Old 03-10-2012, 10:01 PM   #1
jollyblue84
Member#: 292300
01 GC8
blue
Default ej20g air intake upgrade?
I'm wanting to upgrade the air intake. What would be best? Thanks
jollyblue84 is offline   Reply With Quote
Old 03-11-2012, 01:33 AM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
each affect maf scaling, which is bad.
if you have a rob tune use an apexi unit. all his tuning was done with that unit
eg33GC is offline   Reply With Quote
Old 03-11-2012, 12:26 PM   #3
jollyblue84
Member#: 292300
01 GC8
blue
I don't have the rob tune at the moment but will soon. Should I wait?
Old 03-11-2012, 12:49 PM   #4
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
I use an apexi unit
sizzflair is offline   Reply With Quote
Old 03-11-2012, 03:26 PM   #5
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Originally Posted by sizzflair View Post
I use an apexi unit
I have the EJ20G Apexi intake on order. It's going on as soon as it arrives. I've seen and heard no bad things about it what so ever. Apparently the filter used is a superfine mesh with quite alot of extra surface area to prevent particulates and reduce intake restriction. Who knows if there is any truth to that. I'll find out after I install it. The main thing is that it ditches the restriction of the upper intake resonator.
Ditching the upper resonator is very good but from what I've read the lower intake resonator is actually a much larger intake restriction. So in a cold climate where ambient enginebay air temp is not such a big deal a pod filter like with the apexi is probably a good idea. In a warmer climate like california, nevada, arizona type temps it's probably best to get a little hands on and modifying the stock intake like they did here in this austrialian automotive mag I found a link to.
Read here:
http://autospeed.com/cms/A_1605/printArticle.html
The article is old. But so is the GC8-EJ20G so it should still be pretty good advise.
TommyAtomic is offline   Reply With Quote
Old 03-11-2012, 07:25 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
I just made one. It's a black coupler, maf adapter and a cone filter. I spend about $30 on it, 2 years later still working fine. Maybe someday I'll get the apexi one just for the jdm bling.
Old 03-11-2012, 10:54 PM   #7
sizzflair
Member#: 94268
2010 Exige S240
Read here:
When I bought my car, it had the HKS unit installed. I read an article somewhere where they tested all the different filters. Long story short, the Apexi filter had the best filtering and did not need any oiling/maintenance versus the other units.
I've had no issue with my intake. I'm not running MAF anymore so I just have the filter with a 3" piping. I still have most of the Apexi intake parts (except the filter and other minor things). It's a solid unit. You'll be happy.
Old 03-15-2012, 06:28 AM   #8
Subbiespeed
Member#: 276493
2005 STI
I made mine as well
Subbiespeed is offline   Reply With Quote
FS : socal:08+wrx/sti 73mm KS Tech Cold Air Intake Black *PRICE DROPPED* Blackout713 Engine/Power/Exhaust 21 03-20-2012 02:45 PM
ej20g air box, ej20g flywheel, 2000 rs intake man, and more GregBolby 1993 - 2001 Impreza Specific Parts 4 02-04-2012 01:36 PM
WTB: 02/03 WRX stock air intake or trade for Injen cold air intake limpstick VIC Private Classifieds 17 02-16-2007 01:46 AM
ram air intake vs cold air intake Shaji Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 62 07-21-2002 09:05 PM
AEM cold air intake or Injen cold air intake? energy57 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 05-20-2002 12:27 AM
