So fast 6 looks way more over the top and ridiculously cheesey.... I can't wait!
Old 02-03-2013, 08:37 PM   #2623
Cameron208
Member#: 331535
2003 WRX
I know right, that was exactly what I was thinking
Cameron208 is offline   Reply With Quote
Old 02-03-2013, 08:41 PM   #2624
InkyRail
Member#: 267266
'15 VA, E8H
'95 GM4, 307
WHOO HOO!!!
Old 02-03-2013, 09:32 PM   #2625
Lacrosse
Member#: 263633
1999 FRC
Who wants to go the the fast 6 premiere?
SOSEI MOVIE PARTAY!
Lacrosse is offline   Reply With Quote
Eastern Idaho owners(or any ID really) Check-In!!! Local Get-togethers?? neko North West Impreza Club Forum -- NWIC 386 05-12-2010 06:01 PM
Tuners in Northern Wyoming/Eastern Idaho? bryancregger Rocky Mountains Impreza Club Forum -- RMIC 3 01-06-2010 11:05 AM
NWIC - Official "I saw it on Craigslist" Thread Dena North West Impreza Club Forum -- NWIC 4 11-02-2008 10:19 PM
