Old 03-10-2012, 06:33 PM   #1
nexgen
Member#: 179789
2002 When in Doubt
Flat Out!!
Default what ej20 do i have ?
hey guy's i received this short block in a trade and i really don"t know much about it and i'm hoping you'll can help me identify it. i was told it's from a jdm sti and that it's suspoused to rev to 8k. i don"t have the heads so i took pics of the numbers on the block.
the last one's a little hard to read but the numbers 812876812521
thanks joe
nexgen is offline   Reply With Quote
Old 03-10-2012, 07:32 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
What are the numbers above where the water pump mounts? Something like Z25 301
Old 03-10-2012, 08:37 PM   #3
nexgen
Member#: 179789
2002 When in Doubt
Flat Out!!
Fm-1 and on the bottom of the motor it says 20l and 20r
Old 03-10-2012, 10:03 PM   #4
jollyblue84
Member#: 292300
01 GC8
blue
I am also wanting to double check my motor. I'm told by a few people that its a ej20g. How can I be sure?
jollyblue84 is offline   Reply With Quote
Old 03-11-2012, 12:37 AM   #5
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
This looks like a MY99-00 EJ207. It has forged pistons but stock rods.
Marnix is offline   Reply With Quote
Old 03-11-2012, 09:35 PM   #6
nexgen
Member#: 179789
2002 When in Doubt
Flat Out!!
would the forged pistons work in an 02 wrx motor?
Old 03-12-2012, 05:45 AM   #7
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
The 02 WRX motor is the same except for the pistons. So you could use this block in a WRX yes or use the pistons in a WRX block but make sure the block bore size (A or B) match the piston size (A or B).
Old 03-16-2012, 04:01 PM   #8
nexgen
Member#: 179789
2002 When in Doubt
Flat Out!!
thanks marnix, any idea one of these would be worth if it needs to be rebuilt
Old 03-31-2012, 04:15 AM   #9
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Used pistons are not worth anything really, they should stay in the cylinders they were in if they have low mileage. But from what I see here the block in the pics is a USDM 2.0L Nothing special. Most of the JDM version blocks are Semi-closed deck and yours is not.
UK-Wagon is offline   Reply With Quote
Old 03-31-2012, 01:12 PM   #10
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
I agree with Marnix; looks like a 99-00 EJ207.
My 99 v5 EJ207 have those pistons and was also a open deck block.
Like Marnix said, the only difference between your block and a USDM 02-05 WRX block is the forged pistons. block, rods, crank, etc are pretty much identical.
simer1228 is offline   Reply With Quote
got wrx springs, now what else do I have to do? LegacyNate Brakes, Steering & Suspension 0 01-08-2010 01:30 AM
What STD do you have or have you had? Harv_ Off-Topic 24 11-09-2005 11:31 AM
What EJ20 do I have? gotsol Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-13-2005 12:41 PM
CT Drivers: What Insurance Do You have / what do you pay? BrysImpreza New England Impreza Club Forum -- NESIC 13 06-08-2002 03:46 PM
For those of you that have godspeed downpipe, what catback do you have? Night Kid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 05-29-2002 11:11 AM
