Old 03-11-2012, 12:42 AM   #1
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Default Subaru reverse camera that replaces license plate light
Has anyone installed one of these rear view cameras before?
It says it's for a Subaru Forester or Legacy, but doesn't look to hard to make it fit an Impreza.
http://www.ebay.com/itm/CAR-REAR-VIE...item3a644e8500
BeBop86 is offline   Reply With Quote
Old 03-11-2012, 12:14 PM   #2
chithead
Member#: 312018
2014 WRX Hatch
That's pretty stealthy right there.
chithead is offline   Reply With Quote
Old 03-11-2012, 12:52 PM   #3
jakechup
Member#: 280793
02 WRX Wagon
the ebay post said for forester/ impreza sedan.
jakechup is offline   Reply With Quote
Old 03-11-2012, 03:31 PM   #4
dorkbert
Member#: 309901
2012 Impreza 2.0i 5D
do take fleaBay seller's claims with a grain of salt (particularly those from HK and CN.)
dorkbert is offline   Reply With Quote
Old 03-11-2012, 04:23 PM   #5
blackhawk77
Member#: 296374
2011 WRX Sedan
What year imprezas does it fit? I bought a license plat bolt one but haven't installed it yet. I would rather have something more plug and play that I can reverse instead of drilling holes.
blackhawk77 is offline   Reply With Quote
Old 03-11-2012, 04:30 PM   #6
blackhawk77
Member#: 296374
2011 WRX Sedan
I sent the seller an email about what years it fits, I'll order one and give a review if it fits a 2011.
Old 03-12-2012, 03:11 AM   #7
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
I'm fairly certain this is meant for newer subarus (I think this is a copy of a uk/jdm option).
I'm surprised no one has seen this before.... guess I'll have to get one and try it out with my bugeye.
Old 03-14-2012, 01:30 PM   #8
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Well, just ordered one.
Ships from China, so it will probably take a while before I get it.
http://www.ebay.com/itm/260881090188...84.m1497.l2649
Old 03-14-2012, 01:36 PM   #9
blackhawk77
Member#: 296374
2011 WRX Sedan
I wasn't confident enough ordering one after getting this response from the seller.
Hi my friend, thank you very much for your very friendly/polite question about our item , generally speaking,this item can fit with 2011 impreza sedan , thanks a lot again . "
Old 03-14-2012, 02:04 PM   #10
first suby 2010
Member#: 238974
2012 impreza premium
and 09 Forester XT
I think I still have one I ordered from a different seller a while back. It fit my 08 sedan perfectly, but even though it said it was NTSC video system it was not. This doesnt generally matter if you are hooking to an aftermarket radio cause most accept either signal, but sadly the factory NAV did not. I might still have it in the garage in the original box if anyone is interested. I will check.
first suby 2010 is offline   Reply With Quote
Old 03-14-2012, 02:06 PM   #11
Lateralis
Member#: 144421
2012 STi ltd
Wow hahaha.
It is just 18 bucks..... meh...
Lateralis is offline   Reply With Quote
Old 03-14-2012, 02:10 PM   #12
mattesonb
Member#: 139607
2011 WRX
DGM Wrapped Satin Black
i ordered one like this from a seller on amazon, there a re a couple issues with this type of camera.
1- your license plate lights are not screwed in, they are pressed in with a clip. so the screws on each end mean you would be screwing directly into the car
2- the housing was cheaply made and they used a hot glue gun to seal the internals
3- the attached plug ends are large and not removable which means you need a decent sized hole to pass them through
i ended up returning the unit i had and shelled out 140 for a pioneer nd5, light years ahead of one of these sketchy ebay/amazon ones...
mattesonb is offline   Reply With Quote
Old 03-14-2012, 02:13 PM   #13
first suby 2010
Member#: 238974
and 09 Forester XT
You must have a hatch, not a sedan, in which what you are saying is correct. On the sedan they are screwed into the trim panel above the license plate.
Old 03-14-2012, 02:30 PM   #14
mattesonb
Member#: 139607
2011 WRX
correct, forgot to mention hatch not sedan
Old 03-14-2012, 02:38 PM   #15
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
I'm not expecting anything great, but it's cheap and it's a pretty cool concept.
Old 03-14-2012, 03:10 PM   #16
mattesonb
Member#: 139607
2011 WRX
well the best advice i can give is to test fit the unit and be sure its the on you want to use before you commit to ripping apart the car and wiring it in, that part is a bitch
Old 03-14-2012, 03:14 PM   #17
Snow Drift
Member#: 75071
4 Train - Subway
Past: 05, 08, 11 Red WRXs
This thread has info on how to get the 2008+ OEM USDM Nav unit to play the rearview camera. http://forums.nasioc.com/forums/show...ighlight=svxdc
PM SVXdc with any questions, he knows everything.
Old 03-14-2012, 03:16 PM   #18
first suby 2010
Member#: 238974
and 09 Forester XT
If that was directed at me I know all about that...
I have had it working with an NTSC camera for months now, which is what that was supposed to be when i ordered it.
Old 03-14-2012, 04:54 PM   #19
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Well said... I'll keep that in mind
Old 03-15-2012, 08:34 PM   #20
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
That sounds like the same kind that a few people bought (and cursed at) on the Forester forums (this thread, starting at post #24). Those cameras actually do output some facsimile of NTSC, but apparently off spec just enough that the OEM Kenwood Navi can't mix the camera's video signal with the graphics and text that the Navi adds ("Check surroundings..." and parking guide lines).
I'd love to find someone who works in a video production company who can plug that camera into a signal analyzer to see just how far off it is.
Since that was quite awhile ago, I wonder if that camera manufacturer has fixed the problem on current units.
SVXdc is offline   Reply With Quote
Old 03-16-2012, 03:58 PM   #21
first suby 2010
Member#: 238974
and 09 Forester XT
I do still have it. I actually tried them from two different sellers at two different times, both said they were NTSC video system. Sadly, neither were. They both looked like the same camera, but came in different (obviously cheap chinese) packaging. I still have one of the two, think I put the other on for someone that had an aftermarket nav unit.
We tested the one I have now at work a few months back. Had a monitor that switched back and forth between PAL and NTSC input, NTSC was liney and B&W, switched to PAL and it worked fine
Old 03-16-2012, 09:08 PM   #22
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
That's different, then. The Forester owner in the UK tried his camera into several devices, and it worked when all of them were set for NTSC (and didn't work when they were set to receive a PAL signal). That included the Navi's aux input (when that was set for NTSC, but not for PAL). I think the owner in Australia tried similar tests.
So their cameras were definitely some form of NTSC, just not "proper" enough.
Yours outputting PAL is a different issue. Probably got labeled wrong somewhere in the assembly line. There might be a switch, jumper, or PC board trace inside to switch that (probably not worth the effort to check, though).
Old 03-17-2012, 04:52 AM   #23
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Do you guys remember if those cameras were CMOS cameras or CCD camera's?
The seller claims on this listing that this is the newer "better" CCD camera.
Old 03-18-2012, 11:37 AM   #24
ZURCALED12
Member#: 309754
2012 Impreza Sport L
Ice Silver Metallic
I believe they were CMOS ?
ZURCALED12 is offline   Reply With Quote
Old 04-02-2012, 05:18 PM   #25
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Update, received my camera in the mail... just need to install it next.
Subaru baja tailgate license plate light burned out... Soukyoku Electrical & Lighting 6 02-10-2016 12:51 AM
License plate lights and trunk light out TBone7281 Electrical & Lighting 6 05-17-2009 01:35 AM
reverse camera mounted onto license plate AzN121184 Car Audio, Video & Security 1 09-25-2008 08:01 PM
Replace license plate light not working? ltjman22 Electrical & Lighting 7 03-27-2008 02:48 AM
License Plate Lights/Backup Lights No Workie WhiteWRX2002 Electrical & Lighting 8 10-17-2006 12:03 PM
